Selecting a single bit in Xmega a3bu
3 posts / 0 new
How to select a single bit in a PORT in xmega a3bu and to set is as output or input or make it high or low using '.OUT' keyword.
For example:
#define row1out  0<PORTA.OUT
#define row1dir   0<<PORTA.DIR // code for 4x4 matrix keypad, row 1 is connected to PA0
Is this the right way to select a single bit and manipulate it later in the program like this?
row1out = 0;
Should'nt this make the bit 0 of the a PORTA low?
Currently confused in this.
Using C code.
Nitin Shenoy
I think you need to read this tutorial:
That explains all this stuff. The isolation of a bit is achieved using AND/OR
This is actually fundamental computer science and nothing specific to AVR. There is an argument to say that it's quicker/easier to learn the fundamentals of programming by doing it on a PC than using an AVR (or any other) micro!
For example if I go to:
https://www.onlinegdb.com/online...
and type in:
#include <stdio.h>
#include <stdint.h>
uint8_t data = 0xD2;
int main()
    int i;
    for (i = 0; i < 8; i++) {
        printf("%c\n", (data & (1 << i)) ? '1' : '0');
    return 0;
Then I get:
That has broken apart the original 0xD2 I started with into individual 1's and 0's.
It was far easier to test this in about a minute on that website than it was to fiddle about trying to do it on an AVR. The key to that code is:
data & (1 << i)
This is testing each bit of data individually.
If you follow the link to the tutorial you will see that the "(1 << n)" style of construct is used a lot when doing this.
EDIT and I just spotted that the bits came out "backwards" as my i was counting 0..7 when really I meant it to be 7..0. So I can change the for() loop to be:
for (i = 7; i >= 0; i--) {
Then I get:
Thanks for this info!. I will surely go through it.
Nitin Shenoy
