Atmega 168pa MCU is not working properly sometimes
8 posts / 0 new
Hello forum experts,
I am having a problem where I'm trying to run a code that uses PWM and sensors to detect gas. It works perfectly, but mcu detects gas which means that make a beep signal(buzzer) and blinking led without anolog signal (whithout gas ). It repeats 2 or 3 times and after that mcu is silence.
The problem appears when mcu works long time, sometimes 2 weeks or 1 month. It doesn't depend on circuit board.
Does anyone know why this could be happening?
sadf
Could be many things - do you filter your analog signal both in hardware and software? With no filtering a static discharge event (ESD) can cause an invalid reading.  Hopefully this unit isn't a safety device.
I used LM324 op amp for analog signal(10kohm and 47uF). I used two 1000uF 25V 1000uf 10V for converting voltage. I am sure that hardware filter is OK. I didn't solder 0.01uF for MCU(vc,avc and gnd) for ripple because I used high filter.
In software, I used ADC 10 bit for reading anolog signal. How to filter analog signal in software? I used internal oscillator 16 MHz frequency.
sadf
the simplest filter is taking a number of samples and averaging.
Next up is digital filter using DSP techniques.
You still need bypass caps for the AVR.
How do you know? Maybe all your boards are faulty. Show a picture of your board. And also a picture from your PCB CAD program showing the track layout.
I considered before it averaging (sensors value/100).
Could you lead digital filter in software?
sadf
Funny how some ignore the obvious!
Need to also see a schematic of the circuit.
The LM324 is not a rail-to-rail op-amp, and if it is running on 5V/Gnd then it has a very narrow window of operation.
Need the sensor make and model, (or link), also.
When I have had a bug show up once every X hours or days, etc., it has usually been a software problem, where an interrupt just happened to fire at exactly the wrong time to screw things up...
