ATmega will only load half of program
8 posts / 0 new
I am working on a project using the ATmega88PA, Atmel Studio 7 (version 7.0.1931), and the Atmel-ICE debugger.  I'm able to program the ATmega88PA using the Atmel-ICE in ISP mode and my program runs as expected.  However, when I try to debug, a curious behavior occurs: After enabling debugWire, Atmel Studio writes about 60% of the program (according to its status bar), then says "Running," and eventually I get a message saying "Launch Failed:  Timed out waiting for device to reset, would you like to continue waiting for the reset event?"
The problem arose suddenly during development without hardware changes.  My code is large; the hex file is 8192 bytes or 100% of flash.  Could that contribute to this?  What debugging steps should I take to isolate my problem?
Adam J.
I would start by looking over your reset line. debugWire is very sensitive to load on the reset line...
:: Morten
I would solder in a M328 to give yourself some room to debug!  Once the the program works and you know the code space needed, choose the appropriate Mega and recompile.
I always do my prototyping/debugging using the largest member of the family, it makes (programmers) life much easier.
stack gold/silver https://www.onegold.com/join/713...
How are you determining that? It just feel odd that you have managed to write code that fills the full 8K exactly, neither a byte under nor byte over.
Also sizeof(hex file) != sizeof(binary).
Usually .hex is 2.5 to 3.0 times larger than the binary. So if hex is really 8192 bytes then it's probably about 2,700..3,700 bytes of code - avr-size will tell you the exact size held within.
Sorry for the delay in replying.  The source of my problem appears to have been that there was a bit-banged I2C sensor using the same pins as the debugWire.  That's what I get for doing a contract job on someone else's hardware, and not paying close attention to the schematic ;)
I was able to enter debugWire by removing the sensor and using a JTAGICE mkii instead of the Atmel-ICE.  Not sure why changing debug tools helped, but it did.
Regarding code size, I was referring to the size in bytes reported in the compiler output in Atmel Studio; I took a long time coaxing all the required features to fit and that's why it's such a close fit.  And yes, I wholeheartedly agree with the comment to use a bigger chip for development.  This was a quick enhancement on an existing product.
Thanks all!
Adam J.
Doesn't debugWire use the /RESET line?  And you have the bit-banged I2C on the /RESET line?
Now I have to dig out datasheets and past threads -- does debugWire even work if RSTDISBL fues is programmed?
Not on /RESET; it was using two of the other lines.
