Problems in setting & clearing pins of ATxMEGA32 A4u
5 posts / 0 new
Hi guys,
I am new to avr micro-controllers and thus had a few basic questions. Thank you in advance for all the suggestions.
I am writing the following code to set and clear following pins of ATxMEGA32 A4u: (PINs are connected to SPST switches in DG612 IC. )
void main( void )
//setup pins as output.
    PORTE.DIRSET = PIN1_bm; //switch0
    PORTE.DIRSET = PIN0_bm; //switch1
    PORTE.DIRSET = PIN2_bm; //switch2
    PORTE.DIRSET = PIN3_bm; //switch3
 //set initial switch positions
    PORTE.OUTCLR = PIN1_bm; //switch0
    PORTE.OUTSET = PIN0_bm; //switch1
    PORTE.OUTCLR = PIN2_bm; //switch2
    PORTE.OUTCLR = PIN3_bm; //switch3
Thus I want a high at PIN0 (i.e 3v) and low (i.e. 0v) for rest of the mentioned PINs. However I get 3.3v at PIN0 and get 2-3v at other PINs. I am not sure why do I get these voltages. I made sure that ground, AVCC & VCC pins get the proper voltages.  I also checked my connections and no short appears in the pins. Please let me know what might be the problem.
Has timer T0 been initialized for pwm output?
Click Link: Get Free Stock: Retire early!
Hi Jim,
I had not done it initially but now I have. Still it did not affect my output.
Just out of interest:
why 4 writes to the same register? Why not simply:
    PORTE.DIRSET = PIN1_bm | PIN0_bm | PIN2_bm| PIN3_bm; //switches 0..3
Anyway in #1 you said:
Exactly what pins are you testing? The actual pin numbers for PORTE are:
So with your code I'd expect pin 28 to be 3.3V and pins 29, 32 and 33 to be 0V.
(that's always assuming those 4 pins aren't already attached to some other circuitry).
Thanks for suggesting a simpler way to set the directions. For the voltages I am measuring at pins 28, 29, 32, 33. I found out the problem, it was due to a faulty switch IC to which I had connected these PORTE pins.
Thanks a lot!
