Atmega16 as a counter using timers0
9 posts / 0 new
hello freaks,
I just got into Timer/counter programming, and i'm trying to make a counter circuit using atmega16 and 7-segment.
but i reached to a point where the counting on 7-segment displays doesn't go well.
Here is the code I used and the circuit is attached too:
#define  F_CPU 1000000ul
#include <util/delay.h>
#define SegOne   0x01
#define SegTwo   0x02
#define SegThree 0x04
	TCCR0 |= (1<<CS02) | (1<<CS01);
	TCCR0 &= ~(1<<CS00);
	DDRC = 0xff; // Data lines
	DDRD = 0xff; // Control signal PORTD0-PORTD3
	int num,temp;
	char seg_code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
    while (1)
		num = TCNT0;
		temp = num / 100;
		num = num % 100;
		PORTD = SegOne;
		PORTC = seg_code[temp];
		_delay_ms(1);
		temp = num / 10;
		num = num % 10;
		PORTD = SegTwo;
		_delay_ms(1);
		temp = num / 1;
		PORTD = SegThree;
		_delay_ms(1);
Can anyone please tell me where is my mistakes?
What do you mean by ‘doesn’t go well’?
like the first digit counts to 9 then it is starts again from 0 till it reaches 9 again then 0 then the next digit becomes 8 and it stays like that for ever.
What have you done to narrow down the problem?
i'm still trying to modify the code.
I wrote the right code, thank you for you interests.
I just changed the delay time form 1ms to 10ms and it worked properly.
but i still don't know what is the explanation.
How fast can the human eye see and interpret what is displayed? Updating 300 times per second is beyond what the human can decode. 30 times per second is more likely.
Stop opening more threads asking the same question!
I will lock this one and keep thr other one open
Topic locked
