udi_cdc_getc() not working in SAM E70
2 posts / 0 new
I have SAM E70 and I want to get character using udi_cdc_getc() through hyperterminal and echo back using udi_cdc_putc().
The problem is udi_cdc_is_rx_ready() is always false, even when I type letters in hyperterminal. However, udi_cdc_putc() does work by itself when I put udi_cdc_putc(67) it shows "C" in hyperterminal.
Am I doing something wrong?
Below is my entire code:
#include <asf.h>
#include "conf_usb.h"
#include "ui.h"
#include "uart.h"
static volatile bool main_b_cdc_enable = false;
    irq_initialize_vectors();
    cpu_irq_enable();
    sleepmgr_init();
#if !SAM0
    sysclk_init();
    board_init();
#else
    system_init();
#endif
    ui_init();
    ui_powerdown();
    udc_start();
    stdio_usb_enable();
    int input;
    while (true) {
    if (udi_cdc_is_rx_ready())
    input = udi_cdc_getc();
    udi_cdc_putc(input);
Thanks in advance.
Hey did you manage to fix your issue?
