Did I see something about 24 bit integer support in AS7?
5 posts / 0 new
Hi Everyone,
Should there be a uint24_t ?
I am processing a grid keyboard in an ISR and I've always been able to fit them into a single 32 bit variable.  This time I have 34 inputs and am trying to think of the best way to deal with it.  It is a 6x6 grid, so I was thinking of 6 uint8_t's, but then to test for a key, I have to compare all 6 bytes.  I realize it is doing that anyway even when using uint32_t when it compiles.  The ISR debounces it into the "34 bits" and then a later process in the main loop decodes the bits into an actual "key" and puts it in a buffer for processing.
So, processing 34 input bits in an ISR, how would you do it?
Alan
I vaguely recall that 24 bit had something to do with pointers to allow for larger memory devices and that it was not a true data type tike uint24_t.
https://gcc.gnu.org/wiki/avr-gcc#Types
Types
  • Signed and unsigned 24-bit integers: __int24 (v4.7), __uint24 (v4.7).
I don't get your question (maybe the muscle relaxants haven't worn off). How could __unt24 help with a 34 bit data structure?
Hi Joey,
I was thinking it would simplify:
        if ((InputState[0]!=AInput[0] || InputState[1]!=AInput[1] || InputState[2]!=AInput[2] || InputState[3]!=AInput[3] || InputState[4]!=AInput[4] || InputState[5]!=AInput[5]) && InputDebounceCount>=3)
into:
        if ((InputState[0]!=AInput[0] || InputState[1]!=AInput[1]) && InputDebounceCount>=3)
If each were 24 bits, but I suppose I could just do a uint32_t and uint8_t the same way and be 8 bits ahead of the game...
