Hello everybody,
I just have bought an Attiny817 Xplained Mini board (Rev 6). In fact, I took two of them. None is working with Atmel Studio 7. I was supposed to blink the onboard LED when first connected to the USB port then, after installation, the LED should go off. Both boards have the same behavior. The LED is on all the time, steady.
Any idea? Should I update the bootloader on mEDBG? I have tried from the command line, as instructed in the datasheet but the tool cannot be found.
Any idea? I'm really a newbie, so maybe I miss something obvious. Thank you.
