[CODE] [C] 4x4 KEYPAD
7 posts / 0 new
Issue solved
Nitin Shenoy
The general idea is that you make the columns either input or low. Driving a column actively high when the others are actively low means certain key presses can short them out. This also means the inputs are active low and there should be pullups enabled.
So this is now solved?
I guess not wink
Yep.I'll update it with as solved
Nitin Shenoy
Please do not start a second thread on the same topic as your other thread.
It is best to continue the discussion within one thread.
For this reason this ends here. Anyone who wants to read about this follow Brian's link in #3
Topic locked
