Blinking leds
38 posts / 0 new
After playing around with avr's for quite some time (The first I bought was a at90s1200) I'm almost ashamed that I can't get my blinking led project working anymore.
The code should be pretty straight forward:
#define F_CPU 1000000UL
#include
#include
	_delay_ms(200);
	DDRB = 0xff;
	DDRD = 0xff;
	for(;;)
		PORTB = 0xff;
		PORTD = 0xff;
		_delay_ms(200);
		PORTB = 0;
		PORTD = 0;
		_delay_ms(200);
And most of the leds on ports B and D are blinking on the 5 different ATMEGA8's I've tried. (2 of them new out of the box). Different ATMEGA8's generate different led patterns. On one AVR PB1 was not blinking, on another PB2 was not blinking and on yet anoter PB1, 2, 3 and PB6 were not blinking. Same random patterns on PORTD. Each AVR seem to have a preference for a certain pattern, but sometimes the pattern changes (or temporarily dissapears) if the power is cycled.
After 3 whole days of breaking my head on this I have even eliminated most options from my makefile. Below is the complete output of a programming cycle after "make clean".
paul@dualcore ~/projects/avr/lib/main-wanhope-2013-02-21 $ avr-gcc --version
avr-gcc (GCC) 4.5.3
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
paul@dualcore ~/projects/avr/lib/main-wanhope-2013-02-21 $ make program
avr-gcc -c -mmcu=atmega8 -g -Os -Wall main.c
avr-gcc  main.o -o main.elf
avr-objdump -h -S main.elf > main.lst
avr-size main.elf
   text	   data	    bss	    dec	    hex	filename
     52	      0	      0	     52	     34	main.elf
avr-objcopy -j .text -j .data -j .bss -O ihex main.elf main.hex
avrdude -p atmega8 -c usbasp -ye -B20 -U flash:w:main.hex:i
avrdude: set SCK frequency to 32000 Hz
avrdude: Device signature = 0x1e9307
avrdude: erasing chip
avrdude: erase-rewrite cycle count is now 14
avrdude: reading input file "main.hex"
avrdude: writing flash (52 bytes):
Writing | ################################################## | 100% 0.19s
avrdude: 52 bytes of flash written
avrdude: verifying flash memory against main.hex:
avrdude: load data flash data from input file main.hex:
avrdude: input file main.hex contains 52 bytes
Reading | ################################################## | 100% 0.12s
avrdude: verifying ...
avrdude: 52 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
I'm pretty convinced this problem has nothing to do with software, but a brand new ATMEGA8 which runs on the internal 1MHz clock also has the same problem. (With pullup on reset and decoupling caps etc.)
I've also tried 3 different programmers (2 USBasp's and one old STK500V2 based one) All programmers work, I can change the blink rate, but I can't get all leds to blink. Also tried different power supplies.
The only consistency I can find is that if a led is not blinking it's always on. It only goes off during reset.
Does anybody have any ideas about this? I'm empty.
main.elf:     file format elf32-avr
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .text         00000034  00000000  00000000  00000054  2**1
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .stab         000003d8  00000000  00000000  00000088  2**2
                  CONTENTS, READONLY, DEBUGGING
  2 .stabstr      0000076f  00000000  00000000  00000460  2**0
Disassembly of section .text:
00000000
: #else //round up by default __ticks_dc = (uint32_t)(ceil(fabs(__tmp))); #endif __builtin_avr_delay_cycles(__ticks_dc); 0: 8f e4 ldi r24, 0x4F ; 79 2: 93 ec ldi r25, 0xC3 ; 195 4: 01 97 sbiw r24, 0x01 ; 1 6: f1 f7 brne .-4 ; 0x4 <__zero_reg__+0x3> 8: 00 c0 rjmp .+0 ; 0xa <__zero_reg__+0x9> a: 00 00 nop int main(void) { _delay_ms(200); DDRB = 0xff; c: 8f ef ldi r24, 0xFF ; 255 e: 87 bb out 0x17, r24 ; 23 DDRD = 0xff; 10: 81 bb out 0x11, r24 ; 17 for(;;) { PORTB = 0xff; 12: 88 bb out 0x18, r24 ; 24 PORTD = 0xff; 14: 82 bb out 0x12, r24 ; 18 16: ef e4 ldi r30, 0x4F ; 79 18: f3 ec ldi r31, 0xC3 ; 195 1a: 31 97 sbiw r30, 0x01 ; 1 1c: f1 f7 brne .-4 ; 0x1a <__zero_reg__+0x19> 1e: 00 c0 rjmp .+0 ; 0x20 <__zero_reg__+0x1f> 20: 00 00 nop _delay_ms(200); PORTB = 0; 22: 18 ba out 0x18, r1 ; 24 PORTD = 0; 24: 12 ba out 0x12, r1 ; 18 26: ef e4 ldi r30, 0x4F ; 79 28: f3 ec ldi r31, 0xC3 ; 195 2a: 31 97 sbiw r30, 0x01 ; 1 2c: f1 f7 brne .-4 ; 0x2a <__zero_reg__+0x29> 2e: 00 c0 rjmp .+0 ; 0x30 <__zero_reg__+0x2f> 30: 00 00 nop 32: ef cf rjmp .-34 ; 0x12 <__zero_reg__+0x11>
Are you compiling for the right chip ?
Are you uploading the correct executable to the chip ?
What does your circuit look like ?
Sid
Life... is a state of mind
With 40+ projects with AVRs under your belt I'm embarrassed to ask you if you have resistors in series with the LEDs but I'll ask anyway. :-)
And to reedem myself for asking a stupid question I just ran your code on the STK500 with a M8 and all is well. :-)
The code size doesn't match yours, it's 102 bytes.
Are ALL power supply pins (VCC, AVCC, GND) properly connected?
Thanks for the help.
I rechecked all above, but I can't find the fault.
I suspect the error is not in the code.
Just to make sure I don't have a faulty batch of atmega8's I took a atmega328p, recompiled, and programmed it. All 11 connected leds were blinking, but after cycling the power a few times (plug with ground loop for scope etc. on the left) 7 of the leds stopped blinking and only turned of during a reset.
All leds are driven via 2 ULN2803 buffers and current limiting resistors. double checked all 4 power pins with a multimeter. There are also plenty of decoupling caps (also a few smd's on the little green adapter pcb's).
Difference in code size is remarkable. Recompile for atmega328p also is 52 bytes for me with avr-gcc4.5.3. Codesize will change with compiler options and the size of the 3 _delay_ms() macro's also change with F_CPU. According to my list file the whole stack is optimized away in my case.
Because the program in the atmega328p worked first time and only broke after the power was cycled a few times it does seem more like a hardware problem.
Powersupply has 5.05V when not connected and 4.98V when loaded by the breadboard. Because of the 470uF buffer cap I see a 7ms risetime on my scope without any overshoot.
I also believe ESD problems are unlikely. The atmega328p worked after first insertion and I didn't remove it from the breadboard afterwards.
-mmcu option is missing on the linking command line.
Stefan Ernst
So it looks like you are not using Studio at all?
John! This
is the giveaway that he is on some kind of Unix/Linux system. (user 'paul' on machine named 'dualcore', current directory is "home"/projects/avr/lib/main-wanhope-2013-02-21 .)
Hi all,
I have the exact same issue. I cannot get my LEDs flashing. Paul's video link obviously expired, adding mmcu to the linker does not help, and setting register r1 to zero in assembly does not solve the problem either.
Here is my make file:
MCU   = atmega16
F_CPU = 16000000UL
BAUD  = 9600UL
LIBDIR = lib
PROGRAMMER_TYPE = avrispmkII
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
AVRSIZE = avr-size
AVRDUDE = avrdude
TARGET = blinkLED
SOURCES=$(wildcard *.c $(LIBDIR)/*.c)
OBJECTS=$(SOURCES:.c=.o)
HEADERS=$(SOURCES:.c=.h)
CPPFLAGS = -DF_CPU=$(F_CPU) -DBAUD=$(BAUD) -I. -I$(LIBDIR)
CFLAGS = -Os -g -std=gnu99 -Wall
CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -ffunction-sections -fdata-sections
LDFLAGS = -Wl,-Map,$(TARGET).map
LDFLAGS += -Wl,--gc-sections
TARGET_ARCH = -mmcu=$(MCU)
%.o: %.c $(HEADERS) Makefile
     $(CC) $(CFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c -o $@ $<;
$(TARGET).elf: $(OBJECTS)
    $(CC) $(LDFLAGS) $(TARGET_ARCH) $^ $(LDLIBS) -o $@
%.hex: %.elf
     $(OBJCOPY) -j .text -j .data -O ihex $< $@
%.eeprom: %.elf
    $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@
%.lst: %.elf
    $(OBJDUMP) -S $< > $@
.PHONY: all disassemble disasm eeprom size clean squeaky_clean flash fuses
all: $(TARGET).hex
debug:
    @echo
    @echo "Source files:"   $(SOURCES)
    @echo "MCU, F_CPU, BAUD:"  $(MCU), $(F_CPU), $(BAUD)
    @echo
disassemble: $(TARGET).lst
disasm: disassemble
    $(AVRSIZE) -C --mcu=$(MCU) $(TARGET).elf
clean:
    rm -f $(TARGET).elf $(TARGET).hex $(TARGET).obj \
    $(TARGET).o $(TARGET).d $(TARGET).eep $(TARGET).lst \
    $(TARGET).lss $(TARGET).sym $(TARGET).map $(TARGET)~ \
    $(TARGET).eeprom
squeaky_clean:
    rm -f *.elf *.hex *.obj *.o *.d *.eep *.lst *.lss *.sym *.map *~ *.eeprom
flash: $(TARGET).hex
    $(AVRDUDE) -c $(PROGRAMMER_TYPE) -p $(MCU) $(PROGRAMMER_ARGS) -U flash:w:$<
program: flash
flash_eeprom: $(TARGET).eeprom
    $(AVRDUDE) -c $(PROGRAMMER_TYPE) -p $(MCU) $(PROGRAMMER_ARGS) -U eeprom:w:$<
avrdude_terminal:
    $(AVRDUDE) -c $(PROGRAMMER_TYPE) -p $(MCU) $(PROGRAMMER_ARGS) -nt
flash_usbtiny: PROGRAMMER_TYPE = usbtiny
flash_usbtiny: PROGRAMMER_ARGS =  # USBTiny works with no further arguments
flash_usbtiny: flash
flash_usbasp: PROGRAMMER_TYPE = usbasp
flash_usbasp: PROGRAMMER_ARGS =  # USBasp works with no further arguments
flash_usbasp: flash
flash_arduinoISP: PROGRAMMER_TYPE = avrisp
flash_arduinoISP: PROGRAMMER_ARGS = -b 19200 -P /dev/ttyACM0
## (for windows) flash_arduinoISP: PROGRAMMER_ARGS = -b 19200 -P com5
flash_arduinoISP: flash
flash_109: PROGRAMMER_TYPE = avr109
flash_109: PROGRAMMER_ARGS = -b 9600 -P /dev/ttyUSB0
flash_109: flash
LFUSE = 0x62
HFUSE = 0xdf
EFUSE = 0x00
FUSE_STRING = -U lfuse:w:$(LFUSE):m -U hfuse:w:$(HFUSE):m -U efuse:w:$(EFUSE):m
fuses:
    $(AVRDUDE) -c $(PROGRAMMER_TYPE) -p $(MCU) \
               $(PROGRAMMER_ARGS) $(FUSE_STRING)
show_fuses:
    $(AVRDUDE) -c $(PROGRAMMER_TYPE) -p $(MCU) $(PROGRAMMER_ARGS) -nv
set_default_fuses:  FUSE_STRING = -U lfuse:w:$(LFUSE):m -U hfuse:w:$(HFUSE):m -U efuse:w:$(EFUSE):m
set_default_fuses:  fuses
set_fast_fuse: LFUSE = 0xE2
set_fast_fuse: FUSE_STRING = -U lfuse:w:$(LFUSE):m
set_fast_fuse: fuses
set_eeprom_save_fuse: HFUSE = 0xD7
set_eeprom_save_fuse: FUSE_STRING = -U hfuse:w:$(HFUSE):m
set_eeprom_save_fuse: fuses
clear_eeprom_save_fuse: FUSE_STRING = -U hfuse:w:$(HFUSE):m
clear_eeprom_save_fuse: fuses
Here is my c-code:
#include <util/delay.h>
__asm__("clr  r1   \n\t");
int main(void) {
  DDRB |= 0b00000001;
  while (1) {
    PORTB = 0b00000001;
    _delay_ms(1000);
    PORTB = 0b00000000;
    _delay_ms(1000);
  return 0;
blinkLED.lst - this worries me the most:
blinkLED.elf:     file format elf32-avr
00000000 <__vectors>:
   0:    0c 94 2a 00     jmp    0x54    ; 0x54 <__ctors_end>
   4:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
   8:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
   c:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  10:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  14:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  18:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  1c:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  20:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  24:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  28:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  2c:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  30:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  34:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  38:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  3c:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  40:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  44:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  48:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  4c:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
  50:    0c 94 34 00     jmp    0x68    ; 0x68 <__bad_interrupt>
00000054 <__ctors_end>:
  54:    11 24           eor    r1, r1
  56:    1f be           out    0x3f, r1    ; 63
  58:    cf e5           ldi    r28, 0x5F    ; 95
  5a:    d4 e0           ldi    r29, 0x04    ; 4
  5c:    de bf           out    0x3e, r29    ; 62
  5e:    cd bf           out    0x3d, r28    ; 61
  60:    0e 94 36 00     call    0x6c    ; 0x6c <main>
  64:    0c 94 4d 00     jmp    0x9a    ; 0x9a <_exit>
00000068 <__bad_interrupt>:
  68:    0c 94 00 00     jmp    0    ; 0x0 <__vectors>
0000006c <main>:
int main(void) {
  DDRB |= 0b00000001;
  6c:    b8 9a           sbi    0x17, 0    ; 23
  while (1) {
    PORTB = 0b00000001;
  6e:    81 e0           ldi    r24, 0x01    ; 1
  70:    88 bb           out    0x18, r24    ; 24
    #else
    #endif
  72:    2f ef           ldi    r18, 0xFF    ; 255
  74:    33 ed           ldi    r19, 0xD3    ; 211
  76:    90 e3           ldi    r25, 0x30    ; 48
  78:    21 50           subi    r18, 0x01    ; 1
  7a:    30 40           sbci    r19, 0x00    ; 0
  7c:    90 40           sbci    r25, 0x00    ; 0
  7e:    e1 f7           brne    .-8          ; 0x78 <main+0xc>
  80:    00 c0           rjmp    .+0          ; 0x82 <main+0x16>
  82:    00 00           nop
    _delay_ms(1000);
    PORTB = 0b00000000;
  84:    18 ba           out    0x18, r1    ; 24
  86:    2f ef           ldi    r18, 0xFF    ; 255
  88:    33 ed           ldi    r19, 0xD3    ; 211
  8a:    90 e3           ldi    r25, 0x30    ; 48
  8c:    21 50           subi    r18, 0x01    ; 1
  8e:    30 40           sbci    r19, 0x00    ; 0
  90:    90 40           sbci    r25, 0x00    ; 0
  92:    e1 f7           brne    .-8          ; 0x8c <main+0x20>
  94:    00 c0           rjmp    .+0          ; 0x96 <main+0x2a>
  96:    00 00           nop
  98:    eb cf           rjmp    .-42         ; 0x70 <main+0x4>
0000009a <_exit>:
  9a:    f8 94           cli
0000009c <__stop_program>:
  9c:    ff cf           rjmp    .-2          ; 0x9c <__stop_program>
I appreciate any help.
Thanks.
MPN
That listing looks perfect to me, code that should work (as long as the LED is wired right on PORTB.0). What makes you think the code is wrong?
BTW what on earth is the asm("clr r1") supposed to achieve? It's ignored because it's outside the body of a function but what was the intention?
Hi clawson. Thanks for your quick response.
Well, PB0 does not output a voltage, hence, the LED is switched off. That makes me think that the code must be wrong. Following this thread, Paul had similar issues.
I figured that initializing r0 might solve the problem; it sounded like this was Paul's problem anyway.
How interesting. It seems to be the _delay_ function. If I comment that piece out, they light up. Not sure why the delay does not work.
I bet it does.  Just wait 16 seconds.
Hint:  #defining F_CPU to be 16 MHz does not make your AVR run at 16 MHz.  It >>tells<< the compiler how fast the AVR is running at.  >>You<< have to make it do that, usually by connecting a crystal and changing the CKSEL/SUT fuses appropriately.  Have you done so?  Your post shows your fuses to be the factory default values, meaning that your AVR is running at 1 MHz from the internal RC oscillator.  The delays will be 16 times longer than you intend.
This is becoming really entertaining ... look at this:
leds are on:
int main(void) {
    DDRC = 0xff;
    DDRA = 0xff;
    while (1) {
        PORTC = 0b10010011;
        //_delay_ms(1000);
        PORTA = 0b10010011;
    return 1;
leds are off:
int main(void) {
    DDRC = 0xff;
    DDRA = 0xff;
    while (1) {
        PORTC = 0b10010011;
        _delay_ms(1000);
        PORTA = 0b10010011;
    return 1;
Fun times :-)
I see no difference between your two programs.
CAn you post a schematic as you say PORTB.0 in one post but PORTC and PORTA in your last post.
Before this turns into a 50+ post thread over something simple post a schematic of your circuit and lets move from there
JIm
OP here...
My problem apperntly was that the --mmcu flag was needed both during compiling and linking, as sternst pointed out.
Without it the code was smaller (as JS noted in #4) but incomplete. Startup code was missing
You seem to use (TARGET_ARCH) for both compiling and linking, so that looks OK.
First, Joey migt be onto something. Your AVR might be running at a different fequency than your code think it should. Try shorter blink times.
What is the output if you do a "make all" or a "make flash" from the command line?
The lines for the compiler generated from the makefile tend to be quite long, but most of it are the path names to diffent parts and of course the command line options specified in the makefile. and these lines are not so hard to read.
Are there any error messages spit out on the command line during compiling or linking?
Could it be that any of the CPP_FLAGS are also needed for proper linking?
I am not an expert in makefiles  / linker scripts and such. If I was I wouln't have gotten myself into trouble in 2013.
Another possible cause might be in the objcopy part.
Are you sure that all the code in the .lst file ends up in your .hex file and gets programmed?
Often I see some loops for copying data from Flash to RAM to initialize data during initialisation, but it could be that those loops are not in the startup code because they are not needed.
Also: if you blink whole ports (as I did) instead of a single bit you rule out some hardware related problems.
Is this all done on a single uC, or have you tried multiple uC's?
+1
For instructions on how to do that, see Tip #1.
(Tip #1 also tells how to properly post source code).
Thank you for your hints. I inserted the code as suggested. I boiled the problem down to: compiler optimization. If I compile my code with the -Os flag, the LED does not light up. If I compile my code with the -O0 flag, the LED does light up. Please find below the c-code:
int main(void) {
    __asm__(
        "    ldi  r18, 0xFF" "\n"
        "    out  0x14, r18" "\n"
        "    out  0x1a, r18" "\n"
        "    ldi  r18, 0x00" "\n"
        "    out  0x15, r18" "\n"
    while (1) {
        __asm__(
            "    ldi  r18, 100"	 "\n"
            "    ldi  r19, 174"	 "\n"
            "    ldi  r20, 174"	 "\n"
            "1:  dec  r20"	"\n"
            "    brne 1b"	"\n"
            "    dec  r19"	"\n"
            "    brne 1b"	"\n"
            "    dec  r18"	"\n"
            "    brne 1b"	"\n"
            "    rjmp 1f"	"\n"
            "1:"	"\n"
    return 1;
I used make disassemble to look into the compiled code.
-compiled code with -Os flag
  64:	0c 94 49 00 	jmp	0x92	; 0x92 <_exit>
0000006c <main>:
int main(void) {
    __asm__(
  6c:	2f ef       	ldi	r18, 0xFF	; 255
  6e:	24 bb       	out	0x14, r18	; 20
  70:	2f ef       	ldi	r18, 0xFF	; 255
  72:	2a bb       	out	0x1a, r18	; 26
  74:	20 e0       	ldi	r18, 0x00	; 0
  76:	25 bb       	out	0x15, r18	; 21
    while (1) {
        __asm__(
  78:	24 e6       	ldi	r18, 0x64	; 100
  7a:	3e ea       	ldi	r19, 0xAE	; 174
  7c:	4e ea       	ldi	r20, 0xAE	; 174
  7e:	4a 95       	dec	r20
  80:	f1 f7       	brne	.-4      	; 0x7e <main+0x12>
  82:	3a 95       	dec	r19
  84:	e1 f7       	brne	.-8      	; 0x7e <main+0x12>
  86:	2a 95       	dec	r18
  88:	d1 f7       	brne	.-12     	; 0x7e <main+0x12>
  8a:	00 c0       	rjmp	.+0      	; 0x8c <main+0x20>
  8c:	2f ef       	ldi	r18, 0xFF	; 255
  8e:	25 bb       	out	0x15, r18	; 21
            "    rjmp 1f"	"\n"
            "1:"	"\n"
  90:	f3 cf       	rjmp	.-26     	; 0x78 <main+0xc>
00000092 <_exit>:
  92:	f8 94       	cli
00000094 <__stop_program>:
  94:	ff cf       	rjmp	.-2      	; 0x94 <__stop_program>
-compiled code with -O0 flag
0000006c <main>:
int main(void) {
  6c:	cf 93       	push	r28
  6e:	df 93       	push	r29
  70:	cd b7       	in	r28, 0x3d	; 61
  72:	de b7       	in	r29, 0x3e	; 62
    __asm__(
  74:	2f ef       	ldi	r18, 0xFF	; 255
  76:	24 bb       	out	0x14, r18	; 20
  78:	2f ef       	ldi	r18, 0xFF	; 255
  7a:	2a bb       	out	0x1a, r18	; 26
  7c:	20 e0       	ldi	r18, 0x00	; 0
  7e:	25 bb       	out	0x15, r18	; 21
    while (1) {
        __asm__(
  80:	24 e6       	ldi	r18, 0x64	; 100
  82:	3e ea       	ldi	r19, 0xAE	; 174
  84:	4e ea       	ldi	r20, 0xAE	; 174
  86:	4a 95       	dec	r20
  88:	f1 f7       	brne	.-4      	; 0x86 <main+0x1a>
  8a:	3a 95       	dec	r19
  8c:	e1 f7       	brne	.-8      	; 0x86 <main+0x1a>
  8e:	2a 95       	dec	r18
  90:	d1 f7       	brne	.-12     	; 0x86 <main+0x1a>
  92:	00 c0       	rjmp	.+0      	; 0x94 <main+0x28>
  94:	2f ef       	ldi	r18, 0xFF	; 255
  96:	25 bb       	out	0x15, r18	; 21
            "    rjmp 1f"	"\n"
            "1:"	"\n"
  98:	f3 cf       	rjmp	.-26     	; 0x80 <main+0x14>
0000009a <_exit>:
  9a:	f8 94       	cli
The difference between -Os and -O0 flag compilation is:
  6c:	cf 93       	push	r28
  6e:	df 93       	push	r29
The optimised code (-Os) deletes this part.
The led finally blinks once every second. The stack has never been properly initialised. I still do not know why. I added four lines of assembly which fixes the problem.
#define F_CPU 16000000UL
int main(void) {
    __asm__(
        "    push r28 " "\n"
        "    push r29 " "\n"
        "    in   r28, 0x3d " "\n"
        "    in   r29, 0x3e " "\n"
    DDRC = 0xff;
    DDRA = 0xff;
    while (1) {
        PORTC = 0b10010011;
        _delay_ms(1000);
        PORTC = 0x00;
        _delay_ms(1000);
    return 1;
-MPN
    __asm__(
        "    push r28 " "\n"
        "    push r29 " "\n"
Utter bollocks - this is NOT the solution!!!
+1
An interesting assertion.  I've lost track -- which model are we dealing with?  MNega16.  Where is the stack pointer for that model?
And what do we see in the posted "doesn't work"/ -Os code:
I.e., the stack pointer being initialized.
This getting boring. Your code .lss in #13 was quite obviously >>not<< compiled with -O0. The make file even says -Os. Stop taking wild stabs into the dark. Of course if you build with -O0 it won't work as expected. What does the documentation for delay.h say?
Weren't we told the opposite?
I said 'as expected' i.e. the delay will be wildly off because it will do runtime computations in fp.
clawson wrote:
That listing looks perfect to me, code that should work (as long as the LED is wired right on PORTB.0). What makes you think the code is wrong? . BTW what on earth is the asm("clr r1") supposed to achieve? It's ignored because it's outside the body of a function but what was the intention?
It's not supposed to be ignored.
Such basic asm statements (no input or output) are allowed outside functions.
In this case, not terribly useful.
"Demons after money.
Whatever happened to the still beating heart of a virgin?
No one has any standards anymore." -- Giles
skeeve wrote:
It's not supposed to be ignored. Such basic asm statements (no input or output) are allowed outside functions. In this case, not terribly useful.
???  If not ignored, then there should be code generated for it, right?  Looking at #13 I don't see it...
0000006c <main>:
int main(void) {
  DDRB |= 0b00000001;
  while (1) {
    PORTB = 0b00000001;
Thank you all for your patience and respectful responses. I appreciate it. If you find this topic boring, I suggest not responding to the thread.
I am still trying to get to the bottom of this. It is not bullocks that the LED flashes with one code and does not with the other. This is an observation. Whether my explanation is correct, can be discussed. I use an ATmega16 16PU 1022 and an AVRISPMKII programmer. The chip is mounted on an EasyAVR6 development board which has lots of peripherals including  a bunch of LEDs. I use Ubuntu , Emacs, and and a terminal.
If I comment out the "re-initializing the stack-pointer" assembly bit, the LEDs stop flashing. I stopped playing with the optimisation flag. It is now set to -Os. Here is the code:
int main(void) {
/* If I comment this part out, the LEDs don't flash */
    __asm__(
        " ldi	r28, 0x5F " "\n"
        " ldi	r29, 0x04 " "\n"
        " out	0x3e, r29 " "\n"
        " out	0x3d, r28 " "\n"
    DDRC = 0xff;
    while (1) {
        PORTC = 0xff;
        _delay_ms(1000);
        PORTC = 0x00;
        _delay_ms(1000);
    return 1;
If I disassemble the code, we can see that the code actually just initialized the stack pointer, so why do I have to do it again?
  64:	0c 94 51 00 	jmp	0xa2	; 0xa2 <_exit>
0x3d and 0x3e are addresses that point to SPL (stack pointer low) and SPH (stack pointer high), respectively.
I don't see anywhere here where anyone said that one code might not have had a different result than the other.  See the quote that inspired the bollocks comment and my affirmation.
Surely Cliff meant "bullocks"...
Image result for bullocks
or the department store
Back up and look at the posted code where you claimed the "reinitializing stack pointer", which was quoted by Cliff and inspired the offending opinion.  IT IS NOT THE SAME CODE -- IT HAS TWO 'IN' INSTRUCTIONS.  So at this point we have no idea what source code and the associated binary is really loaded into your chip at the present time.  Are you >>sure<< you are sending the code you think you are?  [how have you determined that?]  Is there a boot loader that might be jumping to main()?  Or similar.
One thing I would do is try a version that doesn't use _delay_ms, but just a home-rolled loop, not called as a function but inserted inline.  If your clock is 16 MHz, and you want to delay, say 100 ms, you need to burn 1.6 million cycles each blink on/off.  A starting point would be
volatile uint16_t delay1, delay2
#define MS_COUNT 8000 // seems about right for 1 ms at 16 MHz, but no guarantees
for (delay1 = 100; delay1 != 0; delay1--)
    for (delay2 = MS_COUNT; delay2 != 0; delay2--)
At least the inner delay variable needs to be 'volatile' to keep the compiler from optimizing the entire loop away.
But it does sound like your build/download process is broken in some way.
???  If not ignored, then there should be code generated for [inline ASM code outside of a function], right?  Looking at #13 I don't see it...
Eliminated by the linker due to --gc-sections
It's the first  instruction quoted.
I don't see it generate any opcodes in the .lss:
0000006c <main>:
int main(void) {
  DDRB |= 0b00000001;
  while (1) {
    PORTB = 0b00000001;
It should show up as an eor r1, r1 but there's only one of those and it's in the CRT:
I see your point.
That said, such asm's are allowed and are supposed to generate code.
The question is what removed it?
Garbage collection works on input sections.
It did not have its own .section command,
so it have had to been removed along with an unused function.
That seems unlikely.
I think the more likely scenario is that the compiler removed it as unreachable code.
How can C support the generation of code OUTSIDE a function? How could it ever possibly be accessed without a linkable entry point name to be called? Or are you suggesting it should drop "inline" between the CRT and the entry to main() or something??
For the latter there's clearly an existing mechanism to achieve that:
__attribute__((section(".init8"), naked)) void asm_code(void) {
    asm("ldi r24, 0x55");
As the "call main" is in .init9 then this would slot if just before that:
int main(void) {
    while(1) {
yields...
00000060 <asm_code>:
  60:   85 e5           ldi     r24, 0x55       ; 85
  62:   0e 94 37 00     call    0x6e    ; 0x6e <main>
  66:   0c 94 38 00     jmp     0x70    ; 0x70 <_exit>
But, as far as I know,  this is the only way to get asm "inline" and outside the body of a "normal" function.
I guess the reason the compiler does not reject the existence of asm() outside a function body out right is that the following is valid syntax:
uint8_t foo asm("r18");
int main(void) {
But even so I would have thought:
asm("anything");
int main(void) {
would throw some kind of "error: found asm() floating" message?
This is not C.  It is a GCC extension.
From https://gcc.gnu.org/onlinedocs/gcc/Basic-Asm.html:
Remarks
Using extended asm (see Extended Asm) typically produces smaller, safer, and more efficient code, and in most cases it is a better solution than basic asm. However, there are two situations where only basic asm can be used:
  • Extended asm statements have to be inside a C function, so to write inline assembly language at file scope (“top-level”), outside of C functions, you must use basic asm. You can use this technique to emit assembler directives, define assembly language macros that can be invoked elsewhere in the file, or write entire functions in assembly language.
  • Functions declared with the naked attribute also require basic asm (see Function Attributes).
Also:
Do not expect a sequence of asm statements to remain perfectly consecutive after compilation. If certain instructions need to remain consecutive in the output, put them in a single multi-instruction asm statement. Note that GCC’s optimizers can move asm statements relative to other code, including across jumps.
And:
Under certain circumstances, GCC may duplicate (or remove duplicates of) your assembly code when optimizing. This can lead to unexpected duplicate symbol errors during compilation if your assembly code defines symbols or labels.
Perhaps the redundant clr r1 instruction was identified and deduplicated?
At some point in this thread I stop reading, because something really strange happening with this compiler results.
First, there is a CLI (clear interrupt) at some point, without a single SEI (set interrupt) anywhere.
Second, one of the -Ox options, inserted two PUSH instructions, without POP anywhere, so, stack go down crazy through the SRAM and messes up with the RETurn address from the Call at some point.
There is no Stack setup at the beginning, even that some AVRs automatically set the Stack to the top of the RAM, that is not a rule of thumb, you need to do that.
Also, the routine at 0x60 calls 0x6C that is the supposed 1s time delay, but there is NO return instruction from that whatsoever...
If this routine is to blink LEDs, it must be a loop, but I don't see any loop for the blinking in the disassembled code, what I see that bothers my brain is this:
  86:	4a 95       	dec	r20
  8a:	3a 95       	dec	r19
  8e:	2a 95       	dec	r18
The above is an abomination.
Almost one second delay, if the core is running at 16MHz, but the rjmp instruction at 0x98 just restart the delay at 0x80 again and again.
Something is very strange here.  I just wonder.
Wagner Lipnharski
Orlando Florida USA
I've now marked stenrst post #8 From 2013 as the solution.
I was messin' with my makefile at that time and did not pass the -mmcu option.
Because of this the initialisation code was not linked in, but the program was, and this sometimes ran, but other times did not.
And then 5 years later, in #13 this thread got hijacked by mpn1989.
