Programming AT90S8515
49 posts / 0 new
I have some old hardware which uses an AT90S8515, I also have two .hex files, one for flash the other for EEPROM. My problem is I can't find a way to program the old hardware with these .hex files. I have a JTAGICE3 programmer and have downloaded the latest studio6.2 software, but that is where it stops. Can anyone tell is it possible to achieve what I want with the tools that I have and if so what are the steps? If not, then does anyone know what I need?
Todd
Hello, and welcome Todd -
The AT90S devices are really, really, old. I'm not even sure where to find a spec sheet, though there must be some out on the net somewhere. I am not surprised, in the least, that they are not listed as a supported device.
Not sure what to suggest. Hopefully, one of the "old timers" might have some better information.
Thanks Jim, yes I think they were one of the first AVRs that Atmel produced.
Todd
I just fired up my "old" AVR Studio Ver 4.x and mkII, to see if it was a supported device. It isn't.
Sorry.
Well, OP didn't ask for advice. OP asked whether he could use his new mid-range SnapOn engine analyzer on his 1951 Chevy pickup truck.
If you want to change the timing on your 1951 Chevy pickup truck I can indeed recommend tools, but it won't involve the new SnapOn.
Thanks for trying JC!
Whaddya mean old?....
But supported with AVRISP MK1 or STK500.
Hi John,
Thanks for the information. I was trying to use what I had inhouse but I may have to reconsider and go out and purchase a STK500 kit. My only concern is will the software run on either a windows 7 or windows 8 PC?
Todd
AS4.18 runs on WIN7 no idea about WIN8.
Cheers!
About your age...? :wink:
I would be 100% confident that avrdude will be able to understand a AT90S8515. And presumably send the relevant commands to any of the hardware programmers.
Just try:
avrdude -c jtag3isp -P USB -p AT90S8515 -B5
You will need the latest avrdude to know jtag3
I don't have the latest avrdude. Nor a JTAGICE-3.
Or you could use an old avrdude with a USBASP, Arduino, ...
If you have the source code, I would recommend replacing the AT90S8515 with a ATmega8515 and recompiling.
Hi David,
Thanks for the suggestions, I will give them a try.
Todd
I didn't even think to check the STK500. :oops:
Of course the follow up question is how long one wants to support the old chip, vs redoing the project with a current micro.
The ATmega8515 and ATmega8535 have 90Sxxxx compatibility fuses so, in theory, one should be a be to run the old code without recompiling.
It has been a long time since I used those chips bit I think it worked.
I only have a handful of these boards left so once they are gone the product will be discontinued so the minimum amount of time and effort is what I'm really after.
It is good to know that I could always use the ATmega8515 if there is ever a need to bring the product back to life at a later date.
In the meantime I'm pursuing the use of AVRDUDE.
Todd
AND the Mega162 which is also pin compatible but you will need to change some bits of the code and recompile. You get 16K flash and 2 serial ports unless the pins are already used for something else.
Thanks John
Hey
i have problem while burning the AT90S8515-8PC. Later i used the controller AT90S8515-8PI with ponyprog, but now i have purchased AT90S8515-8PC controller , out of 10 only 1 is programmed remaining 9 shows the error (-25)i.e. unknown device or device locked. i am using Serial programming.These controller easily programmable through LABTOOL but i have to burn device file and eeprom file, so the conclusion of LABtool i get to knows it burns only one file at a time.
please give me solution of this problem, i got stuck in this from last one week
Go on.   The AT90S8515  is obsolete.    It was replaced by the ATmega8515 over 12 years ago.
Avrdude should be able to control the programmer.    Note that programming AT90S8515 is much slower than the ATmega8515.
I would never trust PonyProg.
I would never trust a shop / Ebay that sells obsolete AT90S8515 chips.
is there any way to programme the AT90S8515-8pc, Actually i have  100 ics of same .
Yes, of course you can. STK500, USBASP, ...
Most programming hardware is capable.
Avrdude.exe or stk500.exe should work.
Be realistic. Someone sold 100 obsolete chips to you. You paid them money.
There is a reason why they wanted to get rid of obsolete stock.
Modern chips would be cheaper. Modern chips would have better performance. Faster to program.
there is still 4 pcs. if you are lucky you can add them to your 100 pcs
The chips might be bona-fide stock that has been sitting unused in a warehouse for 18 years.
The chips might be pulls from unused equipment.
The chips might be pulls from used equipment.
The chips might be QC failures or pulls from faulty equipment.
When you Google AT90S8515-8PC  you get Ebay adverts quoting very HIGH prices.
If you are maintaining / repairing old equipment,   it is probably cheaper to use the pin-compatible mega8515 as replacement.
Hey-ho,   you can always try selling your surplus AT90S8515-8PC on Ebay.
That chip appears to have a fuse bit that disables SPI programming. If that bit has been set then you will need to use a parallel programmer to clear it. (or at least, that's how I read the datasheet).
ok i have USBASP , I'll try with that.
if i want to replace AT90S8515-8PC with ATMEGA8515 , what changes i have to made in code ?
is same code run over it or i have to change some settings?
I havent seen the DS but highly probably I assume that you have to. What the guys here are trying to advice you in conclusion is that you should change it now better than saying "what if..."
Explain your situation.   i.e. used/unused chips.   Then you can get practical advice.
All 90S8515 need an external crystal or clock.
They should program via ISP.     Just SLOWLY.
Do you have the source code for the 90S8515 firmware?
Unless the firmware does trickery,   you simply replace with a mega8515.   Program the S8515C fuse.   Program the fuses for 8MHz crystal (or whatever your existing 90S8515 uses)
AVR085: Replacing AT90S8515 by ATmega8515
(page 9)
Other Concerns
ATmega8515 uses page-by-page programming, while AT90S8515 uses byte-by-byte programming of Flash memory.
via AN_2519 AVR085: Migrating from AT90S8515 to ATmega8515 | Application Notes | Microchip Technology Inc.
I have never used a 90S8515.    But I can remember programming a 90S2313.   It was painfully SLOW and it only had 2kB Flash.   The 90S8515 has four times as much Flash memory to program.
"Slowly" includes the bitrate of the ISP clock to accomodate the default speed of the virgin device.  Things could be that simple.
From distant memory,   the SPI speed is the same for 90S as for MEGA  i.e. <=  F_CPU/4
As Mr Chapman has pointed out,   the SLOWNESS is down to individual byte programming.
If the nominal programming time is 5ms,   8kB x 5ms = 40960 ms.    But 64 pages of 128-bytes is 64 x 5ms takes 320 ms.
No,   I have not checked the mega8515 Page size.    Nor the typical programming time.
AN910 is probably the second AVR programmer I used.
First was Pony Prog (or similar, and only once) to program AN910.
AN910 is an Atmel application note (& software) to build your own programmer. It uses an at90s2313 to translate between RS232 and ISP.
It is slow, but it works. And I believe AT90S8515 is inherently slow because it programs 1 byte at a time.
More modern AVR's have small pages, you load 8 bytes into some (invisible?) buffer, and then program those 8 bytes into flash.
Programming stuff into flash has inherent delays.
AVRdude can control a lot of different hardware. If you have an old PC with an LPT port, then avrdude can program your at90S8515 with it.
If you have a beaglebone, Raspi, Cubie board or another small Linux board with GPIO pins, then AVRdude can program your at90s8515 with it.
I also se no reason to not trust something like Ponyprog.
Even old chips such as at90s8515 effectively program themselves. A "programmer" is nothing more than some communication channel between a (usually) PC and the target to exchange data, and commands.
Compare this with for example old Eproms. (Such as 27c128, 27c256, or any number starting with "27" and ending with a round power of2).
Those chips had specific voltages to apply and pulsewidths (Very old were 24V or 25V, newer versions were around 12.5V).
In programmers for those chips programer quality is an importent factor.
If the pulsewidth or voltages were wrong, you would damage the chips and they would never work again.
But for more modern chips which program themselves it either works or it does not work, and chips are verified after programming, So you know if it worked or not.
Programming of more modern chips (And I call at90s8515 "modern" in this context) still use the high voltage, but they have an on board charge pump to generate that voltage.
The high voltage is used to channel some electrons through an isolation barrier on the individual FLASH memory cells, so it needs very little current, but it neads to reach the threshold voltage.
TL866A is an Ali / Ebay / China special and it seems to be an amazing programmer for it's price, but software is mostly windoze, so it's useless to me.
Personally I'm quite happy with those small serial gadged programmers (I have USBasp for AVR, and ST-Link V2 for STM32), and I have not much use for a parallel programmer.
A quick search suggests that USBasp can also program the AT90S8515:
https://duckduckgo.com/html?q=usbasp+at90s8515
But if you want to do some "serious" development and re-program the chip a lot then  using some atmega8515 chips for development seems a good idea just because of the much faster programming.
Paul's comments are misleading.
I thought that I had better check.
AT90S8515 program time per byte = 4ms @ 5V
ATmega8515 page size = 64 bytes.   Program time per page = 4.5ms.
There is a similar amount of comms traffic from the PC to programmer
Total programming time is 32768 ms for 90S8515  (8192 bytes @ 4ms)
Total programming time is 576 ms for mega8515  (128 pages @ 4.5ms)
PonyProg software was not very intuitive when it came to Fuses.
LPT bit-banged programmers were prone to glitches.
You only have to go back 10-12 years on this Forum to discover the problems from PonyProg and/or LPT hardware.
You also see things like bit-banged SPI over a USB-UART chip.     e.g. 45 minutes to program a Mega32.
Just buy a $3 USBASP and get on with the more interesting parts of the hobby.
As the AT90S did not have internal oscillators I wonder if this is all really about dodgy clocks?
The mega8515 is not 100% compatible with the 8515
I remember that an old costumer asked me to make the changes when the 8515 got obsolete (I can't remember what is was but only some init values I think.
(it was all written in the old Atmel ASM where there was an rjmp error so any changes was a pain).
Why?
AT90S8515 program time per byte = 4ms @ 5V ATmega8515 page size = 64 bytes.   Program time per page = 4.5ms.
>> 64*4/4.5
ans =  56.889
So programming the old 90S is about 60x slower than a more modern variant.
I never claimed PonyProg was the best programming software around, just that it CAN be used and has been used (10+ years ago).
I do not care much for digging up the details, but I'm sure that most of the problems were because of dodgy wiring, bad breadboards, forgetting decoupling caps and such.
Using an LPT inconveniently placed at the back of a PC under your desk is an invitation to build something unreliable, especially for inexperienced beginners. And inexperienced beginners are the target group of the Pony Prog software. So it is logical you can find lots of troubles, but the Pony Prog software is not to blaim for that.
I also said I only used it once to progam a better programmer (AN910). Which I used for some years untill I upgraded to USBasp.
Back then the PonyProg software was a real nice project to bootstrap yourself into working with uC's on a small budget.
If interested into the differences between AT90S8515 and ATMEGA8515 then check out doc 2519, aka AVR085:
You can never have 100% compatibility. If the OP revealed the origin of these obsolete chips we would know whether it is worth the trouble.
But most importantly, does the OP have the source code or just the HEX?
If we could see the source code, we could give a reasonable opinion about mega8515.
Accessing undocumented register bits or assembler tricks can be difficult to predict.
Most C programs obey all the rules.
After Re-reading OP's post it seems he only has some hex files and existing hardware with AT90S8515 already fitted and he just wants to put his hex files into those AVR's with the programmer he has.
No mention whatsoever about porting code or a desire to use an ATmega.
Oops, got myself bitten again:
OP's post was from 2014 and it was revived by prajapati1709 in #19
I am surprised I did no have a reply from years ago in this thread!
I do now :)   This one is for posterity.
Have dozens of these obsolete time wasters. Have 2 Ice200s too.  Useful if one wants to connect a lot of external memory at the cost of any reasonable clock speed.
There is an Arduino core for it.  No boot loader though.  One has to save the hex file from the arduino IDE,  then use an external programmer to upload.  I managed to get a serial sketch to work.  Attempted to connect an ILI9341 TFT screen.  Was painfully slow, but the Adafruit demo sketch did run.
other that the max speed is 8MHz and no HW MUL it's about the same as a mega8515 so why all the comments about " painfully slow " ?
That refers to the programming speed -- review the comments and stats above on "byte mode" vs. "page mode".
That said, how often will you be programming your small stash of long-obsolete chips?  If you have a few of those chips and ISP a few dozen times, then you lose a couple minutes out of your life if you just sit there and stare at the progress bar.  More likely you prepare the next unit, put away the previous unit, take a sip of coffee, ogle your favourite body (a "unisex" comment) in the office, get more coffee, take a pee, check email, or similar such that it isn't wasted.
The chips I have are the 4MHZ grade.  It is not the processor that is slow, it is the updates through the HW SPI to the ILI9341 TFT display.  You can almost watch the pixels write.
Most Arduinos expect a F_CPU of 16 megahertz.  4 MHz is a quarter of that.
The external memory also can slow things down, Especially if the memory needs wait states for true 8051 compatibility.  Not that this affects much MIDI processing MIDI is happy at a clock of 1 Mhz which is what the Apple ][+ did.  So by comparisons this is a speed demon.
Sometimes I think that time is at it's best when wasted.  Enjoy the moment.  (Sempre momenta.)  Everything becomes obsolete sooner or later.
I compiled a handfull of examples for those ILI TFT's (Adafruit & RinkyDink).
With "Adafruit" on "Arduino" they use a digitalWrite() to latch the data into the display. Replacing those 2 lines with a direct bit set/clear almost doubles the data transfer for the parallel version of that lib.
Then there is the redicilous "pinmagic.h" which is a contortion to force hardware together that does not fit.
I thought a bit about it, and then quickly discarded the whole Idea of matching an AVR with a TFT display.
It does sorta work a little bit for static menu's, but that's about it and it is not a well fitting combination.
For me this was the main reason to start looking into faster microcontrollers.
Something like STM32F103C8T6 is a good fit for these displays.
Just look on youtube for some demos of the DSO138 or DSO Shell.
This processor can do somewhere between 5 and 10 screen updates/s.
This demo pushes "big buck bunny" at 8fps to an ST7781:
https://www.youtube.com/watch?v=9n9LHX6vwKc
On top of that, the "Blue Pill" development board costs < USD2 and is breadboard friendly, and a programmer (ST-Link V2) costs about the same.
http://www.aliexpress.com/wholesale?SearchText=STM32F103C8T6
They are also supported by GCC, just like the AVR's.
The only things holding you back are the learning curve, which is quite a roller coaster, and the overwhelming amount of choices of other ARM Cortex X controllers.
With those uC families you can get to a few hundred MHz and a gazillion pins if you want or need it.
A processor like the ESP8266 (or even faster ESP32) can reach quite acceptable refresh rates on the SPI versions of those TFT displays, also with plenty of demo's on youtube.
The AVR's  also quickly run out of resources for storing fonts, bitmaps or screen buffering.
I've always liked the AVR processors, and still do, but not for such displays.
If you're intested in ARM, then have a look at the mbed website. It has an overview of 100+ developmentboards from a multitude of manufacturers:
https://os.mbed.com/platforms/
I know this is an old thread revived but it is "current" as of December 7, 2018.
I'm actually working with a few of the 8515's I have in stock, just for grins and ran across this thread.
I had an issue using the AVR DRAGON under STUDIO 4.19 because the AT90S8515 was not available as a part selection from the list of supported MCU's. Then I selected "use the part selected for the project" and was able to program. Fuse and Lock bit support, however, isn't working.
With the AT90S8515-8PC running 8MHz @ 5 volts and avrdude using the "-B 1MHz" option, I can verify ISP avrdude programming with the following programmers:
* USBTiny - took 36 seconds to program ~4300 bytes but fuse support is defunct as avrdude complains with read operation not supported for memory "fuse", which is a listed memory type in the avrdude.conf file.
* USBASP (V2.0) - took 36 seconds to program ~4300 bytes but fuse support is also defunct as avrdude complains with read operation not supported for memory "fuse" , which is a listed memory type in the avrdude.conf file.
* AVR DRAGON - took in excess of 850 seconds for a ~4300 byte FLASH file. Same fuse support error as above.
* TL866A using parallel-programming works fine using WINDOWS and Linux command line interface (minipro Build:20181003.171847). Interestingly, fuses ARE supported.
* TL866A using ISP is not supported under WINDOWS but the Linux command line interface (minipro Build:20181003.171847) does access the 8515 and reads but writes are defunct.
Hope that helps.
Peace and blessings.
That is strange,  I just checked my copy of studio 4.19 build 730 on XP. There are the AT90 series options including the AT90S8515 when I select the Dragon under the connect menu.  As I do not have one connected I opened the disconnect mode and looked under fuses,  there are only two, one for SPI enable and the other for Fast restart.  FSRST.
Lockbits only have one option which is to lock.
Did you perhaps accidentally misprogram the SPI fuse bit?
Given that there are some .hex files from the Arduino IDE in the downloads folder, I am fairly certain I programmed the chip on the proto board with the dragon.  I do have an STK-500 however the XP laptops I have to not have serial ports, so I tend to use the dragons most of the time.  Otherwise I have to dig out a USB to RS232 bridge, which is cumbersome and only a last resort.
It could be that this computer inherited the definition files from earlier versions.
I tend to forget these old first generation chips really do not have fuse options as the mega ones do.  There is no internal oscillator or bootloader or debug modes.   These really are bare bones devices, with only the simplest of basic functions.
Not on mine. Same V4.19 build 730. There is no AT90S2313 either. But the ATmega8515 shows up as does the ATtiny2313.
This a "new" AT90S8515, so the SPI fuse is already programmed. If it were not programmed, the tests using ISP for DRAGON, USBTINY, USBASP and TL866A (ISP) would not have worked at all.
Yes, very basic AVR but they had the external RAM interface, which I saw used in a few designs.
Are you looking under the programmer connect menu or the new project menu?  I just looked at the new project menu which asks for a debugger and the AT90S8515 is indeed grayed out.  I was using the Tools->Program AVR-Connect menu to the programmer, Selecting dragon/USB in disconnect mode, then from the Main tab, I was pulling down the 'Device and signature bytes' menu.
It does seem counter intuitive, that one would expect the project to be attached to a programmer first and a debugger second.  The debugger can be changed in the Debug->Set Platform and Device... menu.  Where the Dragon does not allow a AT90S8515.
Project->Configuration options also has a menu under the General icon where the Device is specified.  This is for the compiler to know what the parameters are and what defaults to load.  So the counter intuitive when creating a project to be programmed by a dragon, one has to actually choose a different debugger (simulator and the ICE200 are probably the only valid ones) to create the project that auto fills this information.
I think most of the programmers like the AVRISP and Dragon use the STK500 protocol for uploading hex files.  I seem to recall that the JTAG ICE, which I ported to run on the Butterfly used the STK500 protocol for uploading.  The JTAG was for the stepping breakpoints and boundary scans. (which are not documented very well as the protocol is somewhat proprietary)
As for the external memory and 8051 pinout, that is why I still play waste/time with these old chips from time to time. They really botched the MEGA162 when the put the JTAG on the external address lines, making it impossible to debug the external memory.  The Mega8515 like the Mega8 has no debugger at all which is sort of silly, I guess they were seen as an interim upgrade path where existing code would be used in compatibility mode, Or else the simulator was good enough.
I have AS4.18 SP 3 and lots of 90S chips available for programming, too lazy to change the USB driver to use the real Dragon.
Never mind the nonsense, no AT90S chips available with the good USB driver and a real connection. blush
