trouble getting DS1620 to work with 3-wire communication
4 posts / 0 new
I took the example program from this website:
PC Parallel Port Interface
and changed it to work with the AVR ProMini where pin D2 is CLK, D3 is DATA and D4 is RST
In the function 'read_raw_data' I change the DATA to an input and back to output using:
	DDRD &= 0xF7; // change bit 3 to input
	DDRD |= 0x08;  // change back to output
other than that, I don't see what I'm doing wrong. I only get 1's as an output from the DS1620
//*************************************** main.c  ******************************************//
bottom view w/ reset button on right
TX		RX		RESET*		gnd		PD2		PD3		PD4		PD5		PD6		PD7		PB0		PB1
RAW		gnd		RESET*		VCC		PC3		PC2		PC1		PC0		PB5		PB4		PB3		PB2
																	SCLK	MISO	MOSI	SS
*either one goes to CS signal on programmer
DS1620 pinout:
8 7 6 5
1 2 3 4
1 - DQ
2 - CLK
3 - RST
4 - GND
8 - VDD
#include<avr/interrupt.h>
//#include "../avr8-gnu-toolchain-linux_x86/avr/include/util/delay.h"
#include "../../Atmel_other/avr8-gnu-toolchain-linux_x86/avr/include/util/delay.h"
#include "sfr_helper.h"
#include <avr/eeprom.h>
#include <stdlib.h>
#include "USART.h"
#include "macros.h"
#include "pinDefines.h"
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#define CLK PORTD2
#define DATA PORTD3
#define RST PORTD4
#define SET_CLK()	_SB(PORTD,CLK)
#define CLR_CLK()	_CB(PORTD,CLK)
#define SET_DATA()	_SB(PORTD,DATA)
#define CLR_DATA()	_CB(PORTD,DATA)
#define SET_RST()	_SB(PORTD,RST)
#define CLR_RST()	_CB(PORTD,RST)
/*  DS1620 Commands */
#define CONF_REG 0x0c
#define READ_CONF 0xAC
#define READ_TEMP 0xaa
#define START_CONVERT 0xee
#define STOP_CONVERT 0x22
void write_command(int command);
void out_bit(int bit);
int read_raw_data(void);
float convert_to_T_F(int raw_data);
int data=0x00;  /**Global variable**/
volatile UCHAR xbyte;
	int raw_data, n;
	int configure=0x02;
	float T_F;
	UINT temp;
	initUSART();
	DDRD &= 0xFF;
	_delay_us(2);
	CLR_RST();
	SET_CLK();
	SET_RST();
	write_command(CONF_REG); /* configure DS1620 in CPU Mode */
	write_command(configure);
	CLR_RST();
	_delay_us(200);  /* wait for programming of configuration status register */
	SET_CLK();
	SET_RST();
	write_command(READ_CONF);
	raw_data = 0;
	raw_data=read_raw_data();        /*read raw temp data */
	CLR_RST();
	// send high byte of results 1st to serial port monitor
	temp = (UINT)raw_data;
	temp >>= 8;
	xbyte = (UCHAR)temp;
	transmitByte(xbyte);
	_delay_ms(1);
	// then send the low byte - make sure to restart the monitor program
	// so the bytes don't get reversed
	_delay_us(5000);  /* wait for programming of configuration status register */
	SET_CLK();
	SET_RST();
	write_command(START_CONVERT);   /* start converting temp*/
	CLR_RST();
	_delay_ms(200);
		SET_CLK();
		SET_RST();
		write_command(READ_TEMP);    /*command to 1620 for reading temp*/
		CLR_RST();
//			T_F=convert_to_T_F(raw_data);
		temp >>= 8;
		_delay_ms(1);
//			printf("The temperature is %f degrees fahrenheit.\n\n", T_F);
//			sleep(10);
		_delay_ms(10);
	SET_CLK();
	SET_RST();
	write_command(STOP_CONVERT); /* stop conversion to save power */
	CLR_RST();
	_delay_ms(5000);
	return (0);		// this should never happen
	float T_F, T_celcius;
	if ((raw_data & 0x100) != 0)
		raw_data = - (((~raw_data)+1) & 0xff); /* take 2's comp */
	T_celcius = raw_data * 0.5;
	T_F = (T_celcius * 1.8) + 32;
	return(T_F);
/* sends 8 bit command on /STROBE output, least sig bit first */
	int n, bit;
	for(n=0;n<8;n++)
		bit = ((command >> n) & (0x01));
		out_bit(bit);
	int bit,n;
	int raw_data=0;
	bit = 0;
//	UCHAR test;
	DDRD &= 0xF7;
	_delay_us(1);
	for(n=0;n<9;n++)
		CLR_CLK();
//		test = PIND & _BV(DATA);
//		transmitByte(test);
		if((PIND & _BV(DATA)) == 0x08)
			bit = 1;
			bit = 0;
		SET_CLK();
		raw_data = raw_data | (bit << n);
	DDRD |= 0x08;
	return(raw_data);
/* state of /STROBE set to value of bit, followed by clock pulse */
	CLR_CLK();
	if(bit & 0x01)
		SET_DATA();
	else CLR_DATA();
	SET_CLK();
- Dan
Are you using GCC?  I see the use of delay() functions but I do not see where F_CPU has been defined.
Dallas One wire protocol is very dependent on timing, do you have an Oscope or Logic Analyzer available to check your timings?
I just googled "DS1620 AVR". It hit a few. The "cleanest" looking code I found so far is:
https://github.com/jenswilly/AVR...
I'd suggest that looks a whole heap more "organized" than the code you present in #1. The chances are that "clean" code is quality code.
Yes, I'm using GCC and I have a scope.
I'm setting the F_CPU in the Makefile as 16Mhz.
That code worked for me. (I did increase the delay in in the readTempFrom1620() from 2us to 5ms).
Thanks.
- Dan
