Compiler not generating assembly code for corresponding C code (maybe due to optimization)
7 posts / 0 new
I hope this is a relevant place for this!
I am working with the ATTINY45 and i am having problems with the compiler not generating assembly part of the C code, which i observed when i had a look at the .lss file. The relevant C code snippet is as follows:
volatile uint16_t counter = 0;
volatile uint8_t flag_reg = 0;
#define msflag	0
#define setmsflag()	flag_reg |= (1<<msflag)
#define clearmsflag()	flag_reg &= ~(1<<msflag)
#define sflag	1
#define setsflag()	flag_reg |= (1<<sflag)
#define clearsflag()	flag_reg &= ~(1<<sflag)
ISR(TIMER0_COMPA_vect)
	counter++;
	// part where ms flag is checked
	if ((flag_reg & (1<<msflag)) == 1)
		if ((counter%50) == 0) PORTB = PORTB ^ (1<<3);
	// part where s flag is checked
	if ((flag_reg & (1<<sflag)) == 1)
		if ((counter%500) == 0)
			counter = 1;
ISR(PCINT0_vect)
	// if PB0 is grounded, respond to a Mode interrupt
	if((PINB & (1<<0)) == 0)
		// Mode interrupt
		clearsflag();
		setmsflag();
	// if PB1 is grounded, respond to a Change interrupt
	else if((PINB & (1<<1)) == 0)
		//Change interrupt
		clearmsflag();
		setsflag();
counter - a variable that increments every 2ms.
flag_reg - A register with abstract flag definitions.
msflag - a flag defined for the flag_reg variable(to refer to millisecond interrupts).
sflag - a flag defined for the flag_reg variable(to refer to second interrupts).
I have gone step by step to check that all my ISRs work and all my hardware(circuits) works as well. All pieces work properly individually.
My problem: Following part in my TIMER0_COMPA_vect ISR does not generate any assembly code:
			counter = 1;
This is the generated assembly code for reference:
1. Vector Loaction for TIMER0_COMPA_vect ISR in the vector table
14:	15 c0       	rjmp	.+42     	; 0x40 <__vector_10>
2. Assembly code for the TIMER0_COMPA_vect ISR
00000040 <__vector_10>:
	PORTB &= ~(1<<3);
void LEDon()
	PORTB |= (1<<3);
  40:	1f 92       	push	r1
  42:	0f 92       	push	r0
  44:	0f b6       	in	r0, 0x3f	; 63
  46:	0f 92       	push	r0
  48:	11 24       	eor	r1, r1
  4a:	5f 93       	push	r21
  4c:	6f 93       	push	r22
  4e:	7f 93       	push	r23
  50:	8f 93       	push	r24
  52:	9f 93       	push	r25
  54:	af 93       	push	r26
  56:	bf 93       	push	r27
  58:	80 91 61 00 	lds	r24, 0x0061	; 0x800061 <counter>
  5c:	90 91 62 00 	lds	r25, 0x0062	; 0x800062 <counter+0x1>
  60:	01 96       	adiw	r24, 0x01	; 1
  62:	90 93 62 00 	sts	0x0062, r25	; 0x800062 <counter+0x1>
  66:	80 93 61 00 	sts	0x0061, r24	; 0x800061 <counter>
  6a:	80 91 60 00 	lds	r24, 0x0060	; 0x800060 <_edata>
  6e:	80 ff       	sbrs	r24, 0
  70:	0d c0       	rjmp	.+26     	; 0x8c <__vector_10+0x4c>
  72:	80 91 61 00 	lds	r24, 0x0061	; 0x800061 <counter>
  76:	90 91 62 00 	lds	r25, 0x0062	; 0x800062 <counter+0x1>
  7a:	62 e3       	ldi	r22, 0x32	; 50
  7c:	70 e0       	ldi	r23, 0x00	; 0
  7e:	59 d0       	rcall	.+178    	; 0x132 <__udivmodhi4>
  80:	89 2b       	or	r24, r25
  82:	21 f4       	brne	.+8      	; 0x8c <__vector_10+0x4c>
  84:	98 b3       	in	r25, 0x18	; 24
  86:	88 e0       	ldi	r24, 0x08	; 8
  88:	89 27       	eor	r24, r25
  8a:	88 bb       	out	0x18, r24	; 24
  8c:	80 91 60 00 	lds	r24, 0x0060	; 0x800060 <_edata>
  90:	bf 91       	pop	r27
  92:	af 91       	pop	r26
  94:	9f 91       	pop	r25
  96:	8f 91       	pop	r24
  98:	7f 91       	pop	r23
  9a:	6f 91       	pop	r22
  9c:	5f 91       	pop	r21
  9e:	0f 90       	pop	r0
  a0:	0f be       	out	0x3f, r0	; 63
  a2:	0f 90       	pop	r0
  a4:	1f 90       	pop	r1
  a6:	18 95       	reti
Thanks for the Help.
Ninad_G
This will never be true. The compiler knows this, and omits the whole code block.
Try:
"Read a lot.  Write a lot."
Ninyo_97 wrote:
#define sflag	1
		// can not get here
Since sflag is 1 and (1<<sflag) is 2, the compiler
realizes the if argument will always be false.
Change the test to:
if (flag_reg & (1<<sflag))
--Mike
EDIT: I must type too slowly.....  ;-)
Thanks so much. It worked!
Thanks a lot @joeymorin! ciao :D
Ninad_G
Yeah, That seemed to work and the explanation makes sense! Can't imagine how much time i was stuck on that one! Thanks a lot @avr-mike..
Ninad_G
Is there a compiler option that warns about that sort of thing?
"SCSI is NOT magic. There are *fundamental technical
reasons* why it is necessary to sacrifice a young
goat to your SCSI chain now and then." -- John Woods
None that I know of (GCC), but I don't know much ;-)
Perhaps lint or other static tools could catch it.
