input pin interrupt self triggering
12 posts / 0 new
I wrote the following code that runs on the ATmega4809 development board and the output constantly pulses at 89KHz regardless of whether there is an input or not. I can't work out where this frequency is picked up from and why it won't follow the frequency of the sig gen when connected:
#include <avr/interrupt.h>
#include <inttypes.h>
ISR( PORTA_PORT_vect){
	PORTD.OUTSET = ( 0x1 << 4 );
	PORTD.OUTCLR = ( 0x1 << 4 );
	// I/O setup
	PORTA.DIRCLR = 0x1 << 0; // make PA0 INPUT
	PORTD.DIRSET = 0x1 << 4; // make PA1 OUTPUT
	PORTA.PIN0CTRL = (0x1 << 0) | (0x1 << 3); // Setup PA0 with interrupt enabled on both edges and pull up enabled
	sei(); // Turn global interrupts on.
    /* Application code */
    while (1)
My guess is the pull up is not enable as you think it is.
The pull up should not make much difference? I'm driving with a 0-5V signal
That was not stated in the OP.   Watchdog perhaps?
I thought WDT too but you can't make it go that fast can you?
1 / 89kHz  = 11us
Don't you need to clear the interrupt flag inside the ISR before exiting?
is the watchdog enabled by default?
If I connect the input to ground and power it up nothing comes out. As soon as I disconnect it the output starts up and no matter what I do it does not change.
Interrupt flags are not automatically cleared after the interrupt is executed. The respective INTFLAGS register descriptions provide information on how to clear specific flags.
Got it to work :) Thank you for your help.
Now to get the PWM decode on a TCB to work
Good, but how? For the benefit of anyone else who has the same problem and finds this topic how did you solve it?
If it was a post above then use the 'mark as solution' button.
resetting the interrupt did it. But I am still confused as to how it was pulsing at all.
