Atmega 1284p WDT
3 posts / 0 new
Hi, this is Siva
I am using watch dog timer... if I enabled WDT, reset happens but after reset, my application not started again. What may be the issue? Kindly help...
sivasankar wrote:
Hi, this is Siva I am using watch dog timer... if I enabled WDT, reset happens but after reset, my application not started again. What may be the issue? Kindly help...
You are going to need to show us your code...or rather the smallest section of code which shows the problem.
What evidence do you have, the cpu must be running something, if not your app, then what?
One gotcha of the WDT, is the time out resets to the lowest value upon reset, so you must disable the WDT early in your code or re-init it to a longer time out value.
