Operators Precedence Query
6 posts / 0 new
Hi
I read a few manuals & I am still a little bit stump.
I have this piece of code from someone else very old program & they are not around any more.
int Voltage, Offset;
    Voltage += Offset * 4 * 6;
From what I can work out that you work from left to right.
So if I break this down, it should be equivalent to in basic term.
My interpretation is this one
Voltage = (Voltage + Offset) * 4 * 6
Not this
Voltage = Voltage + (Offset * 4 * 6)
Am I correct it is the 1st one that I should use.
Please advise.
Ken
No. The += will always happen last. In fact, any operator that includes = as an assignment (as opposed to comparison) has the lowest precedence. Aside from that, * has a higher precedence than +, so it would never be interpreted the second way even if you wrote it:
Voltage = Voltage + Offset * 6 * 4;
You would have to explicitly use the parens.
Any good C book will give you the full order of precedence of all operators.
Steve A.
Bad guess. Assignment operators are very low precedence. It is equivalent to the second one.
A copy of K&R or a quick google will turn up an operator precedence table for C.
Hi
Thanks for the quick responses.
I knew I might get a bit of flaking here but I did look up some C manuals.
Coming from Pascal, Delphi & Asm, it's a bit hard to wrap my head around it.
Just for the sake of rational.
I set up the constant with "Offset = 20" and "Voltage = 700".
So the procedure is work from the right to the left starting with "*" then "+".
1) 4 * 6 = 24
2) Offset (20) * 24 = 480
3) Voltage(700) + 480 = 1180
So my answer is 1180.
Correct me if I am wrong.
Ken
The only thing you REALLY need to know about precendence are that parentheses are higher than anything else. If in doubt just add in some brackets!
Cliff
Hi
Will bear that in mind about the brackets.
Thanks to all.
Ken
