LightweightRingBuff.h
4 posts / 0 new
I can not find any recent thread on this topic, so here is a new one.
I am attempting to use LightweightRingBuff.h and having compile errors.
It seems that there are several versions of his out in the wild including the LUFA version.
I am trying http://www.fourwalledcubicle.com/files/LightweightRingBuff.h
The example in the manual is not quit in sync with the version above.
http://www.fourwalledcubicle.com...
Error    1    expected declaration specifiers or '...' before '&' token    file:   deanSerialTestINT.c
This refer to the last line in the code snip
#include "LightweightRingBuff.h"
// Create the buffer structure and its underlying storage array
RingBuff_t rxBuffer;
RingBuff_Data_t     rxBufferData[BUFFER_SIZE];
RingBuffer_InitBuffer(&rxBuffer);
Also I am confused by the line (from the example in the manual)
Is this not defined in the struct?
I m using Atmel Studio 6.2 1153
KWC
The LUFA documentation is presumably talking about the "lightweight ring buffer" in .../LUFA/Drivers/Misc/RingBuffer.h, rather than the the one you found.   They're substantially different.
The code in #1 is clearly an excerpt and not the entire file (otherwise you have a function call outside of the body of a function!) so perhaps show the entire file?
Well now don't I feel silly. That is exactly the issue.  It seems I have found yet another way to make silly errors.
Thanks!
