adiw in assembly
5 posts / 0 new
Hi Guys,
Just wondering an easier way to do this:
	adiw	XL,63				;most we can do here is 63
	adiw	XL,1				;so do it twice
Assembly only please. (NO C.)
I am trying to add 64 to X every time in a loop.
Just don't understand why I can only do 63?
The above code works, just thought there might be a better way.
I don't see a way to do it in less than 2 instructions. There is a more general way, though, that is subtracting -64 (0xFFC0) from XH:XL. Subtracting -64 is equivalent to adding 64, this is needed because there is no "adci" instruction.
subi XL, 0xC0
sbci XH, 0xFF
With this method you can add a larger range of numbers than with 2x adiw (and it's faster because adiw takes 2 cycles).
Have you read the AVR Instruction Set document?:
The instruction encoding allows for only 6 bits for the immediate value, which is unsigned.  Hence the range 0-63.
The only reason to use adiw is to save a word of flash when the immediate operand is within that range.  If it is not, use subi and sbci.  It both approaches have the same cycle cost.
El Tangas wrote:
subi XL, 0xC0
sbci XH, 0xFF
But:
subi XL, lo8(-64)
sbci XH, hi8(-64)
... is clearer.
"Read a lot.  Write a lot."
Because that's how many bits (6) the designers decided to allow for the immediate value in the instruction.  Instruction set design and encoding is like tetris, trying to fit the most functionality into the limited number of instruction bits while leaving the fewest holes.
Good answer. Thank you
