Come Join Us (MPLAB Now Supports AVRs)
265 posts / 0 new
Pages
Release Notes for MPLAB® X IDE v5.10
November 2, 2018
13   Repairs and Enhancements in v5.10
MPLABX-3553
CPU registers and IO's memory view windows may need to get refreshed in order to see the values correctly for AVR devices.
AVR devices
MPLABX-3642
AVR devices using TPI for programming are not currently supported.
AVR devices
16   Known Issues
16.5   Device Feature Support Issues
AVR MCU Development
If you are developing with AVR devices, it is recommended that you upgrade to MPLAB X IDE v5.10 and MPLAB XC8 v2.05. Several AVR issues have been addressed in these versions. Alternately, you can use AVR_GCC.
AVR mapped program memory is not viewable on ATmega4808, ATmega4809 devices (MPLABXE-1813)
AVR ATmega4808 and ATmega4809 devices support a feature for efficient access of data used by the application which resides in the flash program space. Currently, MPLAB X IDE will not identify this space as a separate viewable memory.
Workaround: The data is viewable where the data begins in the program memory space.
16.7   IDE Specific Issues
MPLABX-3836
When launching a Debug Wire debug session and the device signature is wrong, the launch is aborted. However, a dialog pops up asking if you want to disable Debug Wire even though you never entered a Debug Wire session.
MPLABX-3832
MPLABX START project import: EDBG selected does not stay selected
MPLABX-3615
The AVR-GCC installed with the Arduino IDE does not work with MPLAB X IDE
AVR devices
MPLABX-3605
Debug Wire protocol on AVR devices does not work for MPLAB PICkit 4. For example, the ATmega328p. Programming uses a different protocol and is fine.
ATmega328p
MPLABX-3595
Memory notification not occurring when notification happens on a config mem change for AVR devices.
AVR devices
MPLABX-3168
AVR Disassembler fails to disassemble MOVW
AVR devices
via MPLAB- X IDE | Microchip Technology
westfw wrote:
To be fair, XC8 is not based on "free software" of any sort.
MPLAB XC8 v2 is based on Clang though likely with HI-TECH's backend.
westfw wrote:
XC16 and XC32 are built on gcc, and instructions for building those (or otherwise removing the optimization restrictions) are widely available.
And instructions on how to unlock it.
There might be a way to unlock MPLAB XC8 v2.
Whether the timing and sizing improvements are significant enough would need some evaluation.
http://ww1.microchip.com/downloads/en/DeviceDoc/Readme_XC8_v200_for_PIC.htm#TOC_Overview
...  and this [C99] has been achieved through the addition of Clang as a new compiler front end application.
Clang C Language Family Frontend for LLVM
Embedded C Compilers and Tools for Software Development: HI-TECH Software
GitHub - cv007/XC3216: GCC compiler restrictions removal
via https://www.microchip.com/forums/FindPost/1050359
in GCC Build | Microchip
Exploring Microchip XC16 compiler | Details | Hackaday.io
by Jaromir Sukuba
01/09/2018
Though the sources are available, in professional circles not everybody will spent their expensive time building the compiler (that is far from being trivial exercise) with nobody to ask questions, so they buy directly the full version plus support from Microchip...
...or something. In fact, I'm able to use optimizations higher than -O1 on free version. Compiler complains I have no valid license, but the code builds and runs just fine, with apparent results of compiler optimization efforts.
[how to]
So, what is described here is option to get full optimization level of XC16 compiler without need to recompile the sources, what is far from being simple task. On the other hand, the gains from full options are not particularly huge, but it doesn't hurt anyway.
Why fight them though? If they don't want you to use their parts, don't use them. There are plenty of others offering free high quality tools.
larryvc wrote:
Does the PICkit4 now make my MPLAB REAL ICE obsolete?
fyi, MPLAB REAL ICE is a mature product and it's on sale this month.
MPLAB REAL ICE In-Circuit Emulator
due to DEVELOPMENT TOOL DEALS microchipDIRECT (bottom)
Wow they really don't want hobbyists playing with their chips!
Dev Tool Deals | Microchip Technology
MPLAB PICkit 4 In-Circuit Debugger (PG164140)
Use Coupon Code: TP1943
20% Off
MPLAB® XC8 C Compiler Version 2.05 Release Notes for AVR® MCU
(pages 6 and 7)
3. What's New
3.1. Version 2.05
[macOS XC8 is a 64-bit application]
[constants into program memory; not applicable for unified memory AVR]
Standard for free Unlicensed (Free) versions of this compiler now allow optimizations up to and including level 2. This will permit a similar, although not identical, output to what was previously possible using a Standard license.
[AVRASM2 bundled with MPLAB XC8 AVR]
(pages 8 and 9)
5. Fixed Issues
5.1. Version 2.05
[numerous]
(pages 9 and 10)
6. Known Issues
[install MPLAB X before installing MPLAB XC8]
[__memx and libgcc float]
[use __at() to specify an address instead of a linker option]
[data initialization by a linker option is not yet implemented]
[a long-term issue of limited function libgcc for reduced architecture tinyAVR]
[relaxation and greater than 128KB program space]
[limitations of named address spaces]
via Downloads tab at MPLAB- XC Compilers | Microchip Technology
AVR® Devices in MPLAB® XC8 v2.05 - Developer Help
edit: last URL
I guess I will be using Atmel Studio 7, and ATmega328Ps and ATmega1284Ps for the rest of my life, along with my $20 Chinese AVR MKII and $50 Atmel ICE, for the rest of my life.  My current 328 project is up to 85% of the available flash, so I am going to have to go to the bigger 1284 soon.  Luckily the device we are building is getting larger too, so there is room for the 40 pin DIP in the prototypes.
I'm still using Visual Studio 2012 for Windows projects, and have found no need to go modern, although I see there is a free version of the latest non-enterprise Visual Studio.  With Windows 7 I am an old guy with a set of tools to do whatever I need at present.  After January next year I guess I will have to pay for Windows 7 updates, or maybe I will just take my code development machine off line, and use it as is until it dies.
MarkThomas wrote:
... along with my $20 Chinese AVR MKII and $50 Atmel ICE, for the rest of my life.
Your life expectancy is much greater than an AVRISP2 or Atmel-ICE.  Occasional posts here on the death of such tools.
Atmel-ICE does have sales at MicrochipDirect and am glad the ones of China create clones of the excellent Atmel AVRISP mkII.
Dean's LUFA AVRISP2 function-like can be built on a breadboard or protoboard for when one is in a pinch; several third parties sell these as a PCBA or in an enclosure.
MarkThomas wrote:
My current 328 project is up to 85% of the available flash, ...
One mega328PB follow-on is mega4808.
MarkThomas wrote:
... so there is room for the 40 pin DIP in the prototypes.
fyi, mega4809 is forthcoming in DIP.
https://www.avrfreaks.net/forum/megaavr-0-series?page=2#comment-2587131
Oops, scratch that.
edits: typo, oops
david.prentice wrote:
And my Tiny817-XMINI works reasonably fast on its mEDBG.
It will be interesting to see how MPLAB compares with AS7.
added 2-Jan'19 :
MPLAB® X IDE - Debugging with Unified Program and Debug Interface (UPDI) for AVR® MCUs - Developer Help
Yes,   I have used MPLABX with the XMINI-Tiny817.      MPLABX works ok with the UPDI hardware but the software is less developed than AS7.
I have been busy with other things.    I should find some time and make more effort with AVR.
Release Notes for MPLAB® X IDE v5.15
February 20, 2019
13   What's New in v5.15
·Improved debugWire experience for AVR MCU family. Use Project Properties dialog, "mEDBG" category, "Communication" options category, "Interface " to select ISP or debugWIRE. MPLAB X IDE sets/clears configuration bits accordingly.
·Support for ATSAM MCUs using the Atmel-ICE tool family (Xplained boards).
14   Repairs and Enhancements in v5.15
MPLABX-3605
17   Known Issues
17.5   Device Feature Support Issues
AVR MCU Development
17.7   IDE Specific Issues
The following are issues for the MPLAB X IDE.
MPLABX-4008
AVR-GCC Toolchain on a mounted drive in Linux does not get discovered with correct version information in MPLAB X IDE.
MPLABX-3991
Const declared variables display incorrect addresses in the watch window for AVR devices
MPLABX-3894
AVR STS instruction displayed incorrectly in multiple MPLAB X IDE displays:
·Program memory view
·Disassembly listing view
·Trace
MPLABX-3871
Using AVR 4809 and XC8 v2.00 the disassembly view seems to get lost when pausing in some projects. PC value is not lost during debugging. Continued debugging refreshes the disassembly view/reopening Disassembly view refreshes the display.
MPLABX-3840
BOOTEND and APPEND configuration values are not in the configuration window
ATmega4809
MPLABX-3839
Error in disassembly of rcall/call AVR instructions
[mega4809]
MPLABX-3836
MPLABX-3832
MPLABX-3725
LDS instruction generated has wrong operands in Disassembly view.
ATmega324PB
MPLABX-3678
On some projects, when first using MPLAB XC8 2.00 in MPLAB X v5.00, the build fails with No Chip name.  The interim fix is to change the compiler drivers manually, under Tools>Options>Embedded>Build Tools>XC8 v2.00, C Compiler = xc8-cc, Assembler = xc8-cc, and then click OK.
8-bit MCUs
MPLABX-3657
Adding Library project for MPLAB XC8 v2.00 changes makefile to search for .hex/.elf in library project dist folder instead of .a file
8-bit MCUs
MPLABX-3615
AVR devices
MPLABX-3595
AVR devices
MPLABX-3168
AVR devices
via MPLAB- X IDE | Microchip Technology (Downloads tab, Release Notes zip, Readme for MPLAB X IDE.htm)
edit: typo
Pages
