EVK1104 --- SD card with FAT?
6 posts / 0 new
One AVR example uses SD card with the MMC with sector read writes. Another example uses FAT with a SPI memory.
Does anybody have either a solution or an example of FAT with the SD card in either MMC or SPI mode? Preferably MMC
I want to load a .wav file from the SD card and store the samples in RAM.
Does anyone have any idea?
http://elm-chan.org/fsw/ff/00ind... use the FATFS sample pjts. --> AVR and port it for the AVR32. See the 2 tutorials in the 'Freaks tut. forum.
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
The Software Framework already has FAT support with SD card on both MCI and SPI interfaces. It is very complete and works like a charm...
Have you taken a look at the software examples for the AVR32 in the framework?
Daniel Campora http://www.wipy.io
hello ,
how i can write float variable on sd card becuase fprintf does not souport
thank you
There are two ways I can think of (well more but two of the more obvious):
1) Just convert the float to ASCII and write that:
char buff[20];
sprintf(buff, "%f", fp_var);
f_puts(buff, fil);
If fp_var contains 3.141592 then the file will have "3.141592"
2) just write the float in binary. float vars are usually just 4 bytes. So:
UINT written;
float fp_var = 3.141592;
f_write(fil, &fp_var, 4, &written);
This will actually write something like 0xD8, 0x0F, 0x49, 0x40 to the file which is 3.141592 in little endian IEEE754 format. The reader of the file would then put those 4 bytes back into a float. As log as it also uses little endian and IEEE754 formats then the same value will be recovered.
