Why interupt affect loading from program memory?
9 posts / 0 new
it is snapped from data sheet ?
I am living to bring up new earth ,and not to eat and destroy earth.
Google instruction pipeline
I know That the avr micro controller that i am using now  is single pipeline due to the architecture of harvard
what is the relation of pipeline ?
No, it's Modified Harvard because you can access program as if it were data. But I wouldn't get too worried about what 'type' of architecture it is; it tends to be a pointless discussion in anything other than academic research.
And you can have a pipeline, or not, in any type of architecture.
but this was a reply for the main question what is the relation between interrupt affect loading from program memory and  pipeline ?
Hang on, we're talking xmega here aren't we?
AFAIK, on the xmega, the LD instruction cannot load data from the flash space as it is not memory mapped.
If you look at the whole of that footnote...
..you will see that note 2 does not apply to xmegas.
Since you posted the same question in the UC3 section, can we start by clarifying which chip family we are talking about.
i am only asking the question how it happened
i read it and i wondered
Remember - we didn’t design the chip, so we can only infer what might happen.
Historically, interrupts are usually sampled before an intruction fetch. With pipelines, the picture changes as a fetch might be done in parallel with an instruction issue. If an interrupt is pending, then the pipeline might need to be flushed maybe incurring a 1cycle penalty. This is speculation on my part as i’ve not used an xmega part nor looked into its microarchitecture.
