AT89LP51ED2 Fuse programming
4 posts / 0 new
Hello everybody, I have started to programm AT89LP51ED2 controller. I want to run it in fast mode. It was run normaly on Compatibility Mode, but when I have tryed to run the controller in fast mode, nothing is going on, there is now any activity when i measuring signals with the scope. Any ideas?
Thanks.
Bojan Solin
Can you post what fuses you programmed and the interface you used?  That device allows you to pick your clock source.....maybe you accidentally changed this?
JIm
I am new to fuse programming. To change device state from Compatibilty to Fast mode, I am using this code, for read and write fuses:
EA=0;
FCON=0x04;
DSPR=0x00;
ACC=0x00;
ACC=DSPR;
EA=0;
FCON=0x08;
DSPR=0x06;
ACC=0x00;
DSPR=ACC;
FCON=0x00;
FCON=0x54;
FCON=0xA4;
FCON=0x00;
EA=1;
Is it possible to set fuses on this way? and in which code section is necessary to put the fuses code for fuses to be set?
I am using Atmel flip ISP programming interface.
Thank you in advence.
Best regards.
Bojan Solin
Moderator, please remove this post.
Greetings.
Bojan Solin
