shifting with negative numbers . explanation please.
18 posts / 0 new
hello ,i want to ask about bitwise operators (shifting)
 i know that -1 = 1th comp: 00000001
                          2th comp: 11111110
                          add 1:       11111111
and that means -1=256 in decimal here
now how do i get these results after shifting with -1 (right & left shift )  ?
32<<-1 = 0
and 32>>-1 = 64
thanks in advance
What you are asking makes no sense. This is what the C standard says about << and >> operators:
So using an negative shift is "undefined behaviour" so no one can possibly say what the result is. If I write:
	PORTB = 3 >> -1;
the C compiler says:
		.././main.c: In function 'main':
C:\Users\uid23021\Documents\Atmel Studio\7.0\test1\test1\main.c(12,12): warning: right shift count is negative [-Wshift-count-negative]
		  PORTB = 3 >> -1;
It did generate code however and what it generated was:
	PORTB = 3 >> -1;
  8c:	85 e2       	ldi	r24, 0x25	; 37
  8e:	90 e0       	ldi	r25, 0x00	; 0
  90:	26 e0       	ldi	r18, 0x06	; 6
  92:	fc 01       	movw	r30, r24
This is an "interesting" interpretation. The compiler has chosen to interpret >>-1 to mean <<1 in fact so the 0x03 has become 0x06
I wonder if your original was malformed and you were actually asking what the result of something like:
-1 << 3;
was? In that case it is:
	PORTB = -1 << 3;
  90:	28 ef       	ldi	r18, 0xF8	; 248
  94:	20 83       	st	Z, r18
so 0xFF has been shifted to 0xF8. That is 11111111 has become 11111000 - the bits shift to the left 3 places with 0 filling in behind.
 it was shift with negative number .. 3<<-1 not -1<<3
thank you  for answer
As with anything like this, if it's not covered in your copy of K&R then the next place to look is the C standard.
Unfortunately "undefined" means just that. In which case all you can do is just as I did and see how your own C compiler chooses to implement it.
(but if the code may later be used with a different compiler the fact that you are relying on non-standardized operation should be highlighted)
What you can do is avoid it unless it is a documented extension.
"Undefined" can mean nasal demons of arbitrary sizes, colors
and dispositions.  The effect on one's nose is bad enough.
Any of them might take it into its head (or wherever it keeps it brain)
to go back in time and kill all your grandfathers.
Nasty business, "undefined".
"Demons after money.
Whatever happened to the still beating heart of a virgin?
No one has any standards anymore." -- Giles
first of all, you wrote:
I know that -1 = 1th comp: 00000001
                 2th comp: 11111110
                 add 1:    11111111
That is not true, since -1 = 255, not 256.
The problem with bit shifts on signed numbers, is that the bit 7 is the negative flag indicator.
When you shift a signed byte, the bit 7 should not be touched or considered a value bit.
Consider the signed byte 0011-1111 = 0x3F = +63
If you left shift, multiply by 2, it will result in 0111-1110 = 0x7E = +126, that is exactly +63 * 2
If you again left shift, it will result in 1111-1100 = 0xFC = but signed -0x7C = -124, not unsigned 252 (126*2).
Worse is right shifting a negative number, since bit 7 will fall into bit 6 and creating havoc with the result.
Suppose you have signed 1111-0110 = 0xF6 = -10  and you make shift right LSR.
It will end up as 0111-1011 = 0x7B = +123.
A simple LSR instruction changed the signed byte value -10 to +123.
It could mean that -10 / 2 = +124.
See how crazy it is?
So, shifting signed bytes should never touch bit 7.
First, when shifting negative numbers the shift must be reversed.
If you use LEFT SHIFT to multiply unsigned numbers, it will divide signed numbers.
For example,
Shifting Left number 4 you get 8, number increased two fold.
Shifting Left signed number -4, you get -8, number increased negative, but as negative it was in real divided two fold.
Number -8 is smaller than -4. Well, yeah, I know.
Shifting signed numbers, the shift must happen only on bits 6~0.
For example, shifting RIGHT 0xC8 11000-1000 = -56 will result in -28 0xE4 1110-01000
See that bit 7 stay 1, meaning negative, bit 6 was shifted right to bit 5 and a new bit 6 appears as 1, also, bit 3 shifted to bit 2.
It means what?
The LSR and LSL instructions are no good for it, since they insert a zero bit at bit 0 or bit 7.
In this case, shifting right a signed negative byte, requires only to shift right bits 6.5.4.3.2.1.0, keeping bit 7 = 1 (negative flag) and inserting a bit 7 = 1.
A crude example of a RIGHT SHIFT on negative number, long explanation, would be:
LDI  R16, 0b11001000  ; $C8 -56
MOV  R17, R16
ANDI R17, 0b10000000  ; save bit 7 on R17 (signed flag)
LSR  R16              ; shift right all byte
ORI  R16, 0b01000000  ; insert forced bit 6 = 1
ORI  R16, R17         ; reinsert old bit 7 (signed flag)
The routine above will shift right R16, negative number (-56), resulting in -28 at the end.
The is another way to do that using the Carry bit.
LDI R16, 0b11001000
MOV R17, R16
ROL R17              ; save bit 7 in C
ROR R16              ; shift right R16 and insert old bit 7 from C
ORI R16, 0b01000000  ; force insert bit 6 = 1
But, as the instructions ROR, ROL, LSL, LSR works on unsigned numbers, you can convert your signed negative numbers to unsigned, subtracting them from zero, then applying the required shift and again subtracting the result from zero.  Lets see the ASR instruction later, it keeps the sign intact.
Example:
1111-1111 = -1, multiplied by 2 should be -2.
So, subtract
0000-0000 - 1111-1111 = 0000-0001
Now LSL it will become 0000-0010
Now again subtract this from zero
0000-0000 - 0000-0010 = FE 1111-1110 = -2
LDI R16, 0b11111111  ; 1111-1111 -1
CLR R17              ; 0000-0000
SUB R17, R16         ; 0000-0001
LSL R17              ; 0000-0010
CLR R16              ; 0000-0000
SUB R16, R17         ; 1111-1110 -2
Again, -3 shift left
LDI R16, 0b11111101  ; 1111-1101 -3
CLR R17
SUB R17, R16         ; 0000-0011
LSL R17              ; 0000-0110
CLR R16
SUB R16, R17         ; 1111-1010 -6
The Z80 processor has an instruction SRA, it shifts the register to the right and keep bit 7 unchanged... specially for signed, the same as ASR in AVR cores.
The ASR (Aritmetic Shift Right) instruction shifts right all bit duplicating bit 7 in place, it allows to divide the byte by 2 and keeping the sign.  But there is no equivalent for left shift.
Always remember that on 16, 24, 32 bits (multi-byte) negative numbers, only the MSB byte bit 7 is the flag. All bits (8) of the other bytes are value bits.
Deal with negative numbers is a constant headache, our brain can't process it easily.
Every routine should stressed with all possible bit combination to make sure it works nice.
Wagner Lipnharski
Orlando Florida USA
wagnerlip wrote:
Mas, como instruções ROR, ROL, LSL, LSR são para unsigned numbers (...)
Huh, why does this sentence starts in portuguese then continues in english?
Maybe there's a glitch in the Matrixcheeky
Yeahhh... kkk... it happens.  I post constantly in both languages different forums... matrix got mixup.
This week my port's nacelle is running with a subspace virus, warp coil temperature is fluctuating.   wink
Wagner Lipnharski
Orlando Florida USA
... of course, the raw routine posted as
LDI R16, 0b11111101  ; 1111-1101 -3 (create a negative number)
CLR R17
LSL R17              ; 0000-0110
CLR R16
could be done a little bit more efficient and elegant. since Subtracting a number from zero is exactly what the NEG (negate) instruction does, the "two's complement"
NEG R16              ; 0000-0011 Subtract from zero (Two's complement)
LSL R16              ; 0000-0110 Shift Left as positive
NEG R16              ; 1111-1010 -6
Wagner Lipnharski
Orlando Florida USA
But for left shift just use ADD (no need for a signed version) , and for right use ASL that will keep the correct sign.
Like in #11
LDI  R16,-3
ADD R16,R16
And R16 is -6
For AVR's with HW MUL it's sometimes better to use a signed multiplication.
Like in #11
LDI  R16,-3
ADD R16,R16
And R16 is -6
Add is what the compiler (avr-gcc 4.9.2 is the version I have here) seems to prefer.
Also, the compiler should easily optimise a multiply by power of 2 with or without hw mul.
The compiler uses add for both of these
int8_t times2(int8_t x)
    return x * 2;
    return x << 1;
They both give
00000080 <times2>:
  80:   88 0f           add     r24, r24
  82:   08 95           ret
And multiply by 4 gives
00000080 <times4>:
  82:   88 0f           add     r24, r24
  84:   08 95           ret
The AVR GCC compiler use R1 as a Zero register, so it's a pain for it to use the HW mul (it will need to do a clean up)
Ah, I forgot about that.
Actually, I forgot that the mega328p (which above code was compiled for) even had HW mul.
Just had to look it up.
So I was trying to use it as an example that even without HW mul, if you want to multiply by a power of 2 then there's not much point trying to be clever,  just write it as a multiply and let the compiler pick whatever it thinks is the best way to do it. Fortunately I think it still shows that :)
Like in #11
LDI  R16,-3
ADD R16,R16
And R16 is -6
The problem is that it always requires an extra byte to the left, so you can see if it still negative or not.
The quoted doesn't work very well when the value is above 64, for example, -65, when the result ends up over the limit of 7 bits for negative numbers in a single byte
LD  R16, -65  ;  1011-1111
ADD R16, R16  ;  0111-1110
R16 ends up with 0x7E what is +126 as a Byte or -130 as a word (correct).
This is always a problem with negative numbers, the left carry can be missed, and it is NOT a missed value bit, it is the sign.
The other issue is that when adding the same register (multiplying by 2) of -4 (0xFC), the sign bit 7 disappears and the original bit 6 goes to 7.
But in true, this new bit 7 was originally a value bit (yellow), not a sign bit (blue).
1111-1100
The fact that it moves to bit 7 doesn't change it color, it was a valued bit, and still being, just occupying a position of the sign bit.
carry <--- 1111-1000
It is just coincidental that the original bit 6 was also "1" and now as bit 7 represents a negative number.
See, when it was left shifted, the original bit 7 was lost into carry, but nobody pay attention to say "oh, because the carry is on, it still a negative number".
Just the fact that the actual bit 7 is "1", everyone will say "oh, it is a negative number".
The -65, 1011-1111 when LEFT SHIFTED becomes
carry <--- 0111-1110, potentially a positive number since the actual bit 7 is off.
But now, everyone will cry out loud about the carry bit on... "look that, look that"..
So, technically, whenever LEFT shifting signed numbers, the carry bit MUST be returned to bit 7, it should never left anyway.
The instruction ASR (aritmetic shift right) does exactly that for right shifting signed numbers.
So, the equivalent inverted ASR, would be the non existent ASL, could be always replaced by:
LSL  R16
BRCC PC+3
ORI R16,0x80
RJMP PC+2
ANDI R16,0x7F
and carry from the LSL will still be valid at output since neither ORI or ANDI touches the carry bit.
or easily as;
NEG R16
LSL
NEG R16
but here the LSL carry bit is compromised by the NEG instruction that follows.
Wagner Lipnharski
Orlando Florida USA
1111-1100
No, it's no coincidence, it's designed like that. The largest negative number (in absolute value) that you can store in 8 bits is -128. So you can't double -65, because -130 does not fit.
But you can double -64. It's no coincidence that the binary representation of -64 is 1100 0000 so it has a "spare" 1 bit that becomes the sign after shifting. Every negative number in the range -1 to -64 will have this spare bit, so they can be doubled by shifting.
edit: in other words, if you have a sequence of leading "1" bits in a negative number, they are all sign bits, not just the MSB. So when you sign extend -64 to 16 bits you add 8 extra sign bits:
1100 0000 -> 1111 1111 1100 0000
Your example is a overflow
If there is a risk for overflow you would expand the hole thing to 16 bit.
Add:
This is normal 2 complements algebra, not sign magnitude, so no need for any conversions.
