ili9341 suspicious looking library code
17 posts / 0 new
I can't seem to draw anything below z=255 using this library and I suspect this bit of code:
void ili9341_setaddress(uint16_t x1,uint16_t y1,uint16_t x2,uint16_t y2)//set coordinate for print or other function
ili9341_writecommand8(0x2A);
ili9341_writedata8(x1>>8);
ili9341_writedata8(x1);
ili9341_writedata8(x2>>8);
ili9341_writedata8(x2);
ili9341_writecommand8(0x2B);
ili9341_writedata8(y1>>8);
ili9341_writedata8(y1);
ili9341_writedata8(y2);		// Shouldn't this be y2>>8
ili9341_writecommand8(0x2C);//meory write
Should not the first write of "y2" be y2>>8?
Doesn't y2 get you to the room with the big rock?
Of course, the reason I ask is: changing that line of code does not seem to change behavior.
Without adult supervision.
Yes,  it should be y2 >> 8
Yea. I'm thinking I have bogus example code.
I started off with adafruit's library, but there are so many #IF and such for all the different varieties of Arduini that I couldn't figure out how to get it out of the device's SPI port.
I believe that the preprocessor processes the compiler directives.
You can instruct Arduino to save the output of the preprocessor
by changing a line in the file preferences.txt
In the Arduino IDE preferences.txt file, the default line is:
preproc.save_build_files=false
Change this line to =true
This isn't for an arduino. Otherwise, the adafruit library would see the defines and just make.
Tom,
You need nothing more than a writedata() and a writecommand() function.   And they are nothing more than
DC = 1; spi(data); and DC = 0; spi(command);
Whether you are rendering text, graphics, photos, ... it all comes down to drawPixel(x, y, colour) or fillRect(x, y, w, h, colour)
A horizontal or vertical line is only a very thin rectangle.
You can write your basic functions in ASM, C, C++
And make use of existing Graphics libraries.    The advantage of C++ is that you can inherit from existing classes.
But ASM, C still end up with drawPixel() and fillRect()
Yes,  some libraries get messy with conditionals for different target hardware.   Especially with parallel interfaces
But as I show above,   an SPI interface is very straightforward to use.
I should have been more explicit in my post.
You said that you couldn't follow the Arduino source code from Adafruit because of all the #IF statements.
Let the Arduino toolchain sort all of that out for you.
Enable saving the preproc output files and then build.
The preproc will generate straight C code without the #IFs.
You can then read those files.
Adafruit's library doesn't include a particle electron board.
I googled " particle electron board" and it appears to be a STM32F205 board with Wireless.
There is an official STM32 Arduino Core from STMicroelectronics.
So it should be very easy to run Arduino C++ libraries.
But even if you stick with C.   You only need to know how to wiggle CS, DC, RST pins and a spi() function.
This is easy enough to do by direct ARM register commands but ST provide a HAL library for you.
Well, the first code I got working stubbornly refuses to draw anything if z > 240. It seems to be full of many other bugs.
So, I tried to adapt the adafruit class for a second time, but particle's silly IDE refuses to make spitft.cpp file, leaving all the virtual methods of the iliblablabla class unimplemented. I even put a snide remark in the file between two methods, and it doesn't raise a compile error. Perhaps one of the multiple #if statements isn't satisfied. The whole thing in enclosed in a big #if to make sure it doesn't make for a tiny 85.
"Um, Can I do this project with an xMega?"
I have not done much with TFT displays, but I think I like UTFT better than the Adafruit lib.
Recently I also printed a list of TFT libs which are supported by platformio in:
https://www.avrfreaks.net/forum/tft-touch-suggestions
It has 183 entries, which quite surprised me.
When limiting the list to lib's supporting ILI9341 it spits out a much more reasonable 19:
paul@dualcore:~$ pio lib search ili9341
Found 19 libraries:
TFT_eSPI
#ID: 1559
A TFT and ePaper SPI graphics library for ESP8266 and ESP32
Keywords: tft, epaper, display, esp8266, nodemcu, esp32, m5stack, ili9341, st7735, ili9163, s6d02a1, ili9486, st7789
Compatible frameworks: Arduino
Compatible platforms: Espressif 32, Espressif 8266
Authors: Bodmer
Adafruit ILI9341
#ID: 571
Library for Adafruit ILI9341 displays
Keywords: display
Compatible platforms: Atmel AVR, Atmel SAM, Espressif 32, Espressif 8266, Intel ARC32, Microchip PIC32, Nordic nRF51, Nordic nRF52, ST STM32, Teensy, TI MSP430
Authors: Adafruit
ILI9341_t3
#ID: 540
Optimized ILI9341 (320x240 Color TFT) Display
Keywords: display, tft, lcd, graphics, spi
Authors: Limor Fried, Paul Stoffregen
Ucglib
#ID: 943
True color TFT and OLED library, Up to 18 Bit color depth. Supported display controller: ST7735, ILI9163, ILI9325, ILI9341, ILI9486,LD50T6160, PCF8833, SEPS225, SSD1331, SSD1351, HX8352C.
Keywords: display
Authors: oliver
JeeH
#ID: 3082
Headers for framework- and platform-agnostic code
Keywords: experimental
Compatible frameworks: Arduino, CMSIS, libOpenCM3, mbed, STM32Cube
Compatible platforms: Atmel AVR, Espressif 32, ST STM32
Authors: JeeLabs
Adafruit ILI9341
#ID: 1478
Keywords: display
Authors: Adafruit
Adafruit_ILI9341
#ID: 2148
Port of the Adafruit_ILI9341 library for MBED. Depends on BurstSPI. fillRect, drawFastVLine, drawFastHLine are optimized to use BurstSPI fastwrites and perform a clearRX afterwards. MIT license Due to 600 character ...
Keywords: ili9341, tft
Compatible frameworks: mbed
Compatible platforms: Atmel SAM, Freescale Kinetis, Maxim Integrated MAX32, Nordic nRF51, Nordic nRF52, NXP LPC, Silicon Labs EFM32, ST STM32, Teensy, WIZNet W7500
Authors: James Kidd
ILI9341
#ID: 88
Seeed ILI9341 2.2 TFT+SD library
Compatible frameworks: Energia
Compatible platforms: TI MSP430
Authors: Radoslav Malinov
UniGraphic
#ID: 2819
Basically i glued Peter Drescher and Simon Ford libs in a GraphicsDisplay class, then derived TFT or LCD class (which inherits Protocols class), then the most derived ones (Inits), which ...
Keywords: ili9320, ili9325, ili9328, ili9341, ili9481, ili9486, ist3020, lcd, mipi, parallel, spi, ssd1306, st7565, tft, uc1608, uc1701
Authors: GraphicsDisplay
SPI_TFT_ILI9341
#ID: 2976
Lib for the new LCD Display with ILI9341 controller
Keywords: spi_tft_ili9341
Authors: Peter Drescher
Show next libraries? [y/N]: y
ILI9341
#ID: 1139
ILI9341 for DisplayCore
Keywords: display, displaycore, tft, lcd, glcd, oled, graphics, font
Compatible platforms: Microchip PIC32
Authors: Majenko Technologies
ILI9341_esp
#ID: 5371
Optimized ILI9341 (320x240 Color TFT) Display Support different SPI buses
Keywords: display
Authors: Limor Fried, Adafruit, Paul Stoffregen, Kurt Eckhardt
ILI9341_ESP32
#ID: 2956
A fast ILI9341 LCD driver to be used with ESP32.
Keywords: display
Authors: the-fallen
MI0283QT9
#ID: 148
MI0283QT-9 / -9A / -11 Display (ILI9341, SPI)
Keywords: spi, graphics, display, lcd
Authors: Watterott electronic
TFT_ILI9341_ESP
#ID: 5691
A TFT ILI9341 SPI graphics library for ESP8266
Keywords: ili9341, esp8266, tft
Compatible platforms: Espressif 8266
Authors: Bodmer, Adafruit
BSP_DISCO_F429ZI
#ID: 2208
STM32F429ZI Discovery board drivers
Keywords: bsp, disco_f429zi
Authors: ST
ILI9341_SPI
#ID: 3783
ILI9341_SPI
Keywords: ili9341_spi
Authors: TMNTmaker !
ILI9341_Graphic_Library
#ID: 3767
Wrapped version of the ILI9341 graphics library with some MBED tweaks
Keywords: ili9341_graphic_library
Authors: Justin Howard
SX032QVGA008
#ID: 5261
aitendo SX032QVGA008
Keywords: aitendo, ili9341, spi, tft
Authors: Imayan chan
Today's project is putting a program in an ATTINY 10 for a silly girl's birthday present. 3d printed box, switch and servo to make a useless machine. Besides, her birthday is tomorrow.
Time for an up-your-confidence type project.
Well... So much for that. My age-old Atmel ICE has passed away. In spite of its life support, the USB connector if flopping around loose inside again.
Dang. Moriah's birthday is tomorrow. I guess she's not getting this.
As an emergency repair you can simply cut the end of an USB cable and solder it directly to your PCB. (Not the end you cut off, but the other end. Euhm, beginning?, no the beginning still has a connector. Intermediate part? Weird stuff, language.)
Or take some other USB connector, glue it in a hole of the case and route some wires to the PCB for a more permanent repair.
I've soldered the connector back on twice over the years, and strapping it to a board probably extended its life. Haven't taken it apart to see what the damage is this time.
Was going to make the pastor's daughter a useless machine for her birthday, today. As a last-ditch attempt, I decided to use an arduino, but... it won't program. She's getting a card.
You could make a useless machine with nothing but a DPDT toggle switch, a SPST limit switch, and a plain old motor. No servo or MCU needed. But I guess if the party is today that might be a tall order... ;-)
Right now, more worried about getting an avr programmer working, or finding some way to make money again.
