Problem by using transmission of string or char in external interrupt
4 posts / 0 new
hi
i want to send string by USART in external interrupt .
my project is :
one bluetooth module connected to external interrupt . , .....
when i am connecting to module ,ext interrupt work correctly but i use usart transmission on ISR(INT1_vect) , several sequence of string send to me .
my code :
 * PROBLE_USART_INT_1.c
 * Created: 10/25/2018 08:01:09 AM
 * Author : HF
//device : atmega328
#define F_CPU 16000000UL
#include <util/delay.h>
#include <avr/interrupt.h>
void UART_init(uint32_t baud){
	UBRR0H = (((F_CPU)/(baud*16UL)-1)>>8);                    // shift the register right by 8 bits for UBRRH
	UBRR0L = ((F_CPU)/(baud*16UL)-1);                        // set baud rate value for UBRRL
	UCSR0B|= (1<<TXEN0)|(1<<RXEN0);                // enable receiver and transmitter
	UCSR0C|= (1<<UCSZ00)|(1<<UCSZ01);             // 8bit data format
void UART_transmit_char (unsigned char data)
	while(!(UCSR0A & (1<<UDRE0)));
	UDR0 = data;                            // load data in the register
void UART_transmit_string(char *command){
	while(*command != 0x00){
		UART_transmit_char(*command);
	command++;}
char UART_recieve (void)
	while ( !(UCSR0A & (1<<RXC0)) );                 // wait while data is being received
	return UDR0;                                   // return 8-bit data
UART_init(9600);
//setting external interrupt 1 for BLT connection
EICRA |= (1<<ISC10)|(1<<ISC11);  //The rising edge of INT1 generates an interrupt request.
EIMSK |= (1<<INT1);  //Enable interrupt 1
sei();
    while (1)
ISR(INT1_vect){
	UART_transmit_string("HELLO HOSSEIN");
output after connect to bluetooth mdule :
HELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEINHELLO HOSSEIN
Bad design. Never do "long work" like UART transmission from within an ISR. On an AVR you'll keep interrupts disabled for far too long. Instead have the ISR set a flag then have the foreground code trigger the UART activity from that flag.
I think you're seeing 'contact bounce'. It's not a good idea to use an external interrupt for mechanical switches.
thanks , so you say that me how can find one connection from bluetooth module ?
