Documentation on start frame detection interrupt for ATmega328PB
31 posts / 0 new
Hi all,
I'm looking for documentation on start frame interrupt functionality on the ATmega328PB.
There is an off-hand mention of this capability in section 24.9.4 Start Frame Detection in the ATmega328PB datasheet, however there appears to be no documentation (that I can find) on the registers involved in working with this interrupt.
For example, the datasheet says:
The USART start frame detection works in both asynchronous and synchronous modes. It is enabled by
writing the Start Frame Detection Enable bit (SFDE). If the USART Start Interrupt Enable (RXSIE) bit is
set, the USART Receive Start Interrupt is generated immediately when start is detected.
Unfortunately, that is the only mention of SFDE and/or RXSIE in the entire datasheet
An app-note from avr called AVR42783: Using USART to Wake Up ATmega328PB from Sleep Mode basically just uselessly copies and pastes the above paragraph, with no further explanation.  It then shows some abstracted sample code where no register manipulation is shown, and instructs you to download the full source code from Atmel START.
Once you download the code from Atmel START, and start navigating around in it, you find the following:
static void uart_init(void)
	// USART0
	UBRR0H = UBRRH_VALUE;
	UBRR0L = UBRRL_VALUE;
	// Enable RX and TX and set interrupts on RX complete
	UCSR0B = (1 << RXEN0) | (1 << TXEN0) | (1 << RXCIE0);
	// 8-bit, 1 stop bit, no parity, asynchronous UART
	UCSR0C
	    = (1 << UCSZ01) | (1 << UCSZ00) | (0 << USBS0) | (0 << UPM01) | (0 << UPM00) | (0 << UMSEL01) | (0 << UMSEL00);
	// Enable Start Frame Detection
	UCSR0D = (0 << RXSIE) | (1 << SFDE);
	// Initialize the in and out buffer for the UART
	ring_buffer_out = ring_buffer_init(out_buffer, BUFFER_SIZE);
	ring_buffer_in  = ring_buffer_init(in_buffer, BUFFER_SIZE);
So, looks like the proper register name is UCSR0D...
There is no ISR defined for the start frame detection interrupt, so I assume this code example simply uses the ISR to wake the device from sleep.
By typing in stuff in Atmel studio, auto-completion seems to think that the ISR vector symbol for start frame detection is USART0_START_vect.  Also, going to implementation of OCSR0D brings me to iom328pb.h header file which has the following code grouped together:
#define UCSR0D  _SFR_MEM8(0xC3)
#define SFDE    5
#define RXS     6
#define RXSIE   7
I wonder what the RXS bit represents?  I assume the other abbreviations break down as follows:
- SFDE --> start frame detection enable bit
- RXSIE --> RX start frame interrupt enable bit
- RXS -->  ???
Being a relative newbie to AVR programming, I wonder: did I do well in figuring this stuff out?  Is this really the only documentation on start frame detection?  Is there really no actual formal register description of UCSR0D available to developers?
Thanks!
I love the smell of burning silicon in the morning
I'd say that you did better than the average bear! Good job in ferreting it out.
Maybe like other interrupts, RXS is the testable bit that indicates RX Start, independent of the interrupt (that is, testable by polling)?
At this point, I've only read that far.  But that isn't much different than the doc for any similar AVR8 interrupts, is it?  The condition is signaled by setting the flag.  If you enable the corresponding xxxIE bit, then the ISR is invoked.  For veteran AVR8 people, it sounds OK so far.  Now back to reading the rest of the post...
I guess.  If I'm curious about an AVR feature, I'll read the associated chapter.  And at least scroll through the "Register Description".  When looking for it, this would pop out:
Did you find a typo?  Probably.
Do you need Atmel Start to do your investigation?  Hmmmm--I guess it would depend on what your toolchain of choice is.  If my toolchain has support, I'd build/generate a test program, and examine the chip-include file.
jaza_tom wrote:
There is no ISR defined for the start frame detection interrupt, so I assume this code example simply uses the ISR to wake the device from sleep. By typing in stuff in Atmel studio, auto-completion seems to think that the ISR vector symbol for start frame detection is USART0_START_vect.
I don't quite know what you are getting at here.  Let's peek at the list of interrupt vectors in the datasheet...
Again, there is a "small print" statement somewhere about the "this is repersentative and there might be multiple instances with a specific instance number bla bla bla..."
I think the rest of your post is covered in the UCSR0D/UCSR1D piece of the datasheet.
It certainly can be daunting with an AVR model with hundreds of I/O registers with many/most having multiple bits in them.  Perhaps try a read through the chip-include file along with the datasheet chapters for the various peripheral subsystems.
The PB model of the M328 is fairly new model, so it would not surprise me if little info is available on the interwebs, where the M328P has been around and is quite popular!
I think the problem is looking at the datasheet from a wrong direction.
jaza_tom's picture
Hmm...
In the latest version of the datasheet, chapter 25 only goes to 25.8:
And there is no mention of UCSRnD in either the USART or USARTSPI chapters.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
The debugger seems to know about UCSRnD:
Greg Muth
Portland, OR, US
YAY, I'M NOT CRAZY AFTER ALL!cool
Greg_Muth wrote:
Hmm...
@theusch can you post that older (correcter) datasheet with the juicy scoop on the start frame detect registers!?
Here is the vector definition from iom328pb.h:
/* USART0 Start frame detection */
#define USART0_START_vect            _VECTOR(26)
#define USART0_START_vect_num        26
EDIT:
In case you're wondering, the path for the file above is:
C:/Program Files (x86)/Atmel/Studio/7.0/packs/atmel/ATmega_DFP/1.2.209/include/avr/iom328pb.h
Greg Muth
Portland, OR, US
Last post...
This compiles without error:
 * USART_Frame_Start.c
 * Created: 7/18/2018 6:23:50 PM
 * Author : greg
#include <avr/interrupt.h>
    while (1)
ISR(USART0_START_vect)
ISR(USART0_RX_vect)
ISR(USART0_TX_vect)
ISR(USART0_UDRE_vect)
Greg Muth
Portland, OR, US
Well, I did some testing using mEDBG mode and it appears as though the ISR for start frame detection never gets invoked, howver if I put the device into sleep mode, I can successfully wake it using start-frame detection.
So, I guess this interrupt can only be used to wake up a device from sleep, and not to actually trigger an ISR
Whatever, it does what I want cheeky
So the quotes/snapshots I gave are really Fake News?!?  I should be in politics.
Now you are going to make me look.  I quoted the Rev. C dated 10/15 so indeed nearly three years old.  No wonder OP is confused.  Was the feature removed?  Errata?  Change history has a mention?  Stay tuned while I get the latest datasheet...
[edit]  Indeed, no apparent mention of any change in that feature in rev history or errata.  As a guess, the "convertor" person started with the wrong version?
I find that quite hard to believe.
I think what we have here is the writer of the datasheets editor not double checking the writers work.
From page 276 in the datasheet I found on the website:
The device is not looking for a START FRAME, but a single BIT. and indeed it appears that the sole purpose of this is to wake the AVR.
JIm
App Note...
...has more info
As does...
AT15007: Differences between ATmega328/P and
ATmega328PB
ki0bk wrote:
The PB model of the M328 is fairly new model,...
The first datasheet is dated 2015 so not that new.
Here is the first version of the Atmel datasheet which has the register info in it...
Although the datasheet is dated then, when was the common public able to get hands on the beasties?   Wasn't that the model made out of unobtanium, or was that the '324PB?
Both.  With the 324PB being the most elusive beast.  I seem to recall you were rabidly looking for them.
The DS for 48-88-168pb has complete info on the USART's, looks like something got dropped in the cut n paste!
The following code fails to hit the start frame interrupt ISR:
* UARTSleepReceiveTransmit.ino
* Created: 7/18/2018 1:59:45 PM
* Author: Boompy
#include <avr/sleep.h>
#define ENABLE_UART_START_FRAME_INTERRUPT UCSR0D = (0 << RXSIE) | (1 << SFDE)
volatile bool startFrameDetected = false;
ISR(USART0_START_vect){
	startFrameDetected = true;
ISR(USART1_START_vect){
uint8_t led_pin = 13;
void setup()
	/* add setup code here, setup code runs once when the processor starts */
	Serial.begin(9600);
	//Configure sleep mode for deep sleepage
	set_sleep_mode(SLEEP_MODE_PWR_DOWN);
	//Enable UART start frame detection interrupt
	ENABLE_UART_START_FRAME_INTERRUPT;
	//Set LED pin
	pinMode(led_pin, OUTPUT);
	//Turn off LED
	digitalWrite(led_pin, LOW);
	//Enable global interrupts
	sei();
unsigned long nextSleep = 0;
bool waitToSleep = false;
void loop()
	if(Serial.available()){
		while(Serial.available()){
			Serial.read();
		Serial.println("YUP");
		nextSleep = millis() + 5000;
	if(startFrameDetected){
		//Show that the ISR was invoked by turning on the on-board LED
		digitalWrite(led_pin, HIGH);
	if(millis() > nextSleep){
		sleep_mode();
needs to be:
#define ENABLE_UART_START_FRAME_INTERRUPT UCSR0D = (1 << RXSIE) | (1 << SFDE)
I wonder if you can use the Arduino IDE on an Mega328PB.......
Yes, if it is mounted to an M328PB X-Mini (and probably even if it's not) you can:
Greg Muth
Portland, OR, US
I've also successfully used MiniCore in Arduino IDE with ATmega328PB as well
Reason I mentioned it is because the Arduino-ese usually has a bunch of stuff going on in this background that might be interfering with the ops code? Maybe, maybe not....
ki0bk wrote:
needs to be:
Woops, thanks for the correction.
Works like a charm now!
Please mark the solution!
Done
Got this from Atmel when enquired. At least it has the UCSR1D register in its register list.
rowifi wrote:
Got this from Atmel when enquired. At least it has the UCSR1D register in its register list. Attachment(s): PDF icon ATmega328PB_Datasheet.pdf
Isn't that the same as the one I was quoting from?
Atmel-42397C-8-bit AVR-ATmega328PB_Datasheet_Complete-10/2015
theusch wrote:
So the quotes/snapshots I gave are really Fake News?!? I should be in politics. Now you are going to make me look. I quoted the Rev. C dated 10/15...
So support (Atmel?  Microchip?) gave you the same datasheet version that I quoted earlier with explanations about start-bit?  So was there a later datasheet version that was rescinded?  George Orwell would be proud.
A few months down the road, and this still hasn't been fixed with a new datasheet on the Microchip website.
Looks like AVRfreaks has become the de-facto source for authoritative documentation on the ATmega328PB
