[TUT] [C] Using the EEPROM memory in AVR-GCC
356 posts / 0 new
Pages
Thanks you for helpingyes
Every Atmel Datasheet I've seen has code examples on how to access the EEPROM similar to this:
Containing a wait loop looking at the EEPROM busy bit.  No external delay needed.  How did you miss that?
Hi, I've followed the tutorial through and had some success. I'm trying to use the eeprom for counters so I know how often and on what mode the product is used and so at a point I want to increment one in an array of counters.
I tried to follow through on the example code but convert it to uint16_t array. Some save, some don't. Is my eeprom update block statement correct? Can I even do this?
Thanks in advance,
#include
uint16_t  EEMEM NonVolatileString[10];
	uint16_t  SRAMstring[10];
	eeprom_read_block((void*)&SRAMstring, (const void*)&NonVolatileString, 10);
	SRAMstring[1]++;
	eeprom_update_block((const void*)SRAMstring,(void*) NonVolatileString,10);
markah
10 bytes is not the length of a 10 element array of 16bit values. The size is actually 20 bytes (10 lots of 2 bytes). Of course you could just use:
eeprom_read_block((void*)&SRAMstring, (const void*)&NonVolatileString, sizeof(SRAMstring));
This way if you value the [10] dimension the number of bytes read/written will vary.
Well "some" means the first 5 save and the second 5 don't.
Doh!
Not the first time you have come to my rescue! Much appreciated
Mark
markah
Pages
