basic LED blinking code
20 posts / 0 new
// Project:
// Author:
// Module description:
#include <avr\io.h>              // Most basic include files
#include <avr\interrupt.h>       // Add the necessary ones
#include <avr\signal.h>          // here
#include <util/delay.h>
// Define here the global static variables
int My_global;
// Interrupt handler example for INT0
SIGNAL(SIG_INTERRUPT0) {
// It is recommended to use this coding style to
// follow better the mixed C-assembly code in the
// Program Memory window
void my_function(void) {  // Put the open brace '{' here
   asm("nop");          // Inline assembly example
// Main program
int main(void) {
DDRB|=0xff;
PORTC=(1<<1)|(1<<2);
//PORTB=(1<<4);
  while(1) {
  if(PINC&(1<<PC1)) {
       PORTB=0X55;
       delay_ms(2000);
       PORTB=0XAA;
       delay_ms(1000);  }
     if(PINC&(1<<PC2)){
       PORTB=0X55;
       delay_ms(2000);
       PORTB=0XAA;
       delay_ms(2000);  }
void delay_ms	(int d )
//while(1);
can someone tell me why  LED is not toggling every 1 and 2 sec?
must have tried indefinite times :(
Start by removing all the PINC input stuff. Just do the loop to drive the output:
int main(void) {
  DDRB = 0xff;
  while(1) {
       PORTB=0X55;
       delay_ms(2000);
       PORTB=0XAA;
       delay_ms(1000);
So first verify that works then add the complications afterwards.
PS I don't see where you set F_CPU??
Get into the habit of specifying path names with a forward slash instead of a back-slash:
#include <avr/io.h>              // Most basic include files
#include <avr/interrupt.h>       // Add the necessary ones
#include <avr/signal.h>          // here
See:
https://stackoverflow.com/questions/5790161/is-the-backslash-acceptable-in-c-and-c-include-directives
Where is my check list of giving all needed information?
Please post a complete test program.  Tell your AVR model and clock speed.  Tell your language, brand of toolchain and version.  Tell compile options, and build results.  Are there any warnings?Show your schematic and describe what is connected.
What do you expect to happen?  What >>is<< happening?  How are you testing?
 What do you expect to happen?  What >>is<< happening?  How are you testing?  No lamps at all?  Bulbs explode?   Cops arrive at door?
https://www.nongnu.org/avr-libc/...
#define SIGNAL (   vector )
Introduces an interrupt handler function that runs with global interrupts initially disabled.
This is the same as the ISR macro without optional attributes.
Deprecated:
Do not use SIGNAL() in new code. Use ISR() instead.
Hi Clawson,
Thanks for the response
I intend to toggle  my led using key as input
I've used key1 and key2
so, when I press key1, the led should toggle with a delay of 1 second
and with key2 it should toggle with a delay of 2 seconds
Also, the F_CPU has been configured in the  .prj file
i.e 1MHz
Well, we are part of the way there.
when I press key1, the led should toggle with a delay of 1 second and with key2 it should toggle with a delay of 2 seconds
We still don't know what doesn't work...
Did any one mention "show schematics/connections"?
Enabling the pullups for the "button" pins implies to me active-low switches.  But the code is looking for a high.
I was so pissed off with the "not working code" that I simply wanted to know the reasons behind it
I didn't even realize I haven't mentioned any of the details
AVR model :ATMEGA8
clock speed: 1MHz
 language: embedded C
brand of toolchain and version: VMLAB
build results.: successful
  Are there any warnings: No warnings
what is connected. :PORTC(PC1,PC2) are inputs(keys)
desired output:PORTB which is the output needs to toggle every 1 second on pressing key1 and 2seconds on pressing key2
I am working on simulator
Please let me know if I have missed anything
Kindly do the needful as I am still a learner
I ensure sincere efforts from my side
 all I need is a little push
"  if(PINC&(1<<PC1)) "
if this is what you are talking about, I am trying to tell the compiler that if   button 1(WHICH IS CONNECTED to PORTC.1) is pressed, the pull-up resistor should get activated  which in turn says if (TRUE)
and do the delay job of 1second
Same is the case with Portc.2 for 2 seconds delay
what doesn't work:
my LED which should pause for 1 and 2 seconds but once it is into the while loop it is continuously blinking irrespective of the delay I am giving
WHAT >>IS<< HAPPENING?
Did you see my comment on active-low switches?
Did you do Cliff's basic blink test?  Do you see the lamp then?
Assuming active-low switches on PC1 and PC2, then in a real application switches/buttons bounce wo you need to address that.  But for your purposes you need to think about each of your if() tests...
// Check for active-low on PC1 and only PC1 and not PC2
if ((PINC & 0x06) == 0x04)
        // PC1 pressed and not PC2
// Check for active-low on PC2 and only PC2 and not PC1
if ((PINC & 0x06) == 0x02)
        // PC2 pressed and not PC1
ok
Now it has come down to a part of what my required output is
The LED toggles on when key1 or 2 pressed
Thanks for that Theusch
but,not with the delay I expected
That is nonsense.  Show your connections.  With your code, how do you ever expect the level on that pin be >>not<< a high logic level.
You are finally saying a bit about what >>is<< happening.  What does "continually blinking" mean?  Surely a vital piece of information to do a diagnosis is "what is the blink rate".
Let me go back to
Again you give only partial information.
ok..let me put in an algorithm:
step1: set input pins PORTC1,PORTC2
Step2:set output port PORTB
STEP3:if button1 i.e portc1 is pressed(active-low as suggested by you)-->o/p toggle LED with a delay of 1second   1sec-on-- wait for delay(1second)-off---wait for delay(1second)
Else,portc2 is pressed-->o/p:o/p toggle LED with a delay of 2second   2sec-on-- wait for delay(2second)-off---wait for delay(2second) is expected o/p
current o/p:
led is in on -state
when key1 is pressed, the led toggles (definitely not with one sec delay)
same is the case with key2
Let me go back to
I am not using << and >> after following your  piece of code :)
and as far as this is concerned
I am unable to put it in proper terms
anything else I need to add?
WHAT IS HAPPENING?  Is it that hard to say "I expect the LED to blink every 1.23 seconds, but it is blinking at a rate of 2.34 seconds."  Or 1 second.  Or 10.  Or 100.  Along with the code actually being used, how is anyone supposed to help with a solution if no one knows what the symptoms are?
Apparently you know better.  Apparently I am irritating you by asking pertinent questions.  I'm out.
@ manaswini1317
Please do not edit the code in your OP as it no longer makes sense to what CLiff wrote after, and the posts after and so on.  When oyu make changes, post in your response those changes instead.  This way folks reading the thread for the first time understand what is happening.
Thanks Jim..will follow your suggestion
apologies if the tenor of the tone came out wrong
I am just asking if I missed out anything else that might  help you to lead me to a solution
kindly understand that this is my first post in the forum
never my intention to be rude
Are you sure the CPU is operating @ 1MHz? I would do just a simple blink program, without keys, for testing.
edit:
Why do you have this function:
//while(1);
The function defined in util/delay.h has a leading underscore: _delay_ms()
thanks, much Tangas for leading me to expected o/p
