mega328PB in VisualGDB
5 posts / 0 new
Sysprogs
Topic: Support for ATMEGA328PB
by asti
December 5, 2017
https://sysprogs.com/w/forums/topic/support-for-atmega328pb/
I’ve patched the existing BSP because I needed an immediate workaround,
https://sysprogs.com/w/forums/topic/support-for-atmega328pb/#post-13165
Thanks the for the update. We will try to include support for new devices in our next refresh of the AVR toolchain.
Prebuilt GNU toolchain for avr
http://gnutoolchains.com/avr/
VisualGDB Tutorials
Developing firmware for AVR devices with Visual Studio
https://visualgdb.com/tutorials/avr/
https://github.com/sysprogs/BSPTools/tree/master/DebugPackages/AVaRICEDebugPackage
Edit: AVaRICE
Is VisualGDB worth getting into?  Do you really enjoy using it (any severe pitfalls)? Is it more arm-wrestling than usingAS7?   Perhaps being able to easily move code to other types of targets (STM, PIC, etc) without being tied to Atmel/Microchip makes it wirth investigating.
No because Atmel Studio has "infinite value" wink
If you dis-like AVR in MPLAB X then VisualGDB is one of several alternatives.
VisualGDB is centered on arm Cortex and ESP32/etc (OpenOCD); AVR is an add-on (AVaRICE)
If PIC is a requirement then VisualGDB is not it though PIC32 should work as there are GDB servers for PIC32.
A recent competitor to Sysprogs VisualGDB is PlatformIO
PIO Unified Debugger
http://docs.platformio.org/en/latest/plus/debugging.html
A follow-on to that tutorial shows the further integration of AVR GDB into VisualGDB with a future product for AVR being something akin to Microchip Debug Executive.
Debugging Arduino AVR boards with Visual Studio – VisualGDB Tutorials
October 1, 2018
This tutorial shows how to debug the AVR-based Arduino boards using Visual Studio and the Advanced Arduino Project Subsystem of VisualGDB. Before you begin, install VisualGDB 5.4 Preview 4 or later, get an AVR debug probe (e.g. AVR Dragon) and follow our basic Arduino tutorial to create a simple project.
[debugWIRE enable caution]
[Atmel Studio for DWEN fuse]
[step 8]
As long as the AVR board is properly setup for debugging, VisualGDB will provide the same debugging experience as with any other supported target. The FLASH memory will be automatically programmed and VisualGDB will let you set breakpoints and step through your code. However, while the AVR chip is in the debugging mode, it will only run with a debugger connected and won’t let you use the bootloader for programming the FLASH memory.
[Atmel Studio, disable debugWIRE]
[bottom]
If you are debugging AVR-based Arduino boards frequently and would be interested in our experimental instrumenting debug engine that works over the regular COM port and does not require a separate debug probe, contact us via our support page for more details.
VisualGDB - Serious cross-platform support for Visual Studio
VisualGDB - Download
Debug Executive - Developer Help
