Interrupts Not Required
58 posts / 0 new
Pages
No interrupts - all I/O is polled.
This book avoided interrupts; but it used an 8051, so maybe it had to.
"Patterns for time-triggered embedded systems" by Michael J Pont, from 2001, published by Pearson Education.
Mike
The 8051 series actually has a more sophisticated interrupt system than the AVR as it has a two-level priority scheme. So no, it did not have to.
This is a bit like Monty Python's Four Yorkshiremen but doesn't the Xmega have a 3 level priority system? ;-)
Add :
And the 8051 had bank switch of the registers (mostly used for interrups), think if r24-r31 on a AVR could be changed to r8-r15 just by flipping a bit ;)
Wish I could switch my bank that easily.
smiley
4 (including NMI for XMEGA PMIC)
3 with NMI for unified memory AVR (tinyAVR 0-series, tinyAVR 1-series, megaAVR 0-series)
unified memory AVR
The registers are moved from the memory map , so it should only be "changed memory AVR" devil
Pages
