UART receive problem
9 posts / 0 new
I have a UART receive problem. When I sent char , I saw true value(echo example). But I send some char QUICKLY , echo is wrong . As below.
send: 8888888888888888
echo(receive): 88ÎÎÎ8ÎÎå8
If I send slowly some char, It was success.
send: 8888888888
echo(receive):8888888888
//interrupt code
ISR(USART0_RX_vect){
    data[data_cnt++] = UDR0;
    uart0.receiveHandle(data);
I used UART peripheral (it is not softSerial).
What do you think about this?
Serkan.
How is your AVR clocked?
You’re the millionth and one person who has uart problems. Number 1 culprit is clocking. You wouldn’t happen to be using the internal oscillator would you?
Note - your code doesn’t check for array bounds.
I figure out my fault. Its reason is stop bit count problem. I used 2 stop bit and receive side is 1 stop bit. And when it was quick, occured problem.
Also thanks for your reply Kartman.
Serkan.
I think you mean the other way around. The transmitter using 2 stop bits is not a problem, but if the receiver is set for 2 stop bits and the transmitter one, then i can see how the problem ocurred.
I mean transmit side = 1 stop bit , receive bit = 2 stop bit calculate. another thinking is thinking reverse. Because this is echo example.
Serkan.
Still doesn't make sense since the receiver ignores the
setting of USBS for number of stop bits:
USART Stop Bits Setting
--Mike
avr-mike wrote:
Still doesn't make sense since the receiver ignores the setting of USBS for number of stop bits:
Do we know the receiver is an AVR?
Regardless, the symptoms are classic stop bit error, with loss of character sync caused by receiver expecting 2 and only getting 1!
Not necessarily.  Even if both TX/RX stop bits agree, if baud rate error is near limit, single characters can make it through fine, but repeated characters with no additional idle time can result in incorrect start-bit detection.
We need more information.
OP:  What is doing the sending?  What is doing the receiving?  Do you have an oscilloscope?  Set your transmitter for 8N1, then send an endless series of 'U' characters.  You should see a square wave with a frequency exactly 1/2 the baud rate.  What do you see?
