Microammeter suggestions
17 posts / 0 new
Hey all,
I am looking for a simple microammeter/millammeter that can measure up to lets say 2ma full scale.  I am trying to get an actual current draw of my entire circuit while the RF section is sleeping.  When everything wakes up I know its in the 200ma range, but that I do not care about.
I am looking at the ones from DROK, but I thought some freak might have another vendor recommendation.
Why is there a "Highway to Hell" and only a "Stairway to Heaven"? A prediction of the expected traffic load?  - Lee "theusch"
Jim,
Have you heard of Dave Jones's "uCurrent"? (microcurrent)
https://www.eevblog.com/projects...
That's a slick kit! Thanks. Will see if I can order one
jgmdesign wrote:
That's a slick kit! Thanks. Will see if I can order one Jim
Seems to be out of stock ?
Another approach could be to use the Current Monitor devices, which have a milli-volt current input, plus a volts input.
PAC193x
100 mV full scale range for current sense voltage, - 16 bit resolution
0V to 32V input common-mode voltage - 16 bit resolution for voltage measurements,
eg  this for PAC1934 is in stock :
https://www.digikey.com/products...
or maybe this ?  (INA286)
The evaluation boards for Silicon Labs EFM, 8 range have onboard current monitors and there is a nice bit of software to read the data. I have seen a Web page where someone cut a couple of tracks to allow use with external chips.
How much are you looking to spend?
Many low-cost handheld DMMs have uA ranges these days - I recently bought this one for this very purpose:
5XP-A - 600V AC/DC Digital Multimeter with VoltTect NCV
https://cpc.farnell.com/amprobe-...
It has a 200uA range ...
As Brian says, many dev boards now include some sort of "power analyser".
There's the Atmel "Power Debugger" - but that seems rather expensive for what it is.
Nordic's "Power Profiler Kit" is half the price: https://uk.farnell.com/nordic-se...
Do you just want to measure "static" current, or view the profile?
As I've mentioned before, I just use a current-sense amplifier (CSA) and scope ...
EDIT
Just remembered the SAML21 XPlained Pro board: http://blog.antronics.co.uk/2015/04/23/new-tricks-for-lower-power-from-atmel/
AIUI, its "Xplained Pro Analog Module "(XAM) is the "guts" of the Atmel Power Debugger.
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-42405-SAML21-Xplained-Pro_User-Guide.pdf - page 8
I don't know how hard it would be to "hack" the board to use this for measuring an external system ... ?
Currently fifty quid from Microchip: https://www.microchipdirect.com/product/search/all/atsaml21-xpro-b
Like awneil #6 writes, uA ranges are pretty common with DMM's.
The Aneng AN8009 is a bit special in that regard. It is a 9999 count meter and it has an extra digit in a lot of ranges.
Current resolution is 100nA.
Voltage resolution is 1uV
Ohms resolution is 10mOhm.
The AN8009 is an USD 25 meter.
When measuring standby current of a uC it is handy if your meter can at least pass the full current (presumably 200mA) without too much voltage drop.
An easy way to do this is to put a (scottky) diode parallel to an external shunt resistor.
When the uC is asleep, the voltage drop over the shunt should be < 100mV and the diode conducts almost no current.
When the uC is active, the voltage drop over the shunt is limited by the diode (A few hundred mV).
Thanks for the diode tip - I will try that!
Paulvdh wrote:
AN8009
This: https://www.amazon.co.uk/Digital-Ranging-Multimeters-Voltage-Electronic/dp/B07B6PLBK6 ?
Image result for aneng an8009
Trouble there seems to be that the uA measurement is on a different terminal from the mA and A ?
As you said:
So that's probably going to be a problem with this one?
It's been mentioned a few times here. Might be worth searching out those threads - ISTR there were recommendations for other similar units ...
The design is published - you could build your own ...
Indeed, +1!
Jack Ganssle reviewed it a few years back:
http://www.ganssle.com/reviews/review_of_ucurrent.html
In that review he also mentioned:
https://www.electronicdesign.com/test-amp-measurement/whats-all-femtoampere-stuff-anyhow
and:
http://www.keithley.com/data?asset=50390 (dead link, available via Wayback Machine):
https://web.archive.org/web/20140819113033/http://www.keithley.com/data?asset=50390
Others he has reviewed:
http://www.ganssle.com/rants/realtimecurrentmonitor.html
http://www.ganssle.com/rants/rtcm-version-2.html
Total votes: 2
When buying a meter with a uA range you need to keep an eye on the 'burden voltage' spec. Or, in other words, the value of the shunt resistor used to measure the current. Some cheap meters can easily drop a few 100 millivolts which is not much good when your uC is running on 1.8V.
That is the whole (or nearly) basis of Dave's design. Don't introduce a burdensome (forgive me please) burden voltage into your measurement setup.
So as not to burden myself with unecessary test gear I often made do with the stuff I had easily available. I.e. a simple R/C network inserted into the Vdd line. Although not shown in my schematic, either 10R OR 100R could be used. Oh and the electrolytic was low leakage.
I would connect a DMM for the static sleep mode currents and often scope the output when profiling the run mode current.
This does just fine for a "look-see" investigation. The drop in a working sleep mode design is minimal.
Some words of caution about the AN8009. (So pretty much off topic).
I bought 2 of them as "extra" meters, for those times you need to do measurements with 4 or more DMM's at the same time...
The AN8009 delivers a lot of bang for those few bucks, but it has a few shortcomings.
This meter is pretty good at measuring small values (current, voltage, ohm)
It does indeed have only 2 shunts for measuring currents.
Both are fused with pretty crappy fuses ( D= 3.5 x 10mm)
They look like unobtanium, but D = 5 x 20 mm fuse holders are relatively easy to fit in the housing.
The "A" and "mA" bus has a piece of bridge wire and is not measurable with a normal DMM, Silk screen says: 10mOhm.
The "uA" input has a shunt resistor of 100Ohm and is fused at 200mA.
So it can pass a 100mA current in the "uA" setting, but it just can't measure it.
"Burden voltage" would be 100mA * 100 Ohm = 10V which is unacceptable and would probably overload & burn out the shunt before the fuse blows.
The bigges shortcoming of this meter is the lack of a real "mA" range.
It has a 9.999A range (Resolution 1mA) and a 999.9mA range ( Resolution 100uA)
For currents between 1mA and 100mA this meter has a very low resolution.
About the diode trick:
A lot of small power supplies have a series diode as a reverse voltage protection.
You could put the AN8009 in current measurement mode and short the diode through the shunt in the AN8009.
This should be a pretty decent measurement for currents < 1mA with no modification or extra external components.
I sort of like Dave's uCurrent, but will never buy one.
It is not much more than a (pretty nifty) opamp in a 100x configuration in a small box and with a few precision resistors.
It is too expensive for occasional use, and to limited for daily work.
For occasional use I would cobble something together on a breadboard or whatever.
For daily work I would prefer a power supply with built in accurate meters.
I would like one of those Keithley SMU's such as the 2400 but those are not really affordable :(
Think about USD 5000+
https://duckduckgo.com/html?q=keithley+2400
A power supply for 0 to 10V and 0 to 200mA and accurate measurements is not too difficult to design though.
It could also easily compensate for shunt and lead voltage drops, or even 4 wire feedback.
Dave Jones is currently developing a power supply with those sort of specs (Look at his video of custom LCD design)
It is a follow up of his uSupply which he never finished.
https://www.eevblog.com/projects/usupply/
Yup, that's why I suggested the PAC1934 Eval Board. With 16b ADC and a maximum of 100mV,  that gives VSENSE LSB Step Size VSENSE_LSB — 1.5 — μV Unidirectional currents
If we scale the OPs 2mA to a 6mV burden, that's a 3 Ohm shunt, for 2mA full scale reading of 6m/1.5u = 4000 or 0.5uA LSB, The 16b ADC limit here, is hit at 33mA across that 3 ohm shunt.
