Atmega328p, Unable to set default fuses (AVRDUDE)
13 posts / 0 new
So i've been working through the "Make: AVR Programming" book, and there is a section (Section 5 with the UART sample program) that I was getting really goofy Serial data back from the AVR. I did some digging and it looked like it was probably some mismatch with what my CPU frequency was (For reference the SE question was asked here: Serial Output returns wrong ASCII)
Anyways, the book itself doesn't use a 16mhz Crystal and I had probably bought this atmega with a preloaded bootloader or something........because i've been programming it with AVRDUDE and the 16mhz Crystal for the past programs. Taking out the Oscillator gives the initialization failed, rc=-1 error.
So my guess was..ok I need to set the efuse (or maybe it was lfuse?), since everything lined up besides that one (it was showing 0x07 and I was trying to set it to 0xFF as shown by the "Default" Atmega328p fuse calculator: http://eleccelerator.com/fusecalc/fusecalc.php?chip=atmega328p)
Despite that I would get an error here back from AVRDUDE:
avrdude: verification error, first mismatch at byte 0x0000 0xff != 0x07
So im probably a bit lost. FWIW the "UART.c" file is defined here: https://github.com/hexagon5un/AVR-Programming/blob/master/AVR-Programming-Library/USART.c(The other code is in chapter 5 "serialLoopback.c"). Also I made sure baudrate was 9600. But from looking at that other post....im wondering that it's maybe my CPU Frequency was off?
Basically I think I need to make it where:
  1. I can program without the Crystal , since the book uses the internal crystal (Im using the Pocket AVR programmer from Sparkfun: https://www.sparkfun.com/products/9825)
  2. Figure out what I need to set my CPU Frequency to?
  3. Figure out why I can't set the fuse manually
I admit that I am still new, so fuses im probably not as experienced on. But this is just what i've tried from my research.
I fixed it by just setting the F_CPU to 1000000UL and changing the code a bit according an answer found on the web. I guess that leads me to the question: If it's programmed to use the 16mhz crystal and I set the F_CPU to 10mhz....does that actually work? How exactly does it just "reduce" it's speed. I assume use some sort of internal divider or something? I didn't think that would work with an external crystal?
The short answer is that you aren't really using the 16MHz.  [which is quite different than 16mHz]  Look in the datasheet for Default Clock Source.
Yes, if it >>is<< "programmed" to use the crystal.  This involves setting fuses for clock source, as described in the datasheet.  You can take your infinite-value toolchain with its free compiler and set F_CPU to whatever you want -- but the AVR chip doesn't know about that.  (If you set F_CPU to 123 will your AVR run at 123Hz?)
I have no idea what "unable to set default fuses" means.
Start by showing us your setup, post a clear picture, are you using a breadboard and bare chip or some commercial board (arduino uno?)
What are the current fuse settings?  H:  L:  E:
Getting USART comms to work is fairly simple if you are using a xtal.   Also, how are you looking at the serial I/O?   USB serial TTL cable?
F_CPU doesn't set the speed. It informs avr-libc of the speed you are running at. If your code runs fine with  F_CPU=1000000UL, this means you are running at 1MHz, therefore the fuses are set to use the internal oscillator (8MHz) with 8x divisor.
Im using a bare breadboard and the Sparkfun AVR Programmer. I had pulled the chip off an old arduino so that's why I assumed it was running at 16MHz. How would I find out what my fuses are set to? (I'll update once im at home)
Also the other reason I assumed it was running at 16MHz is that I have an external oscillator (16MHz one) attached, and im unable to actually program to the chip unless it's attached.
I will take a picture of the breadboard when I get home.
No it has an external xtal w/ two caps or external resonator w/caps built in, the chip will not run with out this part unless you "inject" a clock from an external source into xtal1 pin.
Once you do that, you can erase the chip and reset fuses to factory default so it runs on the internal R/C osc.
Well, if you can program, then you can also read the fuses, with avrdude and your programmer. Are you using avrdude for programming?
I am using AVRdude for programming, btw this is what my board looks like:
https://imgur.com/a/CJKeO82
the Metal Cap says "SD16.00000" on the top, which I assume to be 16MHz. When I program my code via the Sparkfun programmer, AVR reads out as: (This is an Atmega328p)
avrdude.exe: safemode: lfuse reads as 62
avrdude.exe: safemode: hfuse reads as D9
avrdude.exe: safemode: efuse reads as 7
avrdude.exe: safemode: Fuses OK
So now you go to a fuse calculator like this: http://www.engbedded.com/fusecalc/ and see what those fuses mean.
I'll tell you: these are factory defaults (probably a brand new chip you just bought), the 328p is running from the internal oscillator (8MHz) divided by 8, as I suspected in post #5. So you shouldn't need the crystal to program the chip.
edit: Regarding your original post, note that efuse = 0x07 or 0xFF is the same, because for this chip and fuse only the low 3 bits matter.
Maybe thats where I get screwed up, I kept seeing people have 0xFF and thought mine was messed up. FWIW it worked without the external crystal so that's good...not sure why it didn't work last time.
Hi, thanks for all your help! I have an Arduino UNO (ATmega328P) And STK-500. I read all the settings for fuses and lock bits. High Voltage programming on the stk500. Just about to give up switched back to the default settings on the stk500. Gave it one last try on the fuses, got no errors. So why not program the optiboot 328? BANG it took. Kept saying no. Put the chip into the UNO and could not find it. Rebooted the W10 and looked again! Plugged in the USB cable really helped! Booted up Arduino And in the background studio 7 was booting(?) And my Arduino was working!! Not only am I happy, I am dumbfounded to know what happened!
(Or is this actually called Geenuss?) On HVP my hi,lo,ex was backwards, changing some of the checks was changing my hi,lo,ex and I think I see what was happening. I tried some other things with the lock bits and turned off verify. And I saw something was happening. But in HVP keept getting FF for all 3 hi,lo,ex. Back in default STK-500 (shipped) it took the fuse settings they were different from what I did in HVP but in default it let me change the fuses to what I needed. And then I put in the optiboot! 8-) ... I think I remember the STK-500 HVP saying I cannot test the settings in HVP. But all I tried previously had not worked.
This article will help you. I also used this and it worked successfully.
https://www.allaboutcircuits.com...
Pavindu
