megaAVR 0-series
173 posts / 0 new
Pages
Getting Started With Your AVR-IoT WG Development Board - YouTube
by Microchip Technology
Oct 10, 2018
https://www.youtube.com/watch?v=WK4ljyKDMIQ (6m26s)
via https://plus.google.com/+MicrochipTech/posts/7pLed2HKFf5
http://packs.download.atmel.com/#collapse-Atmel-ATmega-DFP-pdsc
1.2.272 (2018-09-14)
Corrected CLKCTRL signals, ALT out signals and interrupt edge triggering values for CCL and added SEQCTRL1 for ATmega4809, ATmega4808, ATmega3209 and ATmega3208.
Corrected RW status on MCLKSTATUS register.
Added ATmega1609, ATmega1608, ATmega809 and ATmega808.
Interesting. So that's (likely) the megaAVR 0-series family complete. You can't go bigger than 48k because of the way the memory is mapped, it probably doesn't make sense to go smaller than 8k, it also probably doesn't make sense to go more than 48 pins, and you'd never fit all the functionality is less than 28 pins.
The tinyAVR 1-series is looking to be complete, unless there are plans for 48k devices, as is the tinyAVR 0-series.
It seems I also need to add the ATmega1609, ATmega1608, ATmega809 and ATmega808 to the avrdude.conf file in my programmer.
BTW, tiny3204, tiny3206 and tiny3207 are also missing in my avrdude.conf, but they don't seem to be planed even as future products.
USB megaAVR are popular.
Prediction - megaAVR 1-series
Updated USB device controller, unified memory, ...
Currently future product :
ATmega1609
ATmega1608
ATmega809
ATmega808
the overview say :
 The series uses the latest Core Independent Peripherals with low power features.
is that new version or just a bug fixed one ?
IIRC, CIP is from the PIC side of the house.
If you say so.  I always thought that Microchip's "Core Independent Peripherals" and Atmel's "Event System" and/or "Sleepwalking peripherals" were approximately the same thing.  (though I haven't looked at either one in enough detail to see if there are any important differences.)
It's my assumption.
In '11, became aware of the Charge Time Measurement Unit (CTMU) in some PIC18F where the CTMU is sensing touch buttons while the CPU sleeps.
Atmel QTouch is implemented by library software (CPU) that was improved by some PB megaAVR with the Peripheral Touch Controller (PTC)
AVR32 UC3L has an autonomous touch button hardware interface (Capacitive Touch or CT) to wake the CPU.
Waking up a capacitive touch-sensing device with an MCU peripheral
Nithin Kumar Mada and Harsha Jagadish, Microchip Technology - July 27, 2011
When a capacitive touch screen goes into sleep or standby mode to save energy, how can you design the system to wake up quickly without degrading its performance or burning a lot of power. Here are two options: a traditional method and a new MCU-based method.
https://www.embedded.com/print/4218309
Overview of Charge Time Measurement Unit (CTMU)
https://www.microchip.com/stellent/groups/SiteComm_sg/documents/DeviceDoc/en542792.pdf
(page 32)
Other Applications of CTMU
[capacitance sensing, TDR, precise time, temperature sensing, humidity sensing, DAC]
Total votes: 2
The code for the new ATmega4809-based Arduino board has been checked in:
https://github.com/arduino/ArduinoCore-megaavr
    How they run it at 16MHz ? I thought it will run at 20MHz. Is the schematic available ?
Couldn't quickly locate the schematic of Arduino Uno WiFi rev2.
Its competitor is AVR-IOT WG Development Board
AVR-IOT WG's mega4808 is on page 3 at B3 :
http://ww1.microchip.com/downloads/en/DeviceDoc/AVR-IoT_WG_Schematics.pdf
To megaAVR 0-series UARTs were added autobaud (BREAK, SYNC, data) and FBRG.
AVR-IOT WG's nEDBG SAMD21 (page 2, C5) has access to USB SOF for creation of an accurate internal clock.
Edit: page 2
ATmega4809 Curiosity Nano
has separate LDO for mega4809 and nEDBG SAMD21 such that mega4809 VCC can be nearly USB VBUS.
http://ww1.microchip.com/downloads/en/DeviceDoc/ATmega4809_Curiosity_Nano_Schematics.pdf
in stock
lead time is 15 weeks
ABX00021 Arduino (Uno WiFi Rev2) | Mouser
ARDUINO UNO WiFi REV2, documentation tab
That's a lot of level shifters.
And man, that power supply just keeps getting more and more complicated.  Six transistors, now!  (oh wait - the opamp is gone...)
Am I missing something?   Were there spectacular problems with the old design?  Is there something wholy awful about a couple of diodes?
(and you'd think that someone would have put this whole "USB or external power to 5 and 3V @500mA total" on a single chip/module by now...)
Did someone test the Arduino Uno WiFi Rev 2 ?
It is very strange to see "coming soon" at the Arduino store, as if it had not arrived !
But it is available at Mouser ...
Bernard.
No, but I've been playing with the code using an Xplained Pro board.
That's the lovely thing about Open Source - you can analyze it, criticize it, submit bugs, even write fixes, all without actually contributing to the vendor's revenue stream!
You're onto something really handy (breadboards, typical protoboards)
top left at ATMEGA4809 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
Do you think they'll come with a DIP40 version of the 4809?
Arduino Uno WiFi (the one with the mega4809 on it) is now in stock at Farnell...
https://uk.farnell.com/arduino/a...
Total votes: 2
Soon...
