UTF-16 encoding
5 posts / 0 new
does anybody how I can encode text into UTF-16 to send out on USART? For example, I want to send the following string in UTF-16:
unsigned char temp[] = "test";
I'm not sure how I should be declaring this to make it 16 bits/character. Thanks for the help.
I think it's standard C:
wchar_t temp[] = L"test";
The "trick" being that pre-pended L on the string defintion.
Cliff
How would I break it out into 1 byte chunks to send to the USART?
Nevermind, i just used memcpy and moved it into an array. Thanks for the help.
As far as I know, UTF16 uses 16 bits for each character. But, each 16 bit word can be broken into 8 bit bytes. At the other end, the bytes a assembled, end-to-end and the result is interpreted using the rules of UTF16.
That is all there is to it.
This is for PORTB, not the UART but this little bit of code seems to do the trick (on my compiler anyway):
#include
#include
int main (void)
	int i;
	char *p = (char *) &temp;
	for (i=0; i<8; i++) {
		PORTB = *p++;
	while(1) {
