Confusion on CTC Mode (Atmega328p
6 posts / 0 new
So im learning about timers and the "Normal Mode" timer was pretty straightforward, so I thought i'd take a shot at CTC mode looking purely at the datasheet (seemed easy enough). My chip is running at the default 1MHz. Here is my code:
 * 328p_Timer_CTC_Mode.c
 * Created: 11/9/2018 7:32:35 PM
/* LED Definitions */
#define LED			PINB1
#define LED_PORT	PORTB
#define LED_DDR		DDRB
We are going to use the Atmega's Timer1 (16-bit timer) in Clear Timer on Compare Match (CTC)
For Timer1:
- Setting the mode to (CTC) mode we use OCR1A to set Resolution
- TCNT1 is cleared when the counter matches the value in OCR1A
- Setting Clock prescaler to clk/1024 = 1MHz/1024 = 1.024 (ms) per tick
static inline void initTimer1CTC(void) {
	TCCR1A |= (1 << WGM12);					/* Set CTC Mode, see page: 141 on Datasheet */
	TCCR1A |= (1 << COM1A0);				/* Toggle OC1A Pin (Pin 12, PD6) after each "cycle" after matching OCR1A */
	TCCR1B |= (1 << CS12) | (1 << CS10);	/* Set Timer1 to clk/1024 prescaler */
	initTimer1CTC();
	LED_DDR |= (1 << LED) ;			/* PB1 set to output (LED), for OC1A pin to toggle */
	uint16_t duration =  5000;
	OCR1A |= duration;
	while (1)
		/* Toggle should happen after OCR1A value is reached each time */
	return 0;
So this is indeed working by toggling PB1 every so often, according to my calculation of clock speed and then steps to OCR1A it should be blinking every 5 seconds....but it's blinking more like every 30 seconds or something. Im guessing im mis-understanding how the timing is calculated, but hoping someone could point out where I went wrong. (As a sidenote: I wish there was a good poster or something listing all the AVR pinouts, that'd be a good buy! haha)
Mercfh wrote:
... CTC mode:
WGM12 lives in TCCR1B so you are actually setting a reserved bit to 1.
Also it's better to initialize with an = instead of |= since the latter will
leave any other '1' bits set:
    TCCR1A = (1 << COM1A0);                             // output toggle
    TCCR1B = (1 << WGM12) | (1 << CS12) | (1 << CS10);  // CTC + /1024
--Mike
Yikes thats embarrassing lol! also good point about |= vs =. I wonder why my device was still blinking the LED though...i guess it was in normal mode? but I thought the TOV1 flag had to be cleared before it could be set again?....i mean the LED was def. blinking but just super slowly.
OCR1A =5000;
You want a direct assignment, not |=
TOF1 is only of concern if you have the associated interrupt turned on or you are polling that bit.
Mercfh wrote:
.... the LED was def. blinking but just super slowly.
Probably 13.10458 times slower?
Since you turned the timer on it was still counting
in normal mode, just not resetting when the count
reached OCR1A.  Eventually it overflowed and came
back around to OCR1A again for another toggle of
the output.
--Mike
the output.
--Mike
Yeah thats prolly right. Also Kartman I meant TOV1 flag (which I had to reset when doing normal mode) or do you not need to reset it?
btw why 13.1 times slower (I must be missing something)?
ah wait nm......65,535/5000 derp.
