I hope this is a relevant place for this!
I am working with the ATTINY45 and i am having problems with the compiler not generating assembly part of the C code, which i observed when i had a look at the .lss file. The relevant C code snippet is as follows:
volatile uint16_t counter = 0; volatile uint8_t flag_reg = 0; #define msflag 0 #define setmsflag() flag_reg |= (1<<msflag) #define clearmsflag() flag_reg &= ~(1<<msflag) #define sflag 1 #define setsflag() flag_reg |= (1<<sflag) #define clearsflag() flag_reg &= ~(1<<sflag) ISR(TIMER0_COMPA_vect) { counter++; // part where ms flag is checked if ((flag_reg & (1<<msflag)) == 1) { if ((counter%50) == 0) PORTB = PORTB ^ (1<<3); } // part where s flag is checked if ((flag_reg & (1<<sflag)) == 1) { if ((counter%500) == 0) { PORTB = PORTB ^ (1<<3); counter = 1; } } } ISR(PCINT0_vect) { // if PB0 is grounded, respond to a Mode interrupt if((PINB & (1<<0)) == 0) { // Mode interrupt clearsflag(); setmsflag(); } // if PB1 is grounded, respond to a Change interrupt else if((PINB & (1<<1)) == 0) { //Change interrupt clearmsflag(); setsflag(); } }
counter - a variable that increments every 2ms.
flag_reg - A register with abstract flag definitions.
msflag - a flag defined for the flag_reg variable(to refer to millisecond interrupts).
sflag - a flag defined for the flag_reg variable(to refer to second interrupts).
I have gone step by step to check that all my ISRs work and all my hardware(circuits) works as well. All pieces work properly individually.
My problem: Following part in my TIMER0_COMPA_vect ISR does not generate any assembly code:
This is the generated assembly code for reference:
1. Vector Loaction for TIMER0_COMPA_vect ISR in the vector table
14: 15 c0 rjmp .+42 ; 0x40 <__vector_10>
2. Assembly code for the TIMER0_COMPA_vect ISR
00000040 <__vector_10>: PORTB &= ~(1<<3); } void LEDon() { PORTB |= (1<<3); 40: 1f 92 push r1 42: 0f 92 push r0 44: 0f b6 in r0, 0x3f ; 63 46: 0f 92 push r0 48: 11 24 eor r1, r1 4a: 5f 93 push r21 4c: 6f 93 push r22 4e: 7f 93 push r23 50: 8f 93 push r24 52: 9f 93 push r25 54: af 93 push r26 56: bf 93 push r27 58: 80 91 61 00 lds r24, 0x0061 ; 0x800061 <counter> 5c: 90 91 62 00 lds r25, 0x0062 ; 0x800062 <counter+0x1> 60: 01 96 adiw r24, 0x01 ; 1 62: 90 93 62 00 sts 0x0062, r25 ; 0x800062 <counter+0x1> 66: 80 93 61 00 sts 0x0061, r24 ; 0x800061 <counter> 6a: 80 91 60 00 lds r24, 0x0060 ; 0x800060 <_edata> 6e: 80 ff sbrs r24, 0 70: 0d c0 rjmp .+26 ; 0x8c <__vector_10+0x4c> 72: 80 91 61 00 lds r24, 0x0061 ; 0x800061 <counter> 76: 90 91 62 00 lds r25, 0x0062 ; 0x800062 <counter+0x1> 7a: 62 e3 ldi r22, 0x32 ; 50 7c: 70 e0 ldi r23, 0x00 ; 0 7e: 59 d0 rcall .+178 ; 0x132 <__udivmodhi4> 80: 89 2b or r24, r25 82: 21 f4 brne .+8 ; 0x8c <__vector_10+0x4c> 84: 98 b3 in r25, 0x18 ; 24 86: 88 e0 ldi r24, 0x08 ; 8 88: 89 27 eor r24, r25 8a: 88 bb out 0x18, r24 ; 24 8c: 80 91 60 00 lds r24, 0x0060 ; 0x800060 <_edata> 90: bf 91 pop r27 92: af 91 pop r26 94: 9f 91 pop r25 96: 8f 91 pop r24 98: 7f 91 pop r23 9a: 6f 91 pop r22 9c: 5f 91 pop r21 9e: 0f 90 pop r0 a0: 0f be out 0x3f, r0 ; 63 a2: 0f 90 pop r0 a4: 1f 90 pop r1 a6: 18 95 reti
Thanks for the Help.
