Eclipse trouble
5 posts / 0 new
Hi freaks, when I use the following function:
#include "F:\atmel-software-package-master\drivers\network\ethd.h"
ethd_get_mac_addr(board_get_eth(0), 0, mac_addr);
inside main on Eclipse it wors, but when I use it outside of main it fails to resolve the call...  I'm guessing its a Eclipse setting that I have wrong.  Any ideas?
Does it work in other functions ( than main() ) in the same file as main()?n Wondering if there is something unique about the file that contains main vs the other files?
it was a makefile error on my part
Don't but drive letters or (usually) even path names in the #include - do that external using -I's because, otherwise this code is too tied to the specific layout on your own PC. If you shared this with someone else it's likely they won't have the same layout as you. In fact they probably won't have an "F:" at all.
As you are working with an ARM package, perhaps moderator will move the thread to an appropriate forum.  Then, since you are using Eclipse, your programming will be better.
