1st step:
Use 1mm drill bit to widen the plastic case of IDC connector.
But very carefully with gentle force inorder not to damage the inner metal clamp of IDC
2nd step:
Push the spring connector pins one by one straightly against a semi hard surface (wood, etc) one by one.
The inner clamp is not designed for 1mm,
İt will clamp the pin tightly, no chance to pull back the pin again!
Must be done correctly at first try!
Posted by Brian Fairchild: Wed. Jan 30, 2019 - 07:09 PM
1
2
3
4
5
mu234 wrote:
Thank you for pointing out the size. In addition, your idea is also good, will look at it more! Looked at Farnell guy, this is huge, without knowing what I am looking is illusion to find anything :) any idea how to find what is on picture? Best. PS what OP stands for?
#5 "If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand."
You ought to be able to program 8k bytes in just over a quarter of a second (8k bytes of flash x 4 bytes per programming instruction x 8 bits per byte x 1us per bit). Doing and undoing a clamp will be much slower than that.
I have realised that I have a jumper on my USBasp ( http://msx-elektronika.pl/en/usb... ) and it is on "slow", however, I remember putting it on due to the fact that it did not work on "fast", does any of you know what could be the problem?
Is this the problem of having an internal CLK on 1Mhz / 8Mhz, is this the source of a problem for programming at higher speed?
What's the secret?
FF = PI > S.E.T
Top"Experience is what enables you to recognise a mistake the second time you make it."
"Good judgement comes from experience. Experience comes from bad judgement."
"Fast. Cheap. Good. Pick two."
Top1st step:
2nd step:
True for second step!
Majid
TopI do not why, but it takes me around 30sec to program good 4kb via usbasp...
Best.
Bravo!!!
TopThank you for pointing out the size. In addition, your idea is also good, will look at it more!
Best.
Bravo!!!
TopBeen here, done that, but too big :/
Best
Bravo!!!
TopOriginal Post(the posting that started the thread) or Original Poster( the person that made the first posting)
FF = PI > S.E.T
Tophttps://uk.farnell.com/avx-inter...
#1 Hardware Problem? https://www.avrfreaks.net/forum/...
TopI have realised that I have a jumper on my USBasp ( http://msx-elektronika.pl/en/usb... ) and it is on "slow", however, I remember putting it on due to the fact that it did not work on "fast", does any of you know what could be the problem?
Best.
Bravo!!!
TopPages
