SNTP Timestamp date and time
10 posts / 0 new
How to correctly convert a timestamp from SNTP protocol to an accurate date and time?
That’s a pretty broad question that’s covered by RFCs.
Its not documented in the RFC that I can see.
I have just figured out the Time must be in (UTC) Coordinated Universal Time and is giving accurate results.
I assume I'm working off the Gregorian Calendar, sounds to be standard. Do you need to calculate all leap years going back to 1 January 1900.
Assume you cant just use the average 365.2425 days in year? Must be a simple way of getting the year and day?
    I have in mind this question since a while and I was going to ask the same thing at one point.
    Arduino has an example about this. You need to account for leap seconds as well.
    As a practical way I would calculate the seconds up to the beginning of 2019 and only deal with what is left. I think the future leap years are known in advance. Not the same for the leap seconds. So, I would have a constant for the total leap seconds and set it manually once they occur. For the leap years, just a switch construction.
    I would like also to hear other good ways to implement this.
Leap years occur every 4 years, except when
the year is divisible by 100 without also being
divisible by 400:
bool is_leap_year = ((year % 4) == 0);
if ((year % 100) == 0) {
    is_leap_year = ((year % 400) == 0);
--Mike
Kartman, if it is in the RFC's can you share which one
Use the time.h library. There is one, I believe, built into avr-libc but, if not, just google avr time.h  Its on Savannah.nongnu.org as well as other places. EVERYTHING is there. Has provisions for geographical offset from UTC, as well as daylight saving time. It is derived from the standard time.h library.
Got it sussed, I'm summing all days 365/366 of each year since 1900, until I reach the year in the timestamp, this gives the year. I use the remaining days to calculate the day and month.
Accounting for leap years(28/29 days in Feb).
I'm using the code above for testing for leap years.
I add a constant to the timestamp to adjust for NZ UTC time before doing anything.
As mentioned above I could add a pre calculated constant and start looping from say 2018 to improve performance.
Just have to figure out Daylight Savings Time adjustment now...
Save your energy (and time). Its all in time.h
Yep I see that, thanks.
I used that for checking
I was almost there, had to finish what I started laugh
