ATmega will only load half of program
8 posts / 0 new
I am working on a project using the ATmega88PA, Atmel Studio 7 (version 7.0.1931), and the Atmel-ICE debugger.  I'm able to program the ATmega88PA using the Atmel-ICE in ISP mode and my program runs as expected.  However, when I try to debug, a curious behavior occurs: After enabling debugWire, Atmel Studio writes about 60% of the program (according to its status bar), then says "Running," and eventually I get a message saying "Launch Failed:  Timed out waiting for device to reset, would you like to continue waiting for the reset event?"
The problem arose suddenly during development without hardware changes.  My code is large; the hex file is 8192 bytes or 100% of flash.  Could that contribute to this?  What debugging steps should I take to isolate my problem?
Adam J.
I would start by looking over your reset line. debugWire is very sensitive to load on the reset line...
:: Morten
I would solder in a M328 to give yourself some room to debug!  Once the the program works and you know the code space needed, choose the appropriate Mega and recompile.
I always do my prototyping/debugging using the largest member of the family, it makes (programmers) life much easier.
How are you determining that? It just feel odd that you have managed to write code that fills the full 8K exactly, neither a byte under nor byte over.
Also sizeof(hex file) != sizeof(binary).
Usually .hex is 2.5 to 3.0 times larger than the binary. So if hex is really 8192 bytes then it's probably about 2,700..3,700 bytes of code - avr-size will tell you the exact size held within.
Sorry for the delay in replying.  The source of my problem appears to have been that there was a bit-banged I2C sensor using the same pins as the debugWire.  That's what I get for doing a contract job on someone else's hardware, and not paying close attention to the schematic ;)
I was able to enter debugWire by removing the sensor and using a JTAGICE mkii instead of the Atmel-ICE.  Not sure why changing debug tools helped, but it did.
Regarding code size, I was referring to the size in bytes reported in the compiler output in Atmel Studio; I took a long time coaxing all the required features to fit and that's why it's such a close fit.  And yes, I wholeheartedly agree with the comment to use a bigger chip for development.  This was a quick enhancement on an existing product.
Thanks all!
Adam J.
Doesn't debugWire use the /RESET line?  And you have the bit-banged I2C on the /RESET line?
Now I have to dig out datasheets and past threads -- does debugWire even work if RSTDISBL fues is programmed?
Not on /RESET; it was using two of the other lines.
