USART Programming in Atmega328
7 posts / 0 new
/* Program for transmitting a string serially at 9600 baud rate continously,
using 8 data bit, 1 stop bit , XTAL = 8MHz */
#define F_CPU 8000000UL
#define BAUD 9600
#define MYUBRR F_CPU/16/BAUD-1
#include <util/setbaud.h>
#include <util/delay.h>
void USART_Init( unsigned int ubrr);
void USART_Transmit( unsigned char data );
unsigned char USART_receive(void);
void USART_putstring(char* StringPtr);
int main( void )
    USART_Init(MYUBRR);
        // Chose an arbitrary character to test.
        //char String[]="Hello world!!";
        //USART_putstring(String);
        USART_Transmit('1') ;
        _delay_ms(1000);
    /*Set baud rate */
    /* UBRR0H contains the 4 most significant bits of the
    baud rate. UBRR0L contains the 8 least significant
    bits.*/
    UBRR0H = (unsigned char)(ubrr>>8);
    UBRR0L = (unsigned char)ubrr;
    /*Enable transmitter */
    UCSR0B = (1<<RXEN0) | (1<<TXEN0) ;
    /* Set frame format: 8data */
    UCSR0C = (1<<UCSZ01)|(1<<UCSZ00);
    /* Wait for empty transmit buffer */
    while ( !( UCSR0A & (1<<UDRE0)) );
    /* Put data into buffer, sends the data */
    UDR0 = data;
unsigned char USART_receive(void){
    while(!(UCSR0A & (1<<RXC0)));
    return UDR0;
void USART_putstring(char* StringPtr){
    while(*StringPtr != 0x00){
        USART_Transmit(*StringPtr);
    StringPtr++;}
when I try to run this code & see the received string using Teraterm terminal , the terminal shows different kind of characters ?
First Fail & then succeed, this is what Engineering teach me.
Is you CPU really running at 8MHz?
How have you proved that?
Are you using the internal RC oscillator?
I see you include my setbaud.h but then you define MYUBRR yourself?
I am using calibrated internal RC oscillator i.e 8Mhz .
There is no change after removing setbaud.h  .
How is it "calibrated"? I see nothing in the code that represents a calibration process.
The internal RC oscillator is really inadequate for timing a UART unless you do a genuine calibration. This is often done with an external 32.768KHz crystal. Even better is an 8MHz crystal.
Thank you for the information.
I made the fuse bits to its default settings of CKSEL3..0 which results in internal RC oscillator @ 8 Mhz .
As a result of which I get the proper result on terminal.
