Hello to everyone,
I am new in this AVR FREAKS so I was used Atmel Studio7 and ATMEGA16A microcontroller with ATMEL ICE burner so I check the communication then communication is fine when I debug my code they make an error.
Here is my code
// MyAtmelBlink.c // put LED on PC5 #ifndef F_CPU // if F_CPU was not defined in Project -> Properties #define F_CPU 1000000UL // define it now as 1 MHz unsigned long #endif #include <avr/io.h> // this is always included in AVR programs #include <util/delay.h> // add this to use the delay function /////////////////////////////////////////////////////////////////////////////////////////////////// int main(void) { DDRC |= (1 << PC5); // set Port C pin PC5 for output while (1) { // begin infinite loop PORTC ^= (1 << PC5); // flip state of LED on PC5 _delay_ms(500); // delay 1/2 second } return(0); // should never get here, this is to prevent a compiler warning }
what could I do please help me.
