I want some help as i cannot be able to create pwm in oc1b & oc2 instead i create what i need to the others two oc0 & oc1a!!! in mega 8515 everything is ok and i use ( assembly) this:
as i have told , with 8515 i an be able to controll the pwm in mega 16a in not!! i use the same way with ofcourse the changes that are necessarily as the output ports and the include file..
if somebody could help me i thank you in advance.
