Ben Heck's tiny10
8 posts / 0 new
by Benjamin J Heckendorn
How to use the Atmel ATTINY10 Microcontroller - YouTube (53m)
  • 12V reset for TPI onto his tiny10 protoboard
  • Atmel Studio 7 demonstrations
  • soft UART transmit
  • ADC reads a Hall effect sensor
Smaller than a grain of rice !? !?  :-(
https://youtu.be/ra7bT74EGUs?t=812
and the protoboard that Ben started with :
RadioShack - Grid-Style PC Board 750 Holes
Proposed different tacks on Ben's project :
  • tiny10's follow-on is tiny102 (unified memory, self-programming, bootloader, USART or SPI master, 10b ADC, more)
  • MPLAB PICkit 4 has Vpp and the TPI issue was fixed in MPLAB X v5.10
  • tiny102's follow-on is tiny202 (tinyAVR 0-series : UPDI, etc)
  • 1.27mm pitch SMT instead of 2.54mm pitch THT
via https://plus.google.com/u/0/106109247591403112418/posts/VTHGwo1TyJZ
ATtiny10 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
RadioShack - Prototyping Boards & Wire
ATtiny102 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
tiny102's on sale at Digi-Key :
https://www.digikey.com/product-detail/en/ATTINY102-SSFR/1611-ATTINY102-SSFRCT-ND/6833015
AN_42676 AT13053: Differences between ATtiny4/5/9/10 and ATtiny102/104 | Application Notes | Microchip Technology Inc.
ATTINY202 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
Surface Mount Prototyping PCBs | BusBoard Prototype Systems
edit: SMT
https://youtu.be/ra7bT74EGUs?t=648 for about 2m where Ben does a SMT how to.
IIRC, desoldering braid can also damage a PCB due to excessive heat causing lifted pads or traces, soldering mask damage (etc?)
Ben's method of a clean and tinned tip drawing up excessive solder is easier (solder moves towards heat)
A chisel tip can be used to push solder to the pin if there's enough solder (HASL or tinned pad) and flux.
Drag soldering with flux by a hoof tip is fast (a drop of solder on the hoof)
1/2 X 25/64 (12.8 X 10mm) 10 Pin SOT/SOP Adapter Breakout B | MPJA.COM
edit : MPJA
Huh.  I watched some of Heck's videos back when Element14 first started up, and wasn't very impressed (seemed to be a lot of mechanical engineering and re-shaping, rather than the EE and CS I was more interested in.)
But I thought this one was quite good.  Especially the pacing of the software-writing - not too slow, but not too complex, either.  Showed going back and forth between the datasheet and studio, just like real life...  And he wrote comments!  Useful comments in places where comments were a good idea.  My biggest complaint was the use of binary numbers where perhaps symbolic constants should have been used (not that Atmel's "(1<<WGM00)+(1<<WGM01)" is much clearer than "0b0011"... (sigh.))
Perhaps, but (3<<WGM00) immediately tells me mode 3.
I usually use something like
const uint8_t wgm = 3;
const uint8_t com = 2;
TCCR0A = (com << COM0A0) | ((wgm & 3) < WGM00);
TCCR0B = ((wgm >> 2) << WGM02) | (1<<CS00);
... for clarity.
I dunno,  a simple look at the datasheet would tell you what "(1<<WGM00)+(1<<WGM01)" is all about,  I myself prefer this method.
No Doubt.
Joey's method:
... for clarity.
Kinda makes my head ache, but hey whatever works for you....smiley
JIm
I don't >>always<< do that... but often.  All it does is boil down the TCCRnx assignments to a boilerplate that never changes.  Only the modes (timer, compare) change.  Having them lifted out of the assignment makes things a bit clearer I find.
I left out the prescaler, but I sometimes lift it out as well:
const uint8_t wgm = 3;  // WGM mode 3.
const uint8_t com = 2;  // Compare mode 2.
const uint8_t pre = 1;  // /1 prescaler.
TCCR0B = ((wgm >> 2) << WGM02) | (pre<<CS00);
Obviously different devices have different timers, and some variation on what bits are where, and how many of them there are, but I still find it helpful.  You could also stuff all of that into an inlined function with no penalty.  YMMV of course.
Sorry for the OT.
