Assembly Accessing SRAM malfunction
12 posts / 0 new
hey there
a program expected to indicate an LED 100ms/sec , i used Timer 2 with Asynchronous operation. i read this tiny article "AVR134: Real Time Clock (RTC)", then used 22pf capacitors for TOSC1/TOSC2, 32khz crystal, a LED connected to PB1, Fusebits of L:E3  H:D9, chip = Atmega8A
the problem is:
from Emulator every thing is OK.
from physical tests, after startup, LED does not blinking, when some random times passed (20 sec, 40, 100) led starts blinking. after that if i Power OFF - re Power ON the MCU, that beginning delay goes away and LED starts indicating instantly! even i hold MCU without power for about 5 sec's.
TLDR; program uses timer2 with 32 prescaler, CTC mode, OCR=0, Compare math interrupt enabled.
inside the Interrupt sub routine:
A) i divided interrupts with 10(m_hsecdiv), and then 100(m_hsecdiv+1) to stores approximate value for hundredths of seconds
B) i counts 0-1024(m_sec) to detect if a real/accurate second is passed (32768/32 = 1024)
i used data segment to reserve memory locations for holding that counters
LED turned ON when [m_hsecdiv+1] is 90, then turned OFF when [m_sec] is 1024
problem occurred when i used dynamic memory (SRAM) to store counter values (code1no)
(code2yes) is a fix by replacing all data segment parameters with internal Registers, it has no .DSEG   no memory access   no problem   no delay for blinking, every thing starts as expected.
what is my misunderstand of using RAM in assembly format? am i defined segments correctly?
I'm new, please help me.
If it works in the simulator, but not on your hardware, then surely you have a hardware problem?
So, show us your schematic and show us your actual hardware.
added schematic , and actual hardware is Atmega8a-PU mounted on breadboard equal to its schema.
i think it is rare to get hardware problem with internal ram? however its a probability until some one tell me i wrote that short piece of code correctly or not, at least verify its communication with ram via directives & instructions.
Never mind, not related to issue!
Thank you dear jim, i did not enabled them. I left CKOPT, 0 in fuse bits.
Pin 22 should be connected to 0V.
What is your power supply?
[E2A]
I don't see where you are waiting the 1 second required for the external crystal to stabilise.
I tried a loop of 64*65000 with "nop" instruction inside...
But no success. The only change that i found to makes this assembly snippet working, was replacing memory variables with mcu registers, im not sure if i use memory in wrong way.
But an un stabilised crystal will be stabillised during run time? Is it true? I mean it shall not generate freezed state of timer.
And about pin22, forgive me, it was connected. just a mistake in drawing schematic
I didn't look too hard at your code, but I didn't see the memory variables initialised. Should they be set to zero? Maybe the simulator starts with "memory" cleared but the real processor starts with random stuff in memory.
oh my god just at the same time with you i shot my last bullet to solve this problem and set all variables to 0
thanks a lot for reading the code, it was my first time accessing data segment.
clr R16
sts m_hsecdiv , R16
sts m_hsecdiv+1 , R16
sts m_sec , R16
sts m_sec+1 , R16
its that place where simulator show every thing true but in actual test it is not.
but one more thing, without initializing memory... after passing some seconds, the code starts working!!!! and after a power off / power on (fully reset the MCU) the led starts blinking without any delay!
is there any data retention for a short time when no power consumpted? does SRAM uses capacitors to store data?
payam_sbr wrote:
...and after a power off / power on (fully reset the MCU) the led starts blinking!
How are you turning the power on and off?
just unplug battery and plug it back after 4 ~ 5 seconds
I have seen this happen with other processors. Once the processor stops running, there's very little draw on the 100nF capacitor and it may have enough voltage left to maintain memory for a few seconds.
Pleased it's solved. Good fortune with your programming.
