ATTiny84A - TIMER 0 flash question
23 posts / 0 new
High all:
I'm diving into AVR Timers and Interrupts with a little project.  To learn a bit more about the various timers, settings, and interrupts I used an ATTiny84A running 5 VDC on the Internal 8 MHz oscillator...CLOCK/8 fuse set.  So the device is running 1 MHz.  Fuses are:
EX: 0xFF   HIGH: 0xDF   LOW: 0x62
Here is the code I'm using for this test:
#define F_CPU 1000000UL
#include <avr/interrupt.h>
#include <util/atomic.h>
volatile uint16_t intPulseCount;
int intFlash;
ISR(TIM0_COMPA_vect)
	intPulseCount++;
	DDRB  |= (1<<PORTB0)|(1<<PORTB1)|(1<<PORTB2);	//- Set B0, B1, and B2 as OUTPUT
	//- Set up TIMER0 - 8-bit - Output Flash Timer
	TCCR0A = (0<<WGM02)|(1<<WGM01)|(0<<WGM00)|		//- Timer 0: CTC Mode (Clear Timer on Compare Match)
	         (0<<COM0A0)|(0<<COM0A1);				//- Output compare disable
	TCNT0 = 0;										//- Initial timer value
	OCR0A  = 250;									//- Timer 0: 0.002 second period
	TIMSK0 = (0<<OCIE0B)|(1<<OCIE0A)|(0<<TOIE0);	//- Timer 0: Output Compare Match A Interrupt Enabled
	TCCR0B = (0<<CS02)|(1<<CS01)|(0<<CS00);			//- Timer 0: Clock with 8 prescaler & start clock
	intPulseCount = 0;
	intFlash = 0;
	sei();											//- Enable Global Interrupts
	PORTB |= (1<<PORTB2);							//- Turn on power LED (3)
	PORTB |= (1<<PORTB1);							//- Turn on LED 2
	PORTB &= ~(1<<PORTB0);							//- Turn off LED 1
		if (intPulseCount >= 5000)
			ATOMIC_BLOCK(ATOMIC_FORCEON)
				intPulseCount = 0;
			if (intFlash == 1)
				intFlash = 0;
				intFlash = 1;
				PORTB |= (1<<PORTB0);
It's almost there if I could figure out one issue: the LED flash isn't what I expect.  I expected it to be on for half a second, then off for half a second.  What I seeing is on for a quarter second, off for three quarters of a second.  While that isn't bad, I want to understand why it's different from what I expect to see.
Here is an example Video on YouTube of what I am seeing.
I've moved the ATOMIC_BLOCK to encompass only the "intPulseCount = 0" inside the main loop.  When I try to change the prescaler and OCR0A to another value that would provide the same timing, the flash patter will change a bit.  The overall cycle is 1 second, but sometimes I get a flash for half a second, then a quick "blip" flash...and that repeats.
I'm thinking it has to do with the interrupt being thrown faster than the main loop is doing its thing, but I'm not sure.  250 clock pulses goes by pretty fast.
Any nudge in the right direction would be appreciated.
Thanks.
-Joe
Check your braces { } again, to see if they really line up where you think they should.
Hmmmm....I don't see a problem with them.  I know the formatting was a little screwy when I Copy-n-Pasted the code over.
It may not make any difference but I can't see a power bypass cap anywhere (100nF), maybe it's under the board.
Without bypass cap the processor could reset randomly.
If the micro was resetting randomly the other LEDs would turn off, I believe.  But it was a good find so I put one on and tried it again.  No joy...
Something else really strange...
If I put the code like this:
TCCR0A = (1<<WGM01);				//- Timer 0: CTC Mode (Clear Timer on Compare Match)
TIMSK0 = (1<<OCIE0A);				//- Timer 0: Output Compare Match A Interrupt Enabled
TCCR0B = (1<<CS01);				//- Timer 0: Clock with 8 prescaler & start clock
intPulseCount = 0;
intFlash = 0;
...the LED still does the 25%-on/75%-off flash, but it is flashing.  If I change the code to this...
intPulseCount = 0;
intFlash = 0;
...the green LED comes on and stays on.  ?!?  What am I missing here?  I wouldn't think the order of where the output settings are would make the difference between it work and not working.  I pulled the code file into Notepad++ to make sure I don't have some sort of hidden control character in there or something.  Notepad++ also seems to show that the braces are lined up as I think they should be.  I'm not sure what I'm missing here...
But it would only be for microseconds so you would not see it as they would get turned on again at the beginning of the code. Sorry I tried laugh
Of course if you had a debugger you could put a breakpoint at the start of the code to see if a reset did happen.
Also I don't know why you use an int (16bit signed) for
int intFlash
when a uint8_t would do.
Unfortunately I don't have a T84 to test you code.
// should be DDB0        DDB1        DDB2
//           WGM02 resides in TCCR0B
//       249 (subtract one from desired count)
// with a 1MHz clock, divide-by-8 prescaler, and a count of 250, your
// interrupt should fire 500 times per second
        // the code in here should run only once every 10 seconds!
Since the LED should be toggling only once every ten seconds something else
is going on, not a problem that can be solved with different code.
--Mike
EDIT: #9 caught something I missed which could explain things - accessing a
16-bit variable without disabling interrupts first
I modified the code to run on a Mega88PA (same timer type) and changed the flashing led to PB1 as that's where the led is on my board.
The code runs OK however your expectations of " be on for half a second, then off for half a second " is not correct, it is more like 10 seconds as the post above suggests.
I had to change the clock not to be divided by 8 and changed the OCRA to 100, it now flashes at about 500ms.
 * dataweasel.c
 * Created: 9/10/2018 2:18:05 PM
 * Author : John Samperi
int intFlash;
//ISR(TIM0_COMPA_vect)
ISR (TIMER0_COMPA_vect)
	intPulseCount++;
	TCNT0 = 0;
//	OCR0A  = 250;									//- Timer 0: 0.002 second period
	OCR0A  = 100;
//	TCCR0B = (0<<CS02)|(1<<CS01)|(0<<CS00);			//- Timer 0: Clock with 8 prescaler & start clock
	TCCR0B = (1<<CS00);								//- Timer 0: Clock start clock
	intPulseCount = 0;
	intFlash = 0;
				intPulseCount = 0;
			if (intFlash == 1)
				intFlash = 0;
//				PORTB &= ~(1<<PORTB0);
				PORTB &= ~(1<<PORTB1);
				intFlash = 1;
//				PORTB |= (1<<PORTB0);
I don't know if this is causing the problem you're seeing, but the following is wrong:
It is wrong because you are not protecting the 16-bit variable access from being corrupted by ISR modifications.
But he is using
and I have verified it working correctly but with a different chip.
js wrote:
But he is using
He's not using it when he reads the value in order to compare with 5000.
Here's the example given in the online user manual, that correctly reads the shared variable:
#include <inttypes.h>
volatile uint16_t ctr;
ISR(TIMER1_OVF_vect)
  ctr--;
int
main(void)
   ctr = 0x200;
   start_timer();
   sei();
   uint16_t ctr_copy;
   do
       ctr_copy = ctr;
   while (ctr_copy != 0);
Even so the variable can only be a few counts above, if anything, and that would be a valid comparison on >=5000.
So I guess he can move the line one up.
I agree I don't see how it could make a huge difference.  I would expect at most an error of 0x100 which is only about 5% of 5000.
   do
       ctr_copy = ctr;
Okay...so use the ATOMIC_BLOCK to protect a quick copy of the value, then do the comparison with the copy?  This is similar to one place I read that has the ISR calling a function with a static variable or something like that.  Does anything change if I were to change the 16-bit variable to an 8-bit?  I know it takes more clock cycles to manipulate a 16-bit value.
-Joe
Not relevant to >>this<< problem, because you're setting it to '0' here, but WGM02 is not in TCCR0A.  It's in TCCR0B.
Also, as @avr-mike points out, the timing you're expecting (half-second on, half-second off) doesn't match the code.  At 1 MHz, with a prescaler of /8 and a period of 251 (note it is not 250, since in CTC mode the top value  must be 1 less than the period you desire), the timer frequency should be 1000000 / (8 * 251) = 498.007968127 Hz.  If you're counting 5000 overflows, then the LED should toggle every 10.039999962 seconds, not every half second.  How did you arrive at that figure?  Show your math.
I agree, something else is going on.  Try this sanity check:
#include <util/delay.h>
int main(void) {
  DDRB |= (1 << PORTB0) | (1 << PORTB1) | (1 << PORTB2);
  PORTB |=  (1 << PORTB2);
  PORTB |=  (1 << PORTB1);
  PORTB &= ~(1 << PORTB0);
  while (1) {
    _delay_ms(500);
    _delay_ms(500);
    PORTB |= (1 << PORTB0);
Yes, grabbing a copy (using an atomic access) is the standard procedure.  If you use an 8-bit variable the problem goes away, because neither the variable read nor the setting of the variable to 0 (or any value) is now interruptible.  To summarize (for AVR or any other 8-bit device that I know of):
Read a variable:
8 bit is not interruptible
>8 bit is interruptible
Set a variable:
RMW (read-modify-write, e.g. counter++ or counter += 10):
Any size (8 bit or larger) is interruptible
kk6gm wrote:
Read a variable:
Set a variable:
Okay...good info.  So I should ATOMIC block for the comparison on any IF statements as well.  Basically, if I even think about the variable I should ATOMIC block it.  I think I am also going  to also rework the code to get rid of the 16-bit variable in this area.
As for the math for the flash frequency...I was looking at it from the clock period being set to 0.002 second and 5000 overflows would be the 1 second.  It sure looks like 1 second right now.  I'm going to rework the math using the information above and check my timing.
Everyone...I appreciate the learning experience.
-Joe
Only those that are shared between ISR() and main()!
https://www.onegold.com/join/7134f67c2b814c5ca8144a458eccfd61
Your code works exactly as I was expecting my code to work.  50% on, 50% off.  Going to look into the WGM02 item.
-Joe
So does YOUR CODE I modified above https://www.avrfreaks.net/commen...
Just looked at <util/atomic.h> and didn't understand the code.
You could replace the ATOMIC_BLOCK with the following and
see if things improve:
        cli();
            cli();
                intPulseCount = 0;
            sei();
            if (intFlash == 1)
                intFlash = 0;
                intFlash = 1;
        sei();
The above is just a test, I wouldn't actually write the code this way.
--Mike
Realise that but possibly better is:
        uint8_t old_sreg = SREG;
        cli();
            cli();
                intPulseCount = 0;
            SREG = old_sreg;
            if (intFlash == 1)
                intFlash = 0;
                intFlash = 1;
        SREG = old_sreg;
