Thermocouple amplifier always gives same output
15 posts / 0 new
I have 2 of Adafruit's analog thermocouple amplifiers:
Analog Output K-Type Thermocouple Amplifier - AD8495 Breakout
and 2 thermocouples.
Though I have one in ice water and one in air, they both give me 1.34v. (as close as my meter can show.) Reading them with an A/D on this shamefully non-avr project, they both say 1.6 degrees C. If I disconnect a thermocouple from the amplifier, it reads 39.0 C.
Might this be because my "K type thermocouples" aren't?
The code:
    uint32_t counts = analogRead(Pin)-10;       // seems to be a 10 count offset
    uint32_t mVolts = (counts * 3270) / 4096 ;  // reference measures 3.27v
    uint32_t temp = (mVolts - 1250) / 5 ;                // 5mv / C
Adafruit's formula:
Temperature = (Vout - 1.25) / 0.005 V.
Without adult supervision.
From the data sheet applications section:
The thermometer mode can be particularly useful for debugging
a misbehaving circuit. If the basic connection is not working,
disconnect the thermocouple and short both inputs to ground.
If the system reads the ambient temperature correctly, the
problem is related to the thermocouple. If the system does not
read the ambient temperature correctly, the problem is with
the AD849x or with the downstream circuitry.
The thermometer or measurement mode means that the Sense pin is connected to the Output.
With the input shorted I would expect the thermocouple amplifier output to be that for ambient temperature, whether it is grounded or not.
Stan
If you're having touble then simplify your design to pinpoint it.
Is your amplifier working correctly? do you have errrors in your firmware?
Start by outputting raw ADC values and decide if those make sense. Debug it and and only then add conversion algorithms in steps.
+ and - from the thermocouples swapped?
50K to ground and .1 caps added. microfarads seldom hurt.
That was my first thought.
1. No. 2. Probably.
sbennett: I remember reading that. I'll try. Also, I'll try disconnecting the amplifier output from the uc just to be sure the inputs aren't outputting something at 1.34v.
Interesting: With my meter's temperature probe, my gizmo says I have a temperature of 27C while the meter says 37C, but at least it's not 16C like the food grade probes say everything is.
Consensus is these are J type thermocouples and K type amplifiers.
From the chips datasheet...
...this might suggest something else is going on.
Since the $11 adafruit boards don't come with the AD8494 chip for J type thermocouple, I just layed out a board and ordered some 8494 chips.
Can't seem to find my soldering fry pan. Might have to buy one.
Wonder if I should put in some ferrite beads to keep digital noise out of the power...
Last night, I put the K type thermocouple from my meter on it and... got completely crazy results.
Today, I repeated last night's failed experiment and got completely reasonable results. Even matched a lab thermometer at any temperature between 0 and 100 C I cared to try.
Surprised it does so well with just clip leads as we're dealing with VERY low level signals here.
Yea. I'm relying on that to say, "Hey, dummy, you don't have the probes plugged in."
Using sensor conditioning chips with an analog output seems ... old fashioned to me.
Have a look ad ADS1220, It's also an Ali special with cheap breakout boards.
(Cheap as compared to regular western channels, the chip itself is one of the more expensive little critters)
Also, what is your knowledge level around thermocouples and cold junctions?
Very short: Thermocouples only measure the temperature difference between the ends of the thermocouple wire.
The temperature of the "hot" end is deduced by adding it to the temperature of the "cold" junction compensation.
Your crocodile clamps and audio cinch connectors are not part of the thermocouple wire and if you have a temperature difference over that part of the circuit it can not be corrected for.
That's why you need the connectors close to the chip with its temperature compensation so those extra junctions are at the same temperature. Clip leads don't belong in the real circuit.
Have some J type amplifier chips and made a pc board for them. Need to do some other things before I can try them.
