Playing with the new tinyAVR 1-series
22 posts / 0 new
I've recently moved from Arduino to "bare AVRs", and now making my own PCBs. Most recently, I've decided to explore the newer AVRs, and specifically I've chosen attiny1614 (very low cost, hobbyist-friendly SOIC-14 package) -- I see it as attiny84 replacement.
Just want to share my experience and maybe start a discussion on a few things.
Toolchain:
Having a preference for free (as in freedom) software and small footprint, I was able to successfully set up a minimal toolchain on Linux (Ubuntu) without having to use Atmel/Microchip IDE.
I've documented the process on my github: https://github.com/vladbelous/tinyAVR_gcc_setup -- hopefully someone might find this useful.
Some key takeaways:
  • These new AVR parts are much closer to atxmega rather than to (previous) attiny/atmega parts. In GCC, it is classified under avrxmega3 architecture.
  • Recent GCC versions natively support avrxmega3 / attiny1614, but there's no support (yet?) in avr-libc (as of version 2.0.0). My workaround here is to get a few additional files (in my case, just 5) from Atmel/Microchip packs.
  • avrdude can be used for programming using El Tangas (thanks!) modified avrdude.conf and jtag2updi firmware -- it allows you to setup another AVR as the programmer (similar to the popular "Arduino as ISP" approach). However, the avrdude.conf modifications are not yet upstream (as of version 6.3).
Questions:
Is there any information on adding these new parts to upstream avr-libc (i.e. http://download.savannah.gnu.org/releases/avr-libc/)? Do we have anyone from avr-libc in these forums?
When (if at all) do we expect the jtag2updi work of El Tanga (or some other form of UPDI support) to be added to mainline avrdude?
I think it's quite important to have a simple/small cross-platform toolchain if these new parts are to become more popular in hobbyist community.
avrxmega3 architecture:
Having some experience with (older) attiny and atmega parts, and no experience with atxmega, a lot of things ended up a surprise to me during programming, causing a non-trivial debugging time.
One the one hand, some architecture unification in 8-bit AVR parts seems like a good idea to me (new megaAVR 0-series is also avrxmega), and personally I'm ok with it being atxmega-like, but I'm worried that in hobbyist community there's much more experience/material on the (previous) attiny/atmega, and atxmega is less known. What do you think about this?
Also, do we know if this is indeed Microchip's plan to have all new 8-bit AVRs use avrxmega architecture, or do we expect new attiny/atmega-like parts to come too?
Attiny1614-based board:
I've designed (and had it manufactured) a PCB for attiny1614 and put all the design files and further information here: https://github.com/vladbelous/avr-attiny1614-mini
So far, the board works well, and I was able to use UART, timers and even drive an APA106 programmable LED (similar to the popular WS2812). I'm not using any frameworks, just C++ with avr-libc.
One issue I ran into is UPDI/RESET pin: you have to select either UPDI functionality or RESET functionality via a fuse (default is UPDI). If you choose to make it a RESET source, you'll need to apply 12V to program it again.
I've recently had an issue in one of my designs, where a small leakage through a turned-off MOSFET ended up harvested enough by a boost converter circuit to "partially" start the connected AVR MCU. "Partially" means it got stuck in some non-working condition such that even after supplying a stable 5V, a physical RESET was still necessary.
Basically, I learned the importance of RESET signal and voltage supervisors, but now it appears the new attiny parts are somewhat inconvenient in this regard -- or am I missing something here?
What are your thoughts on the new tinyAVR 0/1-series and megaAVR 0-series parts? Is it the future of AVR for hobbyists?
I'm quite interested in seeing (and contributing to) it becoming more popular, but it's not yet clear if there are enough stakeholders. I know the new Arduino boards are using atmega4809 (which is megaAVR 0-series), but I have some doubts it will lift off.
VladB wrote:
  Questions: Is there any information on adding these new parts to upstream avr-libc (i.e. http://download.savannah.gnu.org...)? Do we have anyone from avr-libc in these forums?
I don't think my mods will be added, what I did is basically an hack, avrdude 6.3 does't really support UPDI. The firmware jtag2updi just pretends the AVR-0/1 are xmegas and uses the PDI support present in avrdude 6.3, specifically via the jtagice MkII protocol.
If you look at the definition for the avr-0/1 family inside my avrdude.conf, you will notice some stuff is commented out and replaced:
# AVR8X family common values
part
    id		= ".avr8x";
    desc	= "AVR8X family common values";
#    has_updi	= yes;
    has_pdi	= yes;
    nvm_base	= 0x1000;
#    ocd_base	= 0x0F80;
Here, I edited the family definition to say they use the PDI interface instead of UPDI. But edited from where? Actually, there is an official version of avrdude that supports UPDI:
http://svn.savannah.gnu.org/view...
This was being supported by Atmel, but since the acquisition I'm not so sure. There are new chips an a few wrong signatures that were not corrected, so I have a feeling Microchip is no longer committed to support avrdude.
Another problem is that UPDI is only supported officially by protocols that use USB exclusively and I wanted to make a programmer that uses serial interface, so I used this work-around of tricking the jtagice MkII interface of avrdude.
edit:
If I could, I would extend the jtagice mkII protocol to support higher programming speeds, and modify avrdude accordingly. Also correct a few things such as hardcoded memory names and types.
The UPDI interface can R/W SRAM and I/O registers at will, but this is not really possible to do with the current capabilities of avrdude. It would only require slight modifications, though, and the interactive mode of avrdude could be used for limited debugging.
I feel completely happy with these new small parts. Using official tools I found no problem, programming/ debugging is very nice with one pin only. But, in my opinion this UPDI Pin should not have different functions, should be always accessible. I have never used the external reset.
PCBs can be very easy. For the controller itself, usually only one capacitor is needed. Sufficient stable clock and many features are already included in these great powerful chips. My favorites are the double AD converters with many voltage references.
Is there some reason you're not using the beta for MPLABX on Linux?
El Tangas wrote:
But edited from where? Actually, there is an official version of avrdude that supports UPDI: http://svn.savannah.gnu.org/view...
Interesting. I only checked the latest released version, which is 6.3 from 2016, according to http://download.savannah.gnu.org/releases/avrdude/.
Do I understand correctly that if you have a programmer of type jtagice3_updi, it should work with avrdude from trunk? Since it's USB, does it require special drivers, or does it use some common interface?
There's definitely value in having a serial-based solution, like yours. Perhaps still it can be modified/cleaned enough to be included in upstream? The principle itself seems reasonable - it's not much different from the popular Arduino-as-ISP approach.
BTW, somewhat off-topic: what is the purpose of series resistor in the wiring diagram? I tried without it, and it seemed to work fine too. Given UPDI is bidirectional, I decided to keep the resistor in my designs as a safety measure, but wondering if there are other reasons.
I cannot say anything bad about MPLABX, since I've never tried it, and I'm not advocating for avoiding it :)
Coming from (non-embedded) software world, I'm just more used to modularity: compilers are independent from editors, and all parts bring only minimal dependencies. There are many reasons one might prefer that (though embedded development could be quite different, I admit).
The fact that there's AVR architecture support in upstream GCC is of huge benefit to AVR as a hobbyist platform, we just need to get avr-libc to the same level.
AVR-GCC toolchain is readily available in official repos of many Linux distros, but I doubt vendor-specific IDE bundles will ever be there. Others can build on top of it and create new development platforms (e.g. platformio.org), create frameworks using modern C++ features, add support for other languages (e.g. there's some projects adding AVR backend for LLVM), etc. Overall, the hobbyist can afford to get creative without a business reason :)
In any case, this was not the main emphasis of my post. If you're interested in creating a separate post discussing merits of different toolchain/IDE setups, I'll gladly expand there!
Yes, I suppose so, if you have a programmer that "talks" jtagice3, you can use it with the unreleased version of avrdude to program UPDI chips.
The thing about MPLABX is that it comes from Microchip with THEIR version of avr-gcc, this is generally 1..2 years ahead of the FSF mainline version so will support new models.
Well, that's not entirely true. First, note that AVR-GCC is just regular GCC configured to output for AVR instruction set. This is what it means for GCC to natively support AVR architecture.
So almost by definition upstream/mainline AVR-GCC is the latest. Also, if Microchip/Atmel made significant changes to "their" AVR-GCC, they would also have to publish the sources, as required by GPL.
According to other posts in this forum (e.g. https://www.avrfreaks.net/forum/mplabx-first-users?page=all), MPLAB X comes with AVR-GCC version 5.4.0, while upstream stable GCC is 8.2.0. Note that 5.4.0 was release on June 3, 2016, while 8.2.0 was July 19, 2018.
However, the other important part of the toolchain is libc, and in it is true that mainline avr-libc is indeed behind in terms of new tinyAVR support, hence my guide.
A I understand it, the issue is NOT gcc but the product definition files! Those are what really lag in the distributions.
I'm not sure what you mean by "avr-libc" support.  Traditionally, Atmel has been responsible for added new device support to ... everything, and recently it seems pretty clear that the "packs" are their preferred solution (as opposed to actually updating packages maintained outside of their control.)  So it's not quite like avr-libc hasn't gotten updates, it's more like updating avr-libc itself is no longer the preferred method of getting those updates.
(I don't particularly like this: https://www.avrfreaks.net/forum/device-family-packs-are-annoying, but it seems to be the way things are going...)
For better or worse, avr-libc "support" doesn't extend much beyond the avr/io.h definitions.  (I guess eeprom and pgmspace could use an update.)
I think we are on the same page here. Programming C/C++ usually requires some additional runtime libraries/code, which however are not part of the compiler itself (see below for an example).
But to clarify my point still: today we can program attiny85/atmega328p/etc with just (upstream) gcc + avr-libc -- in this sense these parts "are supported by avr-libc 2.0.0". The same cannot be said of attiny1614, unfortunately.
I really hope avr-libc project will not die. Was Atmel the only significant contributor? Do you happen to know if any other maintainers of it are on these forums?
Yes, I that's correct. But there's also a few additional things other than product definitions.
For example, C/C++ language definition has floating point types, and defines mathematical operations on it. However, the AVR instruction set does not have any hardware FP support, so they need to be emulated in software.
Traditionally, this implementation is done through external libraries which are not part of the GCC itself. In case of FP, these operations are implemented in libm, which is part of avr-libc.
It also happens that libm is architecture-specific (not part-specific), and avr-libc has libm implementations for avrtiny, avr5, avrxmega2, avrxmega4, etc, but NOT avrxmega3. Hopefully this is be improved soon.
As I've mentioned, in my case, to be able to program attiny1614, I had to manually add these files (otherwise normally supplied by your avr-libc):
  • libm.a and libc.a -- these are avrxmega3-specific, and apply to all tinyAVR 1-series (and similar) MCUs. These include math operations, stuff for working with EEPROM, and C standard library stuff.
  • libattiny1614.a, crtattiny1614.o -- these are part-specific. I don't exactly know what these are responsible for, but I think that, e.g. interrupt vector map is one of those things.
  • iotn1614.h -- also part-specific. This defines names for all IO-registers, interrupt vector addresses, etc.
Quick update:
I've found that there is actually work being done on adding avrxmega3 support to avr-libc: http://savannah.nongnu.org/patch... -- last updates are as recent as Dec 2018.
It looks like it's using a very similar approach (borrowing from Atmel/Microchip atdf packs and their packaged toolchain). I'll probably test out the patch some time later, report here and update my guide :)
 Really?  In between the latest toolchain from Atmel and the downloaded "pack", I have:
 pwd
.../Atmel.ATtiny_DFP.1.3.229/gcc/dev/attiny1614/avrxmega3
WWHackintosh<9998> ls
crtattiny1614.o         libattiny1614.a
pwd
/usr/local/avr8-atmel-3.6.1.495/avr/lib
WWHackintosh<10007> ll avrxmega3/
total 896
-rw-r--r--@  1 wheel  295126 Jun 13  2018 libc.a
-rw-r--r--@  1 wheel   65984 Jun 13  2018 libm.a
-rw-r--r--@  1 wheel    5934 Jun 13  2018 libprintf_flt.a
-rw-r--r--@  1 wheel    2710 Jun 13  2018 libprintf_min.a
-rw-r--r--@  1 wheel    6976 Jun 13  2018 libscanf_flt.a
-rw-r--r--@  1 wheel    3836 Jun 13  2018 libscanf_min.a
drwxr-xr-x@  8 wheel     256 Jun 13  2018 short-calls/
(the xmega3/libc.a came with avr8-gnu-toolchain-3.6.1.496 from http://distribute.atmel.no/tools/opensource/Atmel-AVR-GNU-Toolchain/3.6.1/)
These are essentially the same things you'd have to download to get support for the most recent chips even in AS (though perhaps AS would do it for you automatically, even if it didn't come with the latest compiler.)
My comment was specifically about upstream avr-libc, not Atmel/Microchip's toolchain, sorry if it wasn't clear.
Basically upstream released avr-libc does not have avxmega3 or any of the new attiny part support, but there is work in progress.
In the mean time, to get it to work with latest gcc (8.2), we can borrow a few files from Atmel/Microchip packs and their packaged toolchain, which are the ones you are showing.
Yes but it is COMPLETE in Atmel/Microchip's version so why on earth wouldn't you save yourself a load of hassle and just simply use that?
...THEIR version of avr-gcc, this is generally 1..2 years ahead of the FSF mainline version so will support new models.
The Atmel (Microchip) avr-gcc is 1..2 years ahead WRT device support, and 2..3 years behind WRT gcc version.  Decisions, decisions...
(OTOH, that means that the majority of people using avr-gcc are using an older gcc, and I'm not sure that I *trust* FSF to keep AVRs working.  Ie: https://github.com/arduino/Arduino/issues/1208 )
I don't understand the borderline hostility here. I'm not suggesting you should use mainline avr-libc (or that anyone should not use Atmel/Microchip tools), but if anyone else wants to (and I've already mentioned a few reasons), I only provided information how they can achieve that.
It's great that Atmel/Microchip has full support of their parts, no doubt, but it's also a good thing for that to be in mainline avr-libc. Nothing to be antagonistic about.
Oh don't get me wrong,  I'm a great advocate for FSF / FOSS / GNU and so on. But I'm simply pointing out that if you pick any AVR the fastest route to a Linux installation to support this is to take a distribution from Atmelchip. Sure Bill is right this takes you back to a 5.4 when mainline GCC is at 8.x but those two aren't actually that far apart - there was a pretty major leap in GCC versions after the 5.X's and 6.X and 7.X were almost never seen. So a stable 5.4 with full device support still looks like the quickest/easiest option. It is true that Georg-Johan's ISR streamlining stuff in 8.X does make it quite attractive though if you are really tight on cycles/bytes.
The ones at Microchip will hold close to their vests the answers to your questions (8b MCU market is competitive)
XMEGA's architecture does vary from megaAVR 0-series (DMA, bus matrix difference due to DMAC master, separate memory spaces versus unified memory)
Microchip has a major competitor in Texas Instruments.
EBI by megaAVR and XMEGA AVR is looking long in tooth.
AVR16?
VladB wrote:
... where a small leakage through a turned-off MOSFET ended up harvested enough by a boost converter circuit to "partially" start the connected AVR MCU.
There are relatively low leakage FETs but you have to search for 'em.
Some SMPS are by BJT in order to reduce leakage at an elevated temperature.
Should be multiplexed as tinyAVR 0-series is a follow-on to tiny102 and the very popular tiny85.
MPLAB PICkit 4 has Vpp and UPDI for the following in MPLAB X v5.10 :
  • tiny202
  • tiny204
  • tiny402
  • tiny404
  • tiny804
  • tiny1604
Apparently similar for MPLAB Snap.
VladB wrote:
The fact that there's AVR architecture support in upstream GCC is of huge benefit to AVR as a hobbyist platform, ...
likewise for Texas Instruments MSP430TM.
https://gcc.gnu.org/onlinedocs/gcc-8.2.0/gcc/MSP430-Options.html#MSP430-Options
Indeed though a perk at some workplaces is, IIRC, Fridays where one can effort a personal project that may have a link to that business or may be simply FOSS.
Same thing with tinyAVR 1-series: I would call that a crazy engineer's idea. The possibility to brick devices should be excluded for all time, in principle. Programmability should always be ensured. New controllers like ATMEGA4808/09 do it right: A fixed UPDI Pin for nothing else. I hope that will go without saying for future devices.
To get out of the way of the discussed complex GCC issues I only use simple assembler- for me the means of choice for simple controllers cheeky
