TFT with touch suggestions
9 posts / 0 new
THis is a bit of a new area for me.  I am looking to possibly get away from the LCD Alpha screens and pushbuttons for a possible project and instead go with a TFT/Touch solution.
I have one of these sitting here:
https://www.seeedstudio.io/2.8-T...
and for $20.00 its not a bad choice, but it does not look like it would be very attractive in a case as you can see the connections on the one sire and trying to make a bezel for it would be somewhat expensive.  With the glass I think this would also be rather fragile too.
I was wondering if fellow Freakers that use these things might be able to suggest a favorite of yours.
WHat I am looking for is the following:
SPI interface
MicroSD card slot
2.8 inch minimum size
Rugged glass touchpanel.
Of course easy to use(that definition is an open debate LOL)
It does not need to be an Arduino shield, nor does it need to have an Arduino Library etc....
I plan on connecting this to an AVR8 for this project.
Looking forward to your recommendations
Yes,   the shield is well designed.    It can use the hardware SPI pins on an Arduino.    It seems to have solder-bridges to select SPI pins on STM32 Nucleo, NXP FRDM,   Expressif ESP8266,  ESP32 boards.
It uses an ILI9341 which is a good controller.    It gives dramatic performance when used with DMA.
Of course you can use C, C++ or anything you like.    But Arduino libraries are well supported.   You don't have to use the Seeed library.
Thanks David, but I already knew that......smiley
I was hoping for suggestions based on the criteria I posted in my OP.
I don't see what choice you have.    All TFT panels have a "glass-like" surface.    Ok,  Capacitive Touch panels are slightly different.
Ribbon cables come from underneath the panel.    Most shields or boards offer pin headers     Your wiring is out of view.    A bezel is difficult.   It must not press against the active area of the Touch panel.
Do you want wires to come out of the top of the screen?
The Red 3.3V SPI displays are cheap and popular.    Of course they require level shifters if you are obsessed with 5V GPIO.
Thanks David,
Then for the sake of conversation, what are these test machines using for displays?  My Anritsu Sitemaster and The Spectrum analyser have 8 inch touchscreens that are pretty damn tough.  And for that matter what about the touchscreens on cellular telephones?
https://en.wikipedia.org/wiki/Gorilla_Glass
Suitable for capacitive touch screens.  The screen you linked to in your OP employs a resistive touch screen, which usually has a flexible outer layer.
Thanks Joey,
My quest for a simple to use TFT with touch continues.....
I have used these before:
https://www.itead.cc/display.html
They are USART comms based and you do the graphics, buttons etc in another software package which is pretty easy to use, but they take forever to order/deliver at times.  Prices have come down though so might not be a bad idea for a one off, but this does not do me any favors for my education now does is? wink
Heres the rub,
I want to be able to display ADC values on the screen with the backgrounds from teh SD card
The magic word for the diplays you mentioned in #7 is: "nextion", and they are sold by itead, seeed studio and the usual Ali / Ebay / Chinese resellers.
For ruggedness milling a hole in an aluminimum box and then simply pooring glue around the edges from the inside seems the simplest solution.
All of the TFT breakout boards I've seen also have a uSD connector on the back, and if it doesn't you can always add your own, or some dataflash chip.
My own experiences with TFT displays is quite limited.
I run some demo's of Adafruit and of UTFT, then decided AVR's were too slow which started a foggy maze around STM32.
For small TFT displays the search is usually for the controller chip that is supported by the library you want to use.
The ILI93xx or ILI91xx seem to be popular and well supported.
The datasheets of these are quite ... extensive. (240 pages)
http://newhavendisplay.com/app_notes/ILI9341.pdf
(some of) those ILI displays support an 8 or 16 bit's databus, but also SPI and I believe it is done by pulling some configuration pin high or low.
With a pin pitch of 40 micrometer and the chip glued to glass it would be quite a challenge to change that, which means you are stuck with the signals accesible through the flex cable.
The ST7735 displays also have an SPI interface, and I've read several posts of people prefering these above the ILI displays.
AVR is a bit slow for these displays, and platforms such as mbed & 32 bit processors or anything with hadware SPI with DMA seem a better fit.
Any MBED library is probably pretty easy to port to 8-bit AVR, as long as it is written in C / C++.
I've dabbled a bit with the source code of Rinkydink's UTFT, and it takes some time (an afternoon or so) to get the hang of it, but I think the way they have sovled making the lib compatible with different display controllers quite usable.
Initialisation of these displays consists of writing some 30 odd bytes to them. It does things as, defining how many colors you want to use (monochrome, 8-bit, 16 bit in 565 (RGB) fromat or other. Settings for gamma correction, display resolution and rotation ( The ILI chips rotate your data in hardware!)
UTFT is build up in a few layers.
In the bottom layer you talk to the hardware, whether SPI, or an 8 or 16 bit databus.
Above that you have a layer with hardware specific routines. Stuff like initializing the displays, setting a window and tricks for writing horizontal lines.
If you write a horizontal line from a databus which has the same widht as your colors then you can simply output the data once, and toggle the write pin for each pixel.
This can be a real time saver to speed up the display (espaecially on a lowly AVR), but this trick does not work over SPI. (Add a 20ct 74HC595 shift register?)
I've also posted the output of: "pio lib search tft" which gives many more results than I expected, but it does give an overview of "what's out there".
You can do a text search to refine the results in the direction you want.
paul@dualcore:~$ pio lib search tft
Found 183 libraries:
TFT_eSPI
#ID: 1559
A TFT and ePaper SPI graphics library for ESP8266 and ESP32
Keywords: tft, epaper, display, esp8266, nodemcu, esp32, m5stack, ili9341, st7735, ili9163, s6d02a1, ili9486, st7789
Compatible frameworks: Arduino
Compatible platforms: Espressif 32, Espressif 8266
Authors: Bodmer
DisplayCore
#ID: 1024
DisplayCore for DisplayCore
Keywords: display, displaycore, tft, lcd, glcd, oled, graphics, font
Compatible platforms: Microchip PIC32
Authors: Majenko Technologies
SSD1306
#ID: 1134
SSD1306 for DisplayCore
Adafruit-TFT-LCD
#ID: 32
Arduino library for 8-bit TFT LCDs such as ILI9325, ILI9328, etc
Keywords: display, tft, graphics, lcd, spi
Compatible platforms: Atmel AVR, Atmel SAM, Espressif 32, Espressif 8266, Intel ARC32, Microchip PIC32, Nordic nRF51, Nordic nRF52, ST STM32, Teensy, TI MSP430
Authors: Adafruit Industries
XPT2046_Touchscreen
#ID: 542
Touchscreens using the XPT2046 controller chip. Many very low cost color TFT displays with touch screens have this chip.
Keywords: display, tft, lcd, graphics, spi, touchscreen
Authors: Paul Stoffregen
MCUFRIEND_kbv
#ID: 1426
TFT Library for 2.4, 2.8, 3.5, 3.6, 3.95 inch mcufriend UNO Shields
Keywords: display
Authors: David Prentice
ILI9341_t3
#ID: 540
Optimized ILI9341 (320x240 Color TFT) Display
Authors: Limor Fried, Paul Stoffregen
Ucglib
#ID: 943
True color TFT and OLED library, Up to 18 Bit color depth. Supported display controller: ST7735, ILI9163, ILI9325, ILI9341, ILI9486,LD50T6160, PCF8833, SEPS225, SSD1331, SSD1351, HX8352C.
Keywords: display
Authors: oliver
Mini Grafx
#ID: 1670
A generic graphics library containing several drivers for TFT, OLED and e-paper displays
Keywords: embedded, graphics, tft, oled, e-paper
Authors: Daniel Eichhorn
TFT
#ID: 886
Allows drawing text, images, and shapes on the Arduino TFT graphical display.
Keywords: display
Authors: Arduino, Adafruit
Adafruit_GFX
#ID: 2147
A first port of the excellent Adafruit GFX library
Keywords: adafruit, gfx, lcd, tft
Compatible frameworks: mbed
Compatible platforms: Atmel SAM, Freescale Kinetis, Maxim Integrated MAX32, Nordic nRF51, Nordic nRF52, NXP LPC, Silicon Labs EFM32, ST STM32, Teensy, WIZNet W7500
Authors: Andrew Lindsay
Adafruit_ST7735
#ID: 2150
A first port of the excellent Adafruit ST7735 library
Keywords: adafruit, lcd, st7735, tft
TFT_ILI9163
#ID: 546
A fast SPI driver for TFT drived by ILI9163C, fully SPI Transaction compatible and very fast with Teensy 3
Keywords: display, tft, graphics, spi
Compatible platforms: Atmel AVR, Atmel SAM, Teensy
Authors: max mc costa
Adafruit_ILI9341
#ID: 2148
Port of the Adafruit_ILI9341 library for MBED. Depends on BurstSPI. fillRect, drawFastVLine, drawFastHLine are optimized to use BurstSPI fastwrites and perform a clearRX afterwards. MIT license Due to 600 character ...
Keywords: ili9341, tft
Authors: James Kidd
TFT 22 ILI9225
#ID: 1616
Arduino driver for the ILI9225 based TFT with SPI Interface
Keywords: tft, ili9225
Authors: Nkawu
TFTLCD
#ID: 2787
This is a port of Henning Kralsen's UTFT library for Arduino/chipKIT to mbed, refactored to make full use of C++ inheritance and access control, in order to reduce work when ...
Keywords: hx8340, ili9325, ili9328, itdb02, lcd, ssd1289, st7735, tft, utft
Authors: Todor Todorov
HX8347D
#ID: 1151
HX8347D for DisplayCore
ILI9341
#ID: 88
Seeed ILI9341 2.2 TFT+SD library
Compatible frameworks: Energia
Compatible platforms: TI MSP430
Authors: Radoslav Malinov
UniGraphic
#ID: 2819
Basically i glued Peter Drescher and Simon Ford libs in a GraphicsDisplay class, then derived TFT or LCD class (which inherits Protocols class), then the most derived ones (Inits), which ...
Keywords: ili9320, ili9325, ili9328, ili9341, ili9481, ili9486, ist3020, lcd, mipi, parallel, spi, ssd1306, st7565, tft, uc1608, uc1701
Authors: GraphicsDisplay
SSD1963
#ID: 1157
SSD1963 for DisplayCore
ILI9341_fonts
#ID: 541
Extra fonts for use with ILI9341_t3
Keywords: display, tft, lcd, graphics, font
Compatible frameworks: Arduino, ARTIK SDK, CMSIS, Energia, ESP8266 Non-OS SDK, ESP8266 RTOS SDK, ESP-IDF, Freedom E SDK, libOpenCM3, mbed, PULP OS, Pumbaa, Simba, SPL, STM32Cube, Tizen RT, WiringPi
Compatible platforms: Atmel AVR, Atmel SAM, Espressif 32, Espressif 8266, Freescale Kinetis, Intel ARC32, Linux ARM, Maxim Integrated MAX32, Microchip PIC32, Nordic nRF51, Nordic nRF52, NXP LPC, Samsung ARTIK, Silicon Labs EFM32, ST STM32, Teensy, TI MSP430, TI Tiva, WIZNet W7500
SPFD5408 TFT Library
#ID: 2017
TFT library for SPFD5408
Keywords: display
Authors: Sadika Sumanapala
SSD_13XX
#ID: 967
A fast full featured SPI driver for TFT drived by SSD_13XX, fully SPI Transaction compatible and Fast.
Keywords: display
Authors: Max MC Costa, sumotoy
XPT2046
#ID: 1148
XPT2046 for DisplayCore
TFT_ST7735
#ID: 966
A fast full featured SPI driver for TFT drived by TFT_ST7735, fully SPI Transaction compatible and Fast.
Keywords: display
ILI9481
#ID: 1155
ILI9481 for DisplayCore
Adafruit RA8875
#ID: 458
Adafruit's Arduino driver for the RA8875 TFT driver
Keywords: display
Authors: Adafruit
TFT_ILI9341
#ID: 5518
A fast TFT library for Arduino AVR processors (UNO, Mega, Leonardo, Pro Mini etc)
Keywords: display
Authors: Bodmer
Filters
#ID: 1130
Filters for DisplayCore
ST7735
#ID: 1142
ST7735 for DisplayCore
ILI9341
#ID: 1139
ILI9341 for DisplayCore
ILI9341_esp
#ID: 5371
Optimized ILI9341 (320x240 Color TFT) Display Support different SPI buses
Keywords: display
Authors: Limor Fried, Adafruit, Paul Stoffregen, Kurt Eckhardt
ILI9163
#ID: 1140
ILI9163 for DisplayCore
SPI_TFT
#ID: 242
Library to control a QVGA TFT connected to SPI. You can use printf to print text The lib can handle different fonts, draw lines, circles, rect and bmp
Keywords: display, graphic, lcd, qvga, tft
Authors: Peter Drescher
TFT_ILI93XX
#ID: 970
A fast full featured SPI driver for TFT drived by ILI93XX, fully SPI Transaction compatible and Fast.
Keywords: display
TFT_fonts
#ID: 284
Font to use with the SPI_TFT lib
Keywords: fonts, tft
KS0108
#ID: 1132
KS0108 for DisplayCore
TFT_ST7735
#ID: 2984
Keywords: display
Authors: Bodmer
TFT_Touch
#ID: 5461
A TFT touch screen library for Arduino AVR processors (UNO, Mega, Leonardo, Pro Mini etc)
Keywords: display
Authors: Bodmer
TFT Touch Shield V1.0
#ID: 5364
Arduino library to control 2.8 inch TFT Touch Shield v1.0.
Keywords: display
Authors: Seeed Studio
TFT Touch Shield v2.0
#ID: 5253
Arduino library to control 2.8 inch TFT Touch Shield v2.0.
Keywords: display
TFT_ILI9341_ESP
#ID: 5691
A TFT ILI9341 SPI graphics library for ESP8266
Keywords: ili9341, esp8266, tft
Compatible platforms: Espressif 8266
Authors: Bodmer, Adafruit
FT800
#ID: 2324
Lib for FTDI FT800 Graphic Controller EVE Support up to 512 x 512 pixel resolution. Resistive touch sense Mono audio output SPI Interface
Keywords: graphic, tft, touch
TFT
#ID: 4890
Library to support using the 2.8" TFT Touch Shield v1.0 - made by Seeed Studio - for Arduino This shield uses either the SPFD5408A or ST7781R display chip.
Keywords: frdm, kl25z, mlk25z128frdm
Authors: TJ Forshee
ST7735_TFT
#ID: 2740
This is a mbed library for a 1.8 inch 128x160 pixel SPI TFT display
Keywords: 1.8, spi, tft
Authors: Jonne Valola
AdafruitST77735
#ID: 3130
tft controler
Keywords: adafruitst77735
Authors: david baird
ILI9225_SPI_TFT
#ID: 3785
Library to drive an ILI9225 2.2" SPI TFT.
Keywords: ili9225, lcd, spi
Authors: Arman Safikhani
ILI9325
#ID: 1143
ILI9325 for DisplayCore
S6D0154
#ID: 1145
S6D0154 for DisplayCore
TFT_HX8357_Due
#ID: 2903
A fast TFT library with fonts for the Arduino Due
Keywords: display
Authors: Bodmer
EmbedMenu
#ID: 5806
Simple, generic menu system usable with any displays.
Keywords: menu, display, lcd, tft, buttons, encoder, io, control
Authors: Jocelyn Girard
SPI_TFT_ILI9320
#ID: 5244
SPI Library for 240x320 TFT LCD with ILI9320, ILI9325 and ILI9328 chip
Keywords: ili9320, lcd, spi, tft
Authors: Frank Vannieuwkerke
LCD_DISCO_F769NI
#ID: 3047
This class drives the LCD display (4-inch 800x472 LCD-TFT) present on STM32F769I-DISCO board
Keywords: lcd_disco_f769ni
Authors: ST
BMP
#ID: 1025
BMP for DisplayCore
ILI9342
#ID: 1137
ILI9342 for DisplayCore
SSD1289
#ID: 1158
SSD1289 for DisplayCore
Adafruit HX8340B
#ID: 464
Adafruit 2.2" TFT with SPI interface and microSD card holder
Keywords: display
Authors: Adafruit
Touch_tft
#ID: 2800
LIB for resistiv touchscreen connected to 4 mbed pins Use SPI_TFT lib
Keywords: tft, touchscreen
ILI9341_Graphic_Library
#ID: 3767
Wrapped version of the ILI9341 graphics library with some MBED tweaks
Keywords: ili9341_graphic_library
Authors: Justin Howard
Squircle
#ID: 1041
Squircle for DisplayCore
Sinclair
#ID: 1048
Sinclair for DisplayCore
Ubuntu
#ID: 1111
Ubuntu for DisplayCore
SDL
#ID: 1133
SDL for DisplayCore
FT6206
#ID: 3637
FT6206 Library for Adafruit 2.8" TFT Touch Shield for Arduino w/Capacitive Touch
Keywords: ft6206, touch
Authors: Jack Berkhout
littlevgl
#ID: 5992
Graphics library to create embedded GUI with easy-to-use graphical elements, beautiful visual effects and low memory footprint. Anti-aliasing, opacity, animations using only one frame buffer.
Keywords: gui, graphic, graphics library, tft, lcd, display
Authors: Littlev Graphics Library
HY-1_8TFT_ST7735_KL25Z
#ID: 3725
Chinese module, HY-1.8 SPI TFT LCD Display library, modified library from Jonne Valola to work on the FRDM-KL25Z using 8 bit format.
Keywords: hy-1.8, st7735
Authors: Paul Staron
JPEG
#ID: 1027
JPEG for DisplayCore
Topaz
#ID: 1070
Topaz for DisplayCore
Ecqlipse32
#ID: 1122
Ecqlipse32 for DisplayCore
ILI9340
#ID: 1135
ILI9340 for DisplayCore
LedMatrixDim
#ID: 1020
LedMatrixDim for DisplayCore
LCARSInterface
#ID: 1023
LCARSInterface for DisplayCore
BinaryVector
#ID: 1026
BinaryVector for DisplayCore
Raw565
#ID: 1028
Raw565 for DisplayCore
BMPFile
#ID: 1029
BMPFile for DisplayCore
Kimberley
#ID: 1031
Kimberley for DisplayCore
Aquarius
#ID: 1049
Aquarius for DisplayCore
Unicode
#ID: 1052
Unicode for DisplayCore
BunnyMambo
#ID: 1066
BunnyMambo for DisplayCore
Display7Seg
#ID: 1110
Display7Seg for DisplayCore
VGA8x16
#ID: 1119
VGA8x16 for DisplayCore
Arial
#ID: 1123
Arial for DisplayCore
VGA
#ID: 1136
VGA for DisplayCore
Picadillo
#ID: 1147
Picadillo for DisplayCore
AnalogTouch
#ID: 1149
AnalogTouch for DisplayCore
Framebuffer332
#ID: 1150
Framebuffer332 for DisplayCore
BD663474
#ID: 1152
BD663474 for DisplayCore
Goldelox
#ID: 1156
Goldelox for DisplayCore
Adafruit_358
#ID: 2309
This library can be used to control a low-cost Adafruit 358 TFT display. It has basic functionality but is a starting point for others trying to control this type of ...
Keywords: 358, adafruit, tft
Authors: FRDM-K64F Code Share
MenusLCD
#ID: 2522
Menus LCD TFT
Keywords: lcd, menus, tft
Authors: Ale C.-
S1D13781Shield_Gfx
#ID: 4576
S1D13781 Shield Graphics Library for mbed (requires modified S1D13781 Shield TFT board)
Keywords: lcdc, s1d13781, shield, tft
Authors: Dennis Henderson
Widgets
#ID: 1022
Widgets for DisplayCore
Linux6x10
#ID: 1035
Linux6x10 for DisplayCore
ArialBold
#ID: 1038
ArialBold for DisplayCore
LCDish
#ID: 1039
LCDish for DisplayCore
Liberation
#ID: 1040
Liberation for DisplayCore
Gem
#ID: 1042
Gem for DisplayCore
SheepSans
#ID: 1043
SheepSans for DisplayCore
ProFont6x11
#ID: 1046
ProFont6x11 for DisplayCore
Doorly
#ID: 1050
Doorly for DisplayCore
ComfortAA
#ID: 1055
ComfortAA for DisplayCore
LCARS
#ID: 1056
LCARS for DisplayCore
Open24Display
#ID: 1057
Open24Display for DisplayCore
Hazard
#ID: 1058
Hazard for DisplayCore
OldStandard
#ID: 1063
OldStandard for DisplayCore
Display7SegShadow
#ID: 1064
Display7SegShadow for DisplayCore
Roboto
#ID: 1068
Roboto for DisplayCore
DejaVuSansMono
#ID: 1077
DejaVuSansMono for DisplayCore
AVOP
#ID: 1081
AVOP for DisplayCore
CP851
#ID: 1082
CP851 for DisplayCore
RawGold
#ID: 1083
RawGold for DisplayCore
CP112
#ID: 1086
CP112 for DisplayCore
BPMonoItalic
#ID: 1088
BPMonoItalic for DisplayCore
CP852
#ID: 1096
CP852 for DisplayCore
XTerm
#ID: 1107
XTerm for DisplayCore
Icon8
#ID: 1117
Icon8 for DisplayCore
LedMatrixBright
#ID: 1118
LedMatrixBright for DisplayCore
Ecqlipse48
#ID: 1121
Ecqlipse48 for DisplayCore
Tutorial9Mono
#ID: 1124
Tutorial9Mono for DisplayCore
Gentleface32
#ID: 1125
Gentleface32 for DisplayCore
Brankic
#ID: 1126
Brankic for DisplayCore
Iconic
#ID: 1127
Iconic for DisplayCore
PICOL
#ID: 1128
PICOL for DisplayCore
Gentleface48
#ID: 1129
Gentleface48 for DisplayCore
LM6800
#ID: 1141
LM6800 for DisplayCore
Framebuffer565
#ID: 1154
Framebuffer565 for DisplayCore
gciWidget
#ID: 1159
gciWidget for DisplayCore
Font44
#ID: 1036
Font44 for DisplayCore
Bisasam
#ID: 1113
Bisasam for DisplayCore
ILI9340_Driver_Lib
#ID: 2400
V1.1 of the ILI9340 driver for SPI with integrated graphics functions.
Keywords: driver, graphics, ili9340, lcd, spi, tft
Authors: Ian Weston
SH_MLCD_J
#ID: 4658
秋月電子などで販売されているSHARP製HR-TFTモノクロメモリ液晶を、直接駆動するためのライブラリです。 図形、文字列の描画が可能です。 日本語のフォントも内包していますが、FlashサイズやRAMサイズが小さいものだと扱いきれないかもしれません。 既存のライブラリとは違い、貴重なSPIポートを占拠しません。DigitalOut端子3本でSPIモドキを実現しています。 結線方法については、デモプログラムのページをご参照ください。
Keywords: hr-tft, memory lcd, monochrome lcd, sharp
Authors: Ryota Yamamoto
TFT_TouchPanel
#ID: 4891
Touch panel driver library for the TFT color display MI0283QT-9A.
Keywords: mi0283qt-9a, panel, resistive, touch, touchscreen
Authors: Mario Poneder
SX032QVGA008
#ID: 5261
aitendo SX032QVGA008
Keywords: aitendo, ili9341, spi, tft
Authors: Imayan chan
AitendoTFT
#ID: 3157
Library for Aitendo 2.6 inch TFT shield for Arduino-UNO and Nucleo
Keywords: tft
Authors: Hiroshi Narimatsu
LCDTFT
#ID: 2441
LCD TFT
Keywords: lcd, tft
Authors: Ale C.-
SPI_TFT_old
#ID: 2730
GLCD_MCB1700
#ID: 3661
display control QVGA TFT MCB1700 KEIL
Keywords: keil, mcb1700, qvga, tft
Authors: frederic blanc
MonoIcon
#ID: 1021
MonoIcon for DisplayCore
CP853
#ID: 1030
CP853 for DisplayCore
CP884
#ID: 1032
CP884 for DisplayCore
CP861
#ID: 1033
CP861 for DisplayCore
CP113
#ID: 1034
CP113 for DisplayCore
CP111
#ID: 1037
CP111 for DisplayCore
CP862
#ID: 1044
CP862 for DisplayCore
DOS
#ID: 1045
DOS for DisplayCore
CP850
#ID: 1047
CP850 for DisplayCore
Ingot
#ID: 1051
Ingot for DisplayCore
Comic
#ID: 1053
Comic for DisplayCore
SUN8x16
#ID: 1054
SUN8x16 for DisplayCore
CP866
#ID: 1059
CP866 for DisplayCore
PEARL8x8
#ID: 1060
PEARL8x8 for DisplayCore
SUN12x22
#ID: 1061
SUN12x22 for DisplayCore
CP881
#ID: 1062
CP881 for DisplayCore
EngliBesh
#ID: 1065
EngliBesh for DisplayCore
GeorgiaBoldItalic
#ID: 1067
GeorgiaBoldItalic for DisplayCore
CP883
#ID: 1069
CP883 for DisplayCore
Acorn8x8
#ID: 1071
Acorn8x8 for DisplayCore
CP863
#ID: 1072
CP863 for DisplayCore
OCRAExtended
#ID: 1073
OCRAExtended for DisplayCore
Linux10x18
#ID: 1074
Linux10x18 for DisplayCore
VGA8x8
#ID: 1075
VGA8x8 for DisplayCore
Linux7x14
#ID: 1076
Linux7x14 for DisplayCore
CP885
#ID: 1078
CP885 for DisplayCore
CP864
#ID: 1079
CP864 for DisplayCore
CP437
#ID: 1080
CP437 for DisplayCore
Terminus6x12
#ID: 1085
Terminus6x12 for DisplayCore
DejaVuSans
#ID: 1087
DejaVuSans for DisplayCore
CP865
#ID: 1097
CP865 for DisplayCore
CP882
#ID: 1098
CP882 for DisplayCore
Atari
#ID: 1108
Atari for DisplayCore
Carbine
#ID: 1109
Carbine for DisplayCore
CP737
#ID: 1112
CP737 for DisplayCore
AtariButtons
#ID: 1114
AtariButtons for DisplayCore
MINI4x6
#ID: 1115
MINI4x6 for DisplayCore
Acorn
#ID: 1116
Acorn for DisplayCore
CP860
#ID: 1120
CP860 for DisplayCore
Diablo16
#ID: 1131
Diablo16 for DisplayCore
PG25664CG
#ID: 1138
PG25664CG for DisplayCore
VLCD
#ID: 1144
VLCD for DisplayCore
LinuxEvent
#ID: 1146
LinuxEvent for DisplayCore
NativeFB
#ID: 1153
NativeFB for DisplayCore
CP880
#ID: 1084
CP880 for DisplayCore
TFT_eFX
#ID: 6038
A TFT extensiom graphics library for TFT_eSPI
Keywords: display
Authors: Bodmer
Have a look at the phone repair buiziness.
The front of these are made out of several layers of glass glued on top of each other.
If the front glass is broken, but the TFT behind it is still good there are probably local shops who can replace the glass within a few hours or days.
I believe the broken glass is removed by heating up the display which makes the glue soft and the new glass is glued with UV curable transparent glue.
In the links below I see stuff sold in sheets and stuff in tubes.
https://www.aliexpress.com/wholesale?SearchText=optical+clear+glue+mobile+phone
From Youtube vid's I've seen it seems doable to do something yourself, but you will need to invest a bit in equipment and do some practising.
But it does open the way to making beautifull front panels.
You can glue a small TFT on a bigger sheet of glass and use the extra room for  touch buttons.
I once held a repair glass sheet in my hand in a local shop.
It seemed that it was flexible enough that you could at least bend it 90 degrees, or maybe even for 2 opposite cornes to touch, but I did not want to risk damaging it and put it back on it's hook in the shop. I did not want to spend EUR 15 just to try this.
Modern glass is not the brittle stuff it used to be in the old days.
